Abs pump coding from Italy
ilDandi
Pirate
Walking the Plank
Rome, Italy
Hi all! I'm new here, I'm from Rome, I'm helping a friend of mine having problems with ABS pump on his 2004 Audi A3. He swapped the ABS controller from 1K0 907 379 F to 1K0 907 379 Q. I didn't scan the car before the swap. Now I can't complete with success basic settings for G200 and G201. I checked the coding and it's correct. The only option I see to solve this issue is long coding. Do anybody know if this will fix it?
Tuesday,30,April,2019,15:41:22:04550
VCDS Version: 15.7.0.2
Data version: 20150729
Rest removed.   Data from a Clone/Pirate copy of VCDS is not welcome here.
Viking
C?ID=151455
If you update your VCDS to the latest version then that would be a good starting point.
+1
Version 15.7.0.2 is nearly 4 years out of date, updates are free for as long as you own a genuine Ross-Tech cable so there is no reason not to update.
