Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Carbon cleaning, now stuck intake valve...
    May 2019
    Maryland, USA
    2011 GTI
    135,000 miles
    Chains and tensioner replaced my local VAG shop less than 5000 miles ago with OEM parts.
    Car was throwing intake code 008213 for a couple of months but still getting 30MPG.
    One day I was getting a miss fire so decided it was time to rip it apart.
    I'm doing valve cleaning, new intake manifold, sent the injectors out for ultrasonic cleaning, and new water pump.
    I noticed that the far right intake valve is not opening or closing when I turn the motor over. All other valves operate properly. I have spun the motor by hand and by cranking with the fuel pump fuse out. The valve never moves, stayed in the closed position at all times.
    When I was doing the cleaning I may have spun the motor counter clockwise not knowing till after the fact to spin it clockwise. I was only spinning the motor with pulling/ pushing on the belt so I didn't get many turns on it. Even then I never remember the valve opening or closing.
    When I cranked it over with the battery/ starter nothing sounded "bad".
    Thoughts? Did my screw up throw something off with the timing?
    Wouldn't more than one valve be doing that if that were the case?
    EDIT: Someone from another forum suggested the valve may have bent BEFORE this causing the misfire.
    I just pulled the codes and the codes are -
    008213
    000768
    000770
    000769
    008817
    000772
    On another note 1 of the 4 injectors would not stop leaking and the cleaning company suggested replacing as it will leak fuel into the cylinder after the car is off.
    May 2019
    Maryland, USA
    **** sorry about the cross post *******
    2011 GTI
    135,000 miles
    008213
    000768
    000770
    000769
    008817
    000772
    Please post a complete auto-scan & OBD2 data MODES 1,3,7&9.
    Is this car modified?
    Have you read the entire JPPSG thread?
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by eppy View Post
    Uh... video? Having a hard time visualizing how that could happen without seriously damaged or outright missing parts.
    Do you perhaps mean stuck open rather than stuck closed?
    Try to avoid doing that, but you probably didn't hurt anything.
    It's a decent possibility.
    008213
    000768
    000770
    000769
    008817
    000772
    Complete un-edited Auto-Scan please. Looking up fault codes manually is a super PITA and we would still be missing all the fault elaboration and freeze-frame data.
    Silence gives consent.
  5. Likes PetrolDave, Jack@European_Parts, Dana liked this post
    Nov 2016
    If the valves arent moving, i would be taking the rocker cover off and see whats happening. If the camshaft snapped, are the lifters moving etc
  7. Likes Jack@European_Parts, Uwe liked this post
    Excuse me but does anyone know if carbon cleaning of plugged intakes or timing chain replacement or adjuster are now considered preventive maintenance as required in the RTFB during useful life warranties & being shifted to consumers for responsibility?
    ........ fəˈsēSHəs
    May 2019
    Maryland, USA
    I'm sorry I did not, but have now.
    Car is modified-
    HPA KO4 with all supporting mods, intake, full turbo back, turbo pipes, intercooler.
    Clutch, LSD, and other things that would not be related to this issue.
    The codes at the bottom of the list are from trying to crank with the battery/starter with the car apart so its throwing codes for stuff that is disconnected.
    Video - https://youtu.be/BeBuX9DIpdM
    I start at the affected cylinder pan to the others and back to the affected one.
