B6 Passat DQ500 retrofit project
kamold
Australia
C?ID=241363
Hi All,
The mechatronics in my 2009 R36 is starting to fail. It's an older revision that's not worth reconditioning.
So rather than replace the mechatronics with a new revision, and renewing the clutches, I'm considering instead going for a DQ500 retrofit. Mainly for durability and also for a longer cruising gear. Not chasing power upgrades at this stage (but would be good to have the option down the track).
I'm in the information gathering stage at this point and would really appreciate any insight.
I'm looking at a 2013 Tiguan 2.0TSI 132kw that has 58k kms on it. DSG PN is 0BH300012B. Gearbox code NYE.
Is this a suitable donor? Another possibility is a 2015 with gearbox code NZT.
A possible list of parts I might need:
- Transfer/bevel box
- Drive shafts, left + right
- Starter motor (is this only needed in turbo engines due to clearance issues?)
- Gearbox body mounts
- linkage adapter, or DQ500 shift mechanism complete as cable is slightly longer
- suspension subframe
- transfer box arm
- A few 90 degree elbows for DSG cooler pipes
- connector for TCU 8P0971499A
I have some suitable aftermarket TCU software lined up.
Do I need to swap the dual mass flywheel for a different version, or is it just a good idea to renew it given the trans is out?
Plan would be to get the car up on the hoist, sit the DQ500 underneath and plug it in via the adapter and check that I can see some valid MVBs and code it. Then proceed if it looks OK.
kamold
Australia
C?ID=241363
Looks like I'd also need an adapter between the face of the trans and engine as the angle of interface between the two is different for 4/5 cylinder engines when compared to VR6...starting to look a bit more involved than I'd like for my daily drive. Can't have it sitting for a few weeks while I work out the kinks :(
myounus
Northwest UK
C?ID=321059
It's defo a worthwhile retrofit and you're defo better off replacing the flywheel. However I suspect the end cost will be eye watering and the list of modifications will skyrocket. You might be able to source custom made adapter plates for the mounting. In Europe this retrofit has been done only by a few!
rhinopower
C?ID=58979
On other cars, I’ve been able to swap the bellhousing to deal with issues where the doner gearbox for an upgrade sits at a different angle. Is this an option to use an earlier bellhouding on the dq500 box?
kamold
Australia
C?ID=241363
I'm not sure if it is...is there a car that comes from factory with a VR6 and DQ500? If so then it might be an option. Otherwise I think it's using an adapter plate.
kamold
Australia
C?ID=241363
I think a modified bell housing might be the way that this is accomplished. Need to find someone who does them...
kamold
Australia
C?ID=241363
So I've bravely (stupidly??) gone ahead and pushed forward on this project.
DQ500 is now installed with custom bell housing, driveshafts, starter motor and transfer case from 2013 Tiguan TSI.
I've repinned the 20pin connector to 16pin connector, omitting the extra power, ground and K Line pins which don's exist for the DQ500 OBH TCU connector.
The TCU communicates fine and I can see correct gear selector in advanced values, and these are also shown on the cluster.
However the ECU always shows a gear selection in advanced values of 0, so if I try and start the car it fails and reports car not in Park.
Looking over the WDs there is a purple/black wire which in my 2009 02E transmission goes from pin 17 at the TCU connector to the J519.
In the 0BH wiring diagram for a 2013 Tiguan, the purple/black wire goes from pin2 on the TCU connector, to the J519 BCM, but ALSO to the ECU at pin 42.
My guess is that this is the missing wire which the ECU should be reading the gear selection information from, where it would have read it over the K Line before.
Has anyone had any experience with this retrofit and can confirm or deny this hypothesis?
Bonus points for advising which pin on my MED9.1 ECU this should be connected to....
