Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Carbon cleaning, now stuck intake valve...
  1. #21
    Well usually only one roller rocker I see pop off but never saw two on same ZYL.
    Anything is possible for a first but shear on crank or cam or broken chain sounds more likely.
    Can't wait to see though, gets me excited like a wet KESSY!
  2. Likes Uwe liked this post
  3. #22
    May 2019
    Maryland, USA
    Happy Saturday! ��
    https://youtu.be/1gtIDk7OKBU
  4. #23
    Jun 2014
    Newcastle, England
    Ah.
    Well, there's your problem...
  5. Likes jyoung8607 liked this post
  6. #24
    And is there fuel dilution in oil causing that too happen I almost wonder?
  7. #25
    May 2019
    Maryland, USA
    I did send the injectors out for ultrasonic cleaning, the cleaners said one would not stop leaking after shut off...
    I ordered a new one.
  8. Likes Uwe liked this post
  9. #26
    Mar 2016
    Very late post here, read the first page and watched the video. Lot of labour time gone on there to see that event taking place. DSO and a relative compression test would show a cylinder inefficiency fault and which cylinder within a few seconds. Equipment available (WPS 500x) you could prove the valve train operation within a few seconds and check each valve in each cylinder. You'd also see events like valve timing, exhaust back pressure and cylinder compression's of each cylinder.
    Every job is important, even the lowliest, and peoples lives very much depend on us all, so with this in mind, let no man delude himself that his work is more important than that of his colleagues.
  10. #27
    May 2019
    Maryland, USA
    Well, the car is back on the road, ended up taking it to a local VW shop I have been going to for years.
    New - Intake cam, cam follower, rocker arm, and associated parts.
    Not a cheap repair but the car feels great.
    Thanks for the help, this seems to be the last useful forum alive.
  11. Likes Uwe, jyoung8607, NZDubNurd liked this post