    Thursday,02,May,2019,21:51:38:09276
    VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
                    Address 01: Engine       Labels: 06J-906-026-CCT.clb
    Control Module Part Number: 1K0 907 115 AS    HW: 1K0 907 115 AA
      Component and/or Version: 2.0l R4/4V TFSI     0010
               Software Coding: 0403010A18070160
                Work Shop Code: WSC 59851 128 16480
                          VCID: 77D309CF06E978F2EA-8022
    19 Faults Found:
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 000 - Implausible Signal - Intermittent - MIL ON
                        Fault Status: 10100000
                        Mileage: 212766 km
                        Date: 2027.14.23
                        Time: 05:43:47
                        RPM: 2437 /min
                        Load: 58.0 %
                        Speed: 83.0 km/h
                        Temperature: 36.0C
                        Temperature: 7.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.224 V
                        Mileage: 215628 km
                        Date: 2028.14.21
                        Time: 14:48:05
                        RPM: 1462 /min
                        Load: 65.1 %
                        Speed: 30.0 km/h
                        Temperature: 95.0C
                        Temperature: 31.0C
                        Voltage: 13.843 V
                   P0300 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 216655 km
                        Date: 2029.14.02
                        Time: 10:56:40
                        RPM: 1163 /min
                        Load: 38.0 %
                        Temperature: 27.0C
                        Temperature: 27.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.716 V
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected - MIL ON
                        Mileage: 216655 km
                        Date: 2029.14.02
                        Time: 10:56:44
                        RPM: 1119 /min
                        Load: 35.7 %
                        Temperature: 27.0C
                        Temperature: 29.0C
                        Voltage: 14.097 V
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent - MIL ON
                        Mileage: 216787 km
                        Date: 2029.14.03
                        Time: 10:29:58
                        RPM: 965 /min
                        Load: 33.7 %
                        Temperature: 45.0C
                        Temperature: 24.0C
                        Voltage: 14.097 V
    008817 - Oxygen (Lambda) Sensor Signal B1 S2
                   P2271 - 000 - too Rich - Intermittent
                        Mileage: 217068 km
                        Date: 2029.14.08
                        Time: 20:18:21
                        RPM: 2771 /min
                        Load: 10.2 %
                        Speed: 112.0 km/h
                        Temperature: 94.0C
                        Temperature: 21.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.716 V
    000772 - Cylinder 4
                   P0304 - 000 - Misfire Detected - Intermittent
                        Mileage: 217124 km
                        Date: 2029.14.09
                        Time: 06:22:23
                        RPM: 3693 /min
                        Load: 28.2 %
                        Speed: 149.0 km/h
                        Temperature: 94.0C
                        Temperature: 30.0C
                        Voltage: 13.716 V
    000290 - Throttle Position Sensor (G69)
                   P0122 - 000 - Signal too Low - MIL ON
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    000546 - Angle Sensor 2 for Throttle (G188)
                   P0222 - 000 - Signal Too Low - MIL ON
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    008212 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2014 - 000 - Electrical Malfunction
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    000568 - Manifold Pressure / Boost Sensor (G31)
                   P0238 - 000 - Signal too High
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    000400 - Fuel Pressure Sensor (G247)
                   P0190 - 000 - Circuit Malfunction
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 000 - Electrical Malfunction
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 11.938 V
    001092 - EVAP Purge Control Valve (N80)
                   P0444 - 000 - Circuit Open
                        Mileage: 217197 km
                        Date: 2029.14.10
                        Time: 00:00:21
                        RPM: 209 /min
                        Load: 100.0 %
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 10.668 V
    008200 - Intake Manifold Flap; Bank 1
                   P2008 - 000 - Electrical Malfunction
                        Mileage: 217197 km
                        Date: 2029.14.10
                        Time: 00:00:21
                        RPM: 209 /min
                        Load: 100.0 %
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 10.668 V
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 000 - Signal too High
                        Mileage: 217197 km
                        Date: 2029.14.10
                        Time: 00:00:21
                        RPM: 215 /min
                        Load: 100.0 %
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 10.795 V
    000112 - Sensor for Ambient Air Temperature (G17)
                   P0070 - 000 - Malfunction
                        Mileage: 217197 km
                        Date: 2029.14.10
                        Time: 00:00:22
                        RPM: 216 /min
                        Load: 100.0 %
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 10.668 V
    000835 - Camshaft Position Sensor (G40)
                   P0343 - 000 - Signal too High - MIL ON
                        Mileage: 217197 km
                        Date: 2029.14.10
                        Time: 00:00:23
                        RPM: 215 /min
                        Load: 100.0 %
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 10.668 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 000 - Supply Voltage
                        Mileage: 217197 km
                        Date: 2029.14.10
                        Time: 00:00:24
                        RPM: 200 /min
                        Load: 100.0 %
                        Temperature: 18.0C
                        Temperature: -40.0C
                        Voltage: 11.684 V
  10. Likes Dana liked this post
  11. #8
    Cincinnati, OH
    Wow.
    That valve does look reasonably well closed and sealed, although you'd have to compression test to be absolutely certain. If it was bent, it'd be stuck at least partly open. Valve cover needs to come off for further diagnosis. If you're lucky, that's just a collapsed hydraulic lifter. If you're not lucky, there's a fully wiped out cam lobe, or some other parts fell off and started dancing around.
  12. Likes Uwe, Dana, NZDubNurd liked this post
  13. #9
    May 2019
    Maryland, USA
    Wow.
    100% sealed as the chamber held cleaning fluid when I was working on the valve.
    Thoughts on this being a pre-existing issue that was throwing the misfire code or my shade tree ass messing something up?
    I never checked the codes when it started to misfire, I drove it home, parked it, and torn it apart, thinking it was manifold/ carbon related.
    The only questionable thing I did was possibly spinning the engine backwards during the cleaning.
  14. #10
    Okay so no warranty, Emissions defeats and a most likely broken timing chain or sheared camshaft.
  15. Likes Dana liked this post