Thursday,22,August,2019,23:13:05:58930
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4505.4
VIN: WVWZZZ3CZ9E08  License Plate: DQ500 IN
Mileage: 145800km-90595mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 42 44 46 47 4F 52
          53 55 5F 62 65 6C 6D 72 A5
VIN: WVWZZZ3CZ9E08   Mileage: 145800km-90595miles
Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 AM    HW: 03H 906 032 AB
   Component: R3.6-FSI-EU4    F   3488
   Revision: 5GH04---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 52104 002 1048576
   VCID: 6D87377FB19F9D4F11F-8038
7 Faults Found:
005748 - Powertrain Data Bus
               P1674 - 001 - Implausible Message from Instrument Cluster - Intermittent
                    Fault Status: 00100001
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 00:06:16
                    Temperature: 14.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 11.938 V
005717 - Please check DTC Memory of Auto. Distance Controller
               P1655 - 004 -  - Intermittent
                    Fault Frequency: 7
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 00:06:16
                    Temperature: 14.0°C
                    Temperature: 14.0°C
                    Voltage: 11.938 V
005715 - Please check DTC Memory of ABS Controller
               P1653 - 004 -  - Intermittent
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 00:06:17
                    Temperature: 14.0°C
                    Temperature: 14.0°C
                    Voltage: 11.938 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 00:22:09
                    Temperature: 14.0°C
                    Temperature: -40.0°C
                    Voltage: 11.811 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High
                    Fault Status: 01100010
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 00:22:09
                    Temperature: 14.0°C
                    Voltage: 11.811 V
               P0100 - 002 - Supply Voltage
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 00:22:10
                    Temperature: 14.0°C
                    Voltage: 11.811 V
049409 - No Communication with Transmission Control Module
               U0101 - 008 -  - Intermittent
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 00:23:08
                    Temperature: 14.0°C
                    Voltage: 11.811 V
Readiness: 0110 0101
   Part No SW: 0BH 300 011 T    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H07 1808
   Revision: 00H07V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3333E1079BBB0BBF07B-8066
   Part No SW: 3AA 698 109 N    HW: 3AA 614 109 AL
   Component: J104   C2 450M VEEC 0042
   Revision: --H07---    Serial number: 00000007379684
   Coding: 0119716
   Shop #: WSC 11111 111 45799
   VCID: 44D1B2DBC295BC07AE1-8010
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:26
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.50 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: -----------    HW: -----------
   Component: Climatronic   0404
   Revision: --------
   Coding: 0009000002
   Shop #: WSC 12345 123 61029
   ROD: EV_ACClimaBHBVW411_VW46.rod
   VCID: 6FBB2D77B7136F5F233-803A
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Bordnetz - kein Signal/Kommunikation]
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:26
   Revision: 00H54000    Serial number: 00000009027172
   Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
   Shop #: WSC 12345 123 00000
   VCID: 3333E107973B0BBF07B-8066
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 100908 022  0601
   Coding: 00047029
   Shop #: WSC 12345
   Component: RLS     121108 054  0402
   Coding: 00208936
   Shop #: WSC 12345
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39431711102403
   Coding: 0121164011
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: 3B23C927B3EBC3FFDFB-806E
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:27
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000569541
   Coding: 0010000
   Shop #: WSC 00046 000 00000
   VCID: 3829D62B8E5DE8E7329-806C
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__00S VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPMPB81T
   Coding: 0012371
   Shop #: WSC 05311 000 00000
   VCID: 7AAD0C23F0D13AF784D-802E
   Subsystem 1 - Serial number: 6333FTS665962908
   Subsystem 2 - Serial number: 6343FTS632552888
   Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
   Subsystem 4 - Serial number: 6363ETS640PKVVNR
   Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20160725000799
   Coding: 399AA50003
   VCID: 71BF2B0FA12779AF357-8024
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Coding: 830000
Address 17: Instruments (J285)       Labels:. 3C8-920-xxx-17.clb-SRI1
   Part No SW: 3AA 920 881     HW: 3AA 920 881
   Component: KOMBI         H03 0705
   Coding: 711F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1682
   Revision:   H51       Serial number: 18011400F15997
   Coding: 352007
   VCID: 7BA30927F3EB03FF9FB-802E
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         052 0407
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 06402 785 00200
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F3BED777B132F5F633-807A
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0008275506
   Coding: 0013F7
   VCID: 3537DF1F95CF158F29F-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389__TSG-HR  004 0307
   Serial number: 00000000693593
   Coding: 0000D0
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:26
