2012 Audi A3 FWD DSG
Pulled a 01325 VAG code and now I'm trying to figure out where the control module is. Any idea's?.
FYI - This TPMS is part of the ABS system and doesn't have the individual tire sensors. My initial guess is it's part of the ABS control module...
Saturday,27,April,2019,11:11:13:35040
VCDS Version: 18.9.1.0 (x64)
Dealer/Shop Name: Bailey
VIN: WAUBEAFM1CA146705 License Plate: DAY321
Mileage: 66120km-41085mi Repair Order: RR ABS Sensor
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 56 62 72
77
VIN: WAUBEAFM1CA146705 Mileage: 66120km-41085miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 8P0 907 115 BC HW: 8P0 907 115 AL
Component: 2.0l R4/4V TFSI 0020
Revision: E3H26--- Serial number: AUX7Z0L2FNN0M8
Coding: 010301081C070160
Shop #: WSC 28047 001 1048576
VCID: 74ED35851733CFEAC9-8020
U1017 - 015 - - Intermittent
Fault Status: 00101111
Fault Frequency: 15
Mileage: 65847 km
Date: 2019.04.17
Time: 05:23:42
RPM: 1267 /min
Load: 10.6 %
Temperature: 89.0°C
Temperature: 36.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.938 V
U1017 - 007 - - Intermittent
Fault Status: 00100111
Fault Frequency: 11
Mileage: 65896 km
Date: 2019.04.18
Time: 18:35:53
RPM: 3083 /min
Load: 11.8 %
Speed: 60.0 km/h
Temperature: 42.0°C
Temperature: 14.0°C
Voltage: 13.462 V
U1017 - 000 - - Intermittent
Mileage: 65978 km
Date: 2019.04.20
Time: 07:01:10
RPM: 1266 /min
Load: 8.2 %
Temperature: 96.0°C
Temperature: 49.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
Part No SW: 02E 300 057 R HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3115
Revision: 05551213 Serial number: 00001203090328
Shop #: WSC 06314 000 00000
VCID: 285511F59B7BFB0AB5-807C
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Fault Frequency: 255
Reset counter: 1
Mileage: 66020 km
Date: 2019.04.21
Time: 05:20:17
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 1150600F49260000881206E4921E0041BF0C00
VCID: 7BFF1EB9FA6D809288-802E
Reset counter: 88
Mileage: 66123 km
Date: 2019.04.22
Time: 22:57:15
Count: 16387
Count: 12
Count: 28672
Count: 16390
Count: 43264
Count: 1025
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0180
Revision: 000677 Serial number: 8P0820043BN
VCID: 79F304B13051B2829A-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 Q HW: 8P0 907 063 Q
Component: BCM PQ35 M 110 0667
Revision: AJ110667
Coding: 6E000A0FA01336E4287241E00000054D401A60AA104DC92AE40008800040
VCID: 4281A35DDD07315A8B-8016
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7M0611521
Coding: 0000100
VCID: 3669CF8D41CF9DFA37-8062
Reset counter: 71
Mileage: 65847 km
Date: 2019.04.17
Time: 05:22:19
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 Q HW: 8P0 959 655 Q
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003FC001PS64
Coding: 303142393041303030374A55304C38503053
ROD: EV_Airba10AURB4.rod
VCID: 50A599150B6BD3CA0D-8004
Subsystem 1 - Part No SW: 8P0 959 339 E HW: 8P0 959 339 E
Component: BF-Gewichtss. H04 0040
Serial number: 5850000R11B0900RKC
Serial number: 3572DRB40000E84CE140
Serial number: 3582DRB40000E8510AC.
Serial number: 35128RB400006A375B4L
Serial number: 35228RB400006A19AB2P
Serial number: 35547RB400006A7D57C/
Serial number: 35647RB400006A2772DS
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0014042
VCID: 4689BF4D312F0D7AA7-8012
Component: E0221 H02 0100
Part No SW: 8P0 920 983 C HW: 8P0 920 983 C
Component: KOMBIINSTR. VDO H04 0150
Revision: D0H04003 Serial number: 2242L003003244
Coding: 0272288
VCID: 3A71DBBD75D7799AD3-806E
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 110312F1000604
Coding: 352102
VCID: 3A71DBBDB5D7799AD3-806E
Revision: D0H04003 Serial number: AUX7Z0L2FNN0M8
Shop #: WSC 34433 003 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0001205
VCID: 4993B4712031E2024A-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 233 3305
Revision: 00H22000
VCID: 3777C28946C564F22C-8062
Fault Status: 00101101
Fault Frequency: 33
Reset counter: 128
Mileage: 66123 km
Date: 2019.04.22
Time: 21:45:44
Voltage: 13.38 V
DU
Temperature: 29.0°C
RPM: 1062 /min
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158129020230
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0001205
VCID: 4A918B7D2537E91A43-801E
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AC HW: 8P0 035 186 AC
Component: R Concert2+ H02 0293
Revision: 00H02000 Serial number: AUZ1Z3K1265131
Coding: 0750112
VCID: 73EF3699123DC8D2D0-8026
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0001168
Shop #: WSC 06314 000 1012544
VCID: 4281A35D1D07315A8B-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0001168
VCID: 438FA659021D385280-8016
Part No SW: 8P1 862 336 A HW: 8P1 862 336
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005164379
Coding: 0001277
