- Dec 2, 2016
- 85
- 25
- Cardiff(ish), South Wales, UK.
- C?ID=288281
Hi Folks!
I have been tasked with facelifting a UK 2012 Amarok with the newer Bi-Xenon headlights with LED DRLs.
I have replaced the BCM from 6R7 937 087 H to 7H0 937 090 D and added the wires from the T10 headlight plug to the T73 BCM plugs and replaced the light switch to 6R0 941 531 G.
I have got all function apart from side lights, DRLs and main beam flash when lights are in the off position, however, I can hear the shutters moving when the stalk is pulled. Main beam works fine with the light switch in the dipped beam position...
Here is the autoscan with the old BCM fitted (taken a while ago but still correct)
and here is the scan after fitting the wiring and BCM MAX (I stupidly tried coding I found online but no dice)
There were loads of differing guides on what is needed to get the lights fully working but most were for left hand drive and lower spec models so for example where it was saying to add in new power wires from the fuse box to the BCM, the fuse locations were already occupied? I also have VCP to hand if needed.
Any and all help will be hugely appreciated!
Thanks
Wednesday,10,April,2019,16:36:48:50827
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
VIN: WV1ZZZ2HZCA025970 License Plate:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 10 15 17 19 22 25 56 69
VIN: WV1ZZZ2HZCA025970 Mileage: 144270km-89645miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FA HW: 03L 907 309 K
Component: R4 2.0l BTD H43 9978
Revision: 26H43--- Serial number: 00000000000000
Coding: 01194012232600080000
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
ROD: EV_ECM20BTD01103L906019FA_004.rod
VCID: 6FAE22C7B65B873234-803A
13812 - Exhaust Gas Temperature Sensor 4 Bank 1
P246F 00 [096] - Implausible Signal
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 G HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0106
Revision: 00H44001
Coding: C07324B69196039A24AB89AAAF5010
Shop #: WSC 07456 790 49164
VCID: 3424EDAB97FDE4EA09-8060
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H0 907 040 D HW: 2H0 907 040 D
Component: ClimatronicT5 H11 0304
Revision: 00001002
Coding: 0000000002
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 22081BF335097A5AEB-8076
9481988 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 H HW: 6R7 937 087 H
Component: PQ25 BCM H12 0022
Revision: -1------ Serial number: 1002480801
Coding: 3C0002380C410400923008003C0A04C40080410E600000003000
Shop #: WSC 00513 210 99189
VCID: 49DAAC5FE07F89024A-801C
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3321
Coding: 110000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3321
Coding: 110000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 001 001 0103
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HORN H11 H11 9005
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Coding: 100000
Subsystem 7 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Coding: 100000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 D HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47301122400266
Coding: 108003
ASAM Dataset: EV_VW75XParkAssis4K A01006
ROD: EV_VW75XParkAssis4K_A01.rod
VCID: 3326EEB79AF3E3D210-8066
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00M H06 0013
Revision: -------- Serial number: 003HN0052J2S
Coding: 00000000000000000000000000000000304D
Shop #: WSC 07446 790 50316
Serial number: 3495RRB40630LCOSB8G4
Serial number: 3505RRB405H0LCOS415R
Serial number: 3555YRB40670II4KIO82
Serial number: 3565YRB40570IOK4D1CR
Part No SW: 2H0 920 963 BX HW: 2H0 920 963 BX
Component: KOMBI H02 0505
Coding: 450A00
VCID: 014A747F90CF8142D2-8054
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 087 H
Component: GW-K-CAN TP20 0022
Revision: -1------
Coding: 742300
VCID: 70AC21BBA36598CA2D-8024
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IYC23212BIS0
Coding: 0000013
VCID: 2F2EE2C7BEDBC73274-807A
Component: IMMO H02 0505
VCID: 6A9833D38DB9621A63-803E
Address 56: Radio
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000398123109
Coding: 0100000100000000
VCID: 302CE1BB63E5D8CA6D-8064
End----(Elapsed Time: 01:24, VBatt start/end: 11.5V/11.5V. VIgn 11.6V)-----
Monday,29,April,2019,22:45:21:50827
Scan: 01 03 04 08 09 10 15 17 19 22 25 56 69 0B
VIN: WV1ZZZ2HZCA025970 Mileage: 144960km-90073miles
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
10-Park/Steer Assist -- Status: Not registered 0001
15-Airbags -- Status: Not registered 0011
22-AWD -- Status: Not registered 0001
56-Radio -- Status: Not registered 0011
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Revision: 00H44001
03095 - Diagnostic interface for databus (J533) implausible messa.:
Revision: 00001002
Coding: 0000000002
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
B10AF 04 [009] - Internal System Fault
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0726
Revision: B9078001 Serial number: 0661 163150037
Coding: 640002380CB3040011300E316DCB84D45A81672F60053041300000020003
Shop #: WSC 18752 008 00032
VCID: 2F2EE2C77EDBC73274-807A
Coding: 110000
Coding: 110000
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H11 9005
Coding: 100000
Coding: 100000
01516 - Terminal 30; Left
00927 - Terminal 30 (Right)
Coding: 108003
12854016 - Databus
[Kombi1 DLC Error]
Coding: 450A00
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0726
Revision: B9078001
Coding: 002000
00381 - Databus Instrument Cluster
Coding: 0000013
Address 56: Radio
End----(Elapsed Time: 02:17, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
Thanks