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 143    3501
   Revision: 00H15000
   VCID: 392FD32FB557F1EFCD7-806C
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:24
                    Battery Volts: 12.1 V
                        DD
                    Temperature: 17.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Component:    KSG PQ47 ELV 052 0645
   Coding: 00900A00D1034E7F000294157008DFCE607841
   Shop #: WSC 11111 111 45725
   Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
   Component: DSP 10 Kanal        0013
   Revision: 00010000    Serial number: 00000000002780
   VCID: 2313114727DB9B3FF7B-8076
                    Fault Status: 00100110
                    Reset counter: 20
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:26
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:27
            006 - Short to Plus
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:27
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1682
   Coding: 00000001
   VCID: 6FBB2D77B7936F5F233-803A
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0008282177
   Coding: 0013F6
   VCID: 3635D81388C91E97205-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0503
   Serial number: 00000003880813
   Coding: 0106D0
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:26
   Revision:   H19       Serial number: 00000001024031
   Coding: 0022157
   Shop #: WSC 12345 111 45725
   VCID: 3635D81384491E97205-8062
   Component: AFS-Steuergeraet    0136
   Coding: 2311185
   VCID: 3431E21B92350C871E1-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
   Component: MU-S-ND-ER    H31 0367
   Serial number: VWZAZ2T5074914
   Coding: 027404010000000011111105400908001F01079600F081014E
   ROD: EV_MUStd4CTSAT_VW46.rod
   VCID: 231311472B5B9B3FF7B-8076
   Subsystem 1 - Part No SW: 5NA 919 866 AD    HW: -----------
   Component: MRM3 2020  --- 1310
          B201A 00 [009] - -
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:26
                    Voltage terminal 30: 11.5 V
                    Status_Software_Version_Management-module_name:
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 40000000055443
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD5178FC3E79F3B3-8062
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 01130608A201000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 3039EE0B6AAD30A77A9-8064
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 G    HW: 3C9 827 383 G
   Component: J605  HECKDECKEL    0730
   Revision: 00H27001
   VCID: 3537DF1F994F158F29F-8060
   Subsystem 1 - Part No: 3C9 827 384 G
   Component: J756  HECKDECKEL    0730
   Subsystem 2 - Serial number: 0900H27001001B0191ÿ
Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H04 0610
   Serial number: 290515null1593
   Coding: 000406040000040100021044C090800090000E10000000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_VW46.rod
   VCID: 40D9BECBDA0DA0278A9-8014
4195331 - Databus
          [LH_EPS_03_EPS_HCA_Status]
                    Reset counter: 236
                    Mileage: 145805 km
                    Date: 2019.08.22
                    Time: 01:14:27
                    Control Module temperature: 18 °C
                    Outside air temperature: 12.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 45.8 s
                    Voltage terminal 15: 11.4 V
                    mid: 02 A7
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
End----(Elapsed Time: 01:51, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
rhinopower
C?ID=58979
Does it not communicate over can-bus? Is the extra wire the lin bus otherwise?
kamold
Australia
C?ID=241363
DSG talks fine over can. Gear selector display shows correctly in the cluster.
That extra wire is for Park signal to BCM. It is only needed to ECU for start stop from what it looks like.
kamold
Australia
C?ID=241363
OK the issue is actually with the CECM not getting a valid signal from the TCU to indicate the position of the park/neutral this is the fault:
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Control Module Part Number: 3C8 937 049 E HW: 3C8 937 049 E
Component and/or Version: Bordnetz-SG H54 2602
Software Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
Work Shop Code: WSC 12345 123 00000
Additional Info: 3C2955119B Wischer 100908 022 0601 1K0955559AH RLS 121108 054 0402
02389 - Release Signal Transmission; Position P/N
Reset counter: 236
Mileage: 145805 km
So this is the pin that goes from pin 2 at the DQ500 TCU to pin 7 at the CECM.
If I pull this pin, or ground it I still get the exact same fault. So the CECM can't determine the status of park/neutral and therefor won't trigger the starter motor.
Into the interwebs we go.....see if anyone else has had a similar issue
siLc
Tallinn, Estonia
C?ID=330192
I wouldn't be surprised if this means a 3C8 CECM to 3AA BCM retrofit. In theory, of course. I mean, all the cars having the DQ500 from the factory have a BCM.
kamold
Australia
C?ID=241363
No there are plenty of cars older than mine running CECM and DQ500.
The problem is the transmission IS actually in gear. It must have been in gear when it was removed from the wrecked vehicle.
If I bypass the start check and crank the engine the car moves because it's in gear.
So what I plan to do is this, appreciate any input:
1. Bypass the P/N check in CECM by pulling pin 2 of the TCU connector to ground. The CECM is looking for 0v on this wire from the TCU. Anything non-zero means the transmission is NOT in P or N.
Checking the wire voltage I see a floating voltage of around 2v or 0.6v.
