Results 1 to 4 of 4
Thread: Abs pump coding from Italy
    Pirate
    May 2019
    Rome, Italy
    Hi all! I'm new here, I'm from Rome, I'm helping a friend of mine having problems with ABS pump on his 2004 Audi A3. He swapped the ABS controller from 1K0 907 379 F to 1K0 907 379 Q. I didn't scan the car before the swap. Now I can't complete with success basic settings for G200 and G201. I checked the coding and it's correct. The only option I see to solve this issue is long coding. Do anybody know if this will fix it?
    Tuesday,30,April,2019,15:41:22:04550
    VCDS Version: 15.7.0.2
    Data version: 20150729
    Rest removed.   Data from a Clone/Pirate copy of VCDS is not welcome here.
    Nov 2015
    If you update your VCDS to the latest version then that would be a good starting point.
  3. Likes iichel, Uwe liked this post
    Quote Originally Posted by Viking View Post
    +1
    Version 15.7.0.2 is nearly 4 years out of date, updates are free for as long as you own a genuine Ross-Tech cable so there is no reason not to update.
  5. Likes Uwe liked this post
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#it
  7. Likes PetrolDave liked this post