2. Put the car up on the hoist so the wheels are free to move.
3. Put gear selector and TCU selector into D
4. Start the car and then try and put the transmission properly out of gear and into park
5. Return TCU wiring to correct wiring
Will this likely work? Or anything similar? I had to leave the car at the workshop and go and hire a car to pick the kids up so when I get back I'd like to have a solid plan of attack.
Any thoughts or conjecture welcome.
siLc
Tallinn, Estonia
C?ID=330192
Aah, I see. Googling with "drive2 dq500 passat" should net you some Passat B6-es from the drive2.ru site.
A nice challenging retrofit. Good luck and keep us posted.
kamold
Australia
C?ID=241363
So remarkably enough, my half-baked plan worked!! I had visions of having to pull the DQ500 back out and install the original DQ250 again to get the car working...
The park/neutral check from the TCU to CECM is still incompatible. Have that bypassed by pulling pin 2 to ground. Will sort that out later.
The gearbox is now functioning normally. Can properly engage and disengage park, go forwards and backwards. TCU software is still stock, that needs to be replaced with custom software.
Need a wheel alignment because of the new driveshafts.
And I've somehow managed to introduce a vacuum leak near the fuel pump. I can hear it hissing but only had a quick look and couldn't see what it was. Pulled the cam cover back off and checked the PCV which was fine. Only fault is idle rpm too high. It presents like a failed PCV membrane apart from the obvious sucking sound.
rhinopower
C?ID=58979
Will the modified TCU software fix the compatibility with CECM, or are you going to take the BCM plunge?
For the vac leak, i use break cleaner, have a little spray around and see when the rev's pick up
kamold
Australia
C?ID=241363
Yeah the brake cleaner trick is the next step when I can get back down there.
I don't think the TCU software will fix it. BCM is a big job I'm not sure I want to go down that route yet. It might just need a newer CECM maybe. I tried to update the software on mine as there looks to be a newer version but it fails and says conditions not met so might just need to get a newer rev of the CECM maybe.
dieseltje
Groningen, The Netherlands
C?ID=148044
Going to follow this thread.
Is this for a 4cyl Tdi (commonrail) straight forward? Or do I get the same problems with my CECM?
MasterTommy
Amsterdam
C?ID=295586
Edit: forgot to read the next page
kamold
Australia
C?ID=241363
OK now not going so well :(
Cannot complete basic settings.
Aborted due to safety reasons. Main reason 0, sub reason 91.
This happens very early at the point of closing clutch.
Same in VCDS or ODIS.
Driving:
Clutch slipping a lot in 1st. Once 2nd is engaged drive is normal. 3rd is all slip. 4th gear engages ok again.
Reverse engages ok.
After a drive TCU has logged this fault:
10895 - Clutch 1
P1898 00 [047] - Function Restriction
Coupling function restriction
The transmission has 55,000kms on it so I don't think the clutches themselves would be a problem?
The transmission has had the bell housing removed and installed with a custom modified one for the mounting to VR6 engine.
Starting to think I've bitten off more than I can chew....open to any suggestions
Thinking maybe that the clutches on K1 are fully binding having sat around without having had fluid through them while the gearbox was sitting at the wrecking yard....will look into getting a new clutch basket kit, and at the same time replace the K1/K2 clutch solenoids in the mechatronics.
kamold
Australia
C?ID=241363
I logged a basic settings attempt:
Wednesday,04,September,2019,12:08:56:58930-VCID:3333E1079BBB0BBF07B-8066,VCDS Version: Release 19.6.1,Data version: 20190529 DS308.0
0BH 300 011 T,ADVMB,DSG DQ500-7A  H07 1818,
,,G017,F0,G062,F0,G084,F0,G085,F0,G090,F0,G091,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. IDE00322-ENG100540,TIME,Loc. IDE02775-ENG101304,TIME,Loc. IDE02824-ENG99279,TIME,Loc. IDE02825-ENG100313,TIME,Loc. IDE02858-ENG100590,TIME,Loc. IDE02859-ENG99797,,,,,,,,,,,,,
,STAMP,Status of basic setting-Basic Settings Status,STAMP,Status of basic setting data-State Of Basic Adjustmentdata,STAMP,Main status of abort code basic setting-Basic Settings Main Status,STAMP,Substatus of abort code basic setting-Basic Settings Sub Status,STAMP,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,STAMP,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,,,,,,,,,,,,,
,0.12,0,0.16,valid,0.21,0,0.25,1,0.29,gültig Grundeinmessung,0.03,gültig Defaultwerte,,,,,,,,,,,,,
,0.41,0,0.45,valid,0.49,0,0.54,1,0.58,gültig Grundeinmessung,0.33,gültig Defaultwerte,,,,,,,,,,,,,
,0.71,0,0.75,valid,0.80,0,0.85,1,0.89,gültig Grundeinmessung,0.63,gültig Defaultwerte,,,,,,,,,,,,,
,1.02,0,1.06,valid,1.10,0,1.14,1,1.19,gültig Grundeinmessung,0.94,gültig Defaultwerte,,,,,,,,,,,,,
,1.32,0,1.36,valid,1.41,0,1.45,1,1.48,gültig Grundeinmessung,1.24,gültig Defaultwerte,,,,,,,,,,,,,
,1.59,0,1.63,valid,1.67,0,1.72,1,1.77,gültig Grundeinmessung,1.52,gültig Defaultwerte,,,,,,,,,,,,,
,1.89,0,1.94,valid,1.99,0,2.03,1,2.08,gültig Grundeinmessung,1.82,gültig Defaultwerte,,,,,,,,,,,,,
,2.21,0,2.25,valid,2.30,0,2.35,1,2.39,gültig Grundeinmessung,2.13,gültig Defaultwerte,,,,,,,,,,,,,
,2.83,192,2.88,valid,2.92,2,2.97,0,3.01,gültig Grundeinmessung,2.44,gültig Defaultwerte,,,,,,,,,,,,,
,3.20,192,3.25,valid,3.29,14,3.34,0,3.39,gültig Grundeinmessung,3.06,gültig Defaultwerte,,,,,,,,,,,,,
,3.58,192,3.62,valid,3.67,14,3.72,0,3.76,gültig Grundeinmessung,3.44,gültig Defaultwerte,,,,,,,,,,,,,
,3.95,192,4.00,valid,4.05,14,4.09,0,4.14,gültig Grundeinmessung,3.81,gültig Defaultwerte,,,,,,,,,,,,,
,4.33,192,4.37,valid,4.42,14,4.47,0,4.52,gültig Grundeinmessung,4.18,gültig Defaultwerte,,,,,,,,,,,,,
,4.71,192,4.77,valid,4.81,14,4.86,0,4.90,gültig Grundeinmessung,4.56,gültig Defaultwerte,,,,,,,,,,,,,
,5.09,192,5.14,valid,5.18,14,5.23,0,5.28,gültig Grundeinmessung,4.95,gültig Defaultwerte,,,,,,,,,,,,,
,5.47,192,5.51,valid,5.56,14,5.61,0,5.66,gültig Grundeinmessung,5.33,gültig Defaultwerte,,,,,,,,,,,,,
,5.84,192,5.89,valid,5.93,14,5.98,0,6.03,gültig Grundeinmessung,5.70,gültig Defaultwerte,,,,,,,,,,,,,
,6.21,192,6.26,valid,6.31,14,6.35,0,6.40,gültig Grundeinmessung,6.07,gültig Defaultwerte,,,,,,,,,,,,,
,6.59,192,6.63,valid,6.68,14,6.73,0,6.77,gültig Grundeinmessung,6.45,gültig Defaultwerte,,,,,,,,,,,,,
,6.93,192,6.98,valid,7.03,14,7.07,0,7.12,gültig Grundeinmessung,6.82,gültig Defaultwerte,,,,,,,,,,,,,
,7.30,192,7.36,valid,7.40,14,7.44,0,7.49,gültig Grundeinmessung,7.17,gültig Defaultwerte,,,,,,,,,,,,,
,7.68,192,7.73,valid,7.78,14,7.82,0,7.87,gültig Grundeinmessung,7.54,gültig Defaultwerte,,,,,,,,,,,,,
,8.02,192,8.07,valid,8.12,14,8.16,0,8.21,gültig Grundeinmessung,7.91,gültig Defaultwerte,,,,,,,,,,,,,
,8.40,192,8.45,valid,8.49,14,8.54,0,8.58,gültig Grundeinmessung,8.26,gültig Defaultwerte,,,,,,,,,,,,,
,8.77,192,8.82,valid,8.86,14,8.92,0,8.96,gültig Grundeinmessung,8.63,gültig Defaultwerte,,,,,,,,,,,,,
,9.15,192,9.19,valid,9.24,14,9.29,0,9.33,gültig Grundeinmessung,9.01,gültig Defaultwerte,,,,,,,,,,,,,
,9.52,192,9.57,valid,9.62,14,9.66,0,9.71,gültig Grundeinmessung,9.38,gültig Defaultwerte,,,,,,,,,,,,,
,9.90,192,9.95,valid,9.99,14,10.04,0,10.08,gültig Grundeinmessung,9.75,gültig Defaultwerte,,,,,,,,,,,,,
,10.27,192,10.32,valid,10.36,14,10.41,0,10.45,gültig Grundeinmessung,10.13,gültig Defaultwerte,,,,,,,,,,,,,
,10.64,192,10.69,valid,10.74,14,10.79,0,10.83,gültig Grundeinmessung,10.50,gültig Defaultwerte,,,,,,,,,,,,,
,11.01,192,11.05,valid,11.09,14,11.15,0,11.20,gültig Grundeinmessung,10.88,gültig Defaultwerte,,,,,,,,,,,,,
,11.39,192,11.44,valid,11.49,14,11.53,0,11.58,gültig Grundeinmessung,11.26,gültig Defaultwerte,,,,,,,,,,,,,
,11.74,192,11.78,valid,11.83,14,11.88,0,11.93,gültig Grundeinmessung,11.62,gültig Defaultwerte,,,,,,,,,,,,,
,12.11,192,12.15,valid,12.18,14,12.22,0,12.27,gültig Grundeinmessung,11.97,gültig Defaultwerte,,,,,,,,,,,,,
,12.43,192,12.47,valid,12.51,14,12.57,0,12.61,gültig Grundeinmessung,12.31,gültig Defaultwerte,,,,,,,,,,,,,
,12.80,192,12.84,valid,12.89,14,12.94,0,12.98,gültig Grundeinmessung,12.66,gültig Defaultwerte,,,,,,,,,,,,,
,13.19,192,13.24,valid,13.28,4,13.33,15,13.37,gültig Grundeinmessung,13.04,gültig Defaultwerte,,,,,,,,,,,,,
,13.56,192,13.61,valid,13.65,5,13.70,15,13.75,gültig Grundeinmessung,13.42,gültig Defaultwerte,,,,,,,,,,,,,
,13.93,64,13.99,valid,14.03,0,14.08,91,14.12,gültig Grundeinmessung,13.80,gültig Defaultwerte,,,,,,,,,,,,,
,14.31,64,14.36,valid,14.40,0,14.45,91,14.50,gültig Grundeinmessung,14.17,gültig Defaultwerte,,,,,,,,,,,,,
,14.68,64,14.73,valid,14.78,0,14.82,91,14.87,gültig Grundeinmessung,14.54,gültig Defaultwerte,,,,,,,,,,,,,
,15.06,64,15.10,valid,15.13,0,15.17,91,15.21,gültig Grundeinmessung,14.92,gültig Defaultwerte,,,,,,,,,,,,,
,15.40,64,15.45,valid,15.50,0,15.54,91,15.58,gültig Grundeinmessung,15.26,gültig Defaultwerte,,,,,,,,,,,,,
,15.76,64,15.81,valid,15.85,0,15.91,91,15.95,gültig Grundeinmessung,15.62,gültig Defaultwerte,,,,,,,,,,,,,
,16.13,64,16.17,valid,16.21,0,16.26,91,16.31,gültig Grundeinmessung,15.99,gültig Defaultwerte,,,,,,,,,,,,,
,16.50,64,16.54,valid,16.59,0,16.64,91,16.68,gültig Grundeinmessung,16.35,gültig Defaultwerte,,,,,,,,,,,,,
,16.86,64,16.90,valid,16.95,0,16.99,91,17.04,gültig Grundeinmessung,16.73,gültig Defaultwerte,,,,,,,,,,,,,
,17.23,64,17.27,valid,17.32,0,17.37,91,17.42,gültig Grundeinmessung,17.09,gültig Defaultwerte,,,,,,,,,,,,,
,17.60,64,17.65,valid,17.70,0,17.74,91,17.79,gültig Grundeinmessung,17.46,gültig Defaultwerte,,,,,,,,,,,,,
,17.95,64,17.99,valid,18.04,0,18.08,91,18.13,gültig Grundeinmessung,17.83,gültig Defaultwerte,,,,,,,,,,,,,
,18.30,64,18.35,valid,18.39,0,18.42,91,18.46,gültig Grundeinmessung,18.17,gültig Defaultwerte,,,,,,,,,,,,,
,18.63,64,18.68,valid,18.72,0,18.77,91,18.82,gültig Grundeinmessung,18.50,gültig Defaultwerte,,,,,,,,,,,,,
,18.97,64,19.02,valid,19.07,0,19.12,91,19.16,gültig Grundeinmessung,18.86,gültig Defaultwerte,,,,,,,,,,,,,
Is anyone able to make any sense of the status codes?
I also had a look at measured values while shift between R/N/D whilst stopped with the park brake on.
Wednesday,04,September,2019,11:43:27:58930-VCID:3333E1079BBB0BBF07B-8066,VCDS Version: Release 19.6.1,Data version: 20190529 DS308.0
,,G063,F0,G064,F0,G065,F0,G066,F0,G082,F0,G149,F0,G150,F0,G151,F0,G152,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. IDE02776-ENG102757,TIME,Loc. IDE02777-ENG101539,TIME,Loc. IDE02779-ENG100646,TIME,Loc. IDE02780-ENG103741,TIME,Loc. IDE02821-ENG101653,TIME,Loc. IDE05988-ENG110505,TIME,Loc. IDE05989-ENG110503,TIME,Loc. IDE05990-ENG110506,TIME,Loc. IDE05991-ENG110504,,,,,,,
,STAMP,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,STAMP,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,STAMP,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,STAMP,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,STAMP,Pressure supply specified pressure/threshold1-Pressure Supply Commanded Value Threshold 1,STAMP,Pressure of clutch 2: actual value-Clutch_2_actual_value,STAMP,Pressure of clutch 1: actual value-Clutch_1_actual_value,STAMP,Pressure of clutch 2: specified value-Clutch_2_commanded_value,STAMP,Pressure of clutch 1: specified value-Clutch_1_commanded_value,,,,,,,
,, bar,, bar,, bar,, bar,, bar,, bar,, bar,, bar,, bar,,,,,,,
,0.58,25.00,0.70,3.05,0.81,25.00,0.94,3.05,0.03,3.05,0.16,-0.06,0.25,0.00,0.37,0.00,0.47,0.00,,,,,,,
,1.59,25.00,1.73,3.05,1.84,25.00,1.97,3.05,1.03,3.05,1.15,-0.06,1.24,0.00,1.37,0.00,1.48,0.00,,,,,,,
,2.61,25.00,2.76,3.05,2.83,25.00,2.95,5.10,2.06,3.05,2.18,-0.06,2.27,0.00,2.40,0.00,2.50,0.00,,,,,,,
,3.62,25.00,3.74,5.04,3.84,25.00,3.95,5.04,3.06,5.09,3.17,-0.04,3.28,2.25,3.39,0.00,3.54,2.01,,,,,,,
,4.62,25.00,4.74,5.04,4.85,25.00,4.96,5.04,4.06,5.04,4.18,-0.05,4.32,2.21,4.40,0.00,4.52,1.99,,,,,,,
,5.64,25.00,5.74,5.04,5.88,25.00,5.96,5.04,5.10,5.04,5.18,-0.05,5.29,2.21,5.40,0.00,5.51,1.99,,,,,,,
,6.61,25.00,6.71,3.05,6.83,25.00,6.94,3.05,6.08,5.04,6.18,-0.06,6.29,2.17,6.40,0.00,6.52,0.00,,,,,,,
,7.64,25.00,7.73,3.05,7.86,25.00,7.97,3.05,7.05,3.05,7.19,-0.06,7.30,0.00,7.43,0.00,7.52,0.00,,,,,,,
,8.63,25.00,8.75,4.78,8.86,25.00,9.00,4.76,8.08,3.05,8.21,-0.06,8.29,0.00,8.42,0.00,8.52,0.00,,,,,,,
,9.64,25.00,9.77,4.71,9.86,25.00,9.98,4.71,9.08,4.74,9.20,1.81,9.29,0.00,9.39,1.66,9.53,0.00,,,,,,,
,10.64,25.00,10.76,4.71,10.86,25.00,10.97,4.71,10.07,4.71,10.17,1.79,10.31,0.00,10.42,1.66,10.56,0.00,,,,,,,
,11.64,25.00,11.76,4.71,11.87,25.00,11.98,4.71,11.09,4.71,11.20,1.78,11.33,0.01,11.42,1.66,11.54,0.00,,,,,,,
,12.65,25.00,12.76,4.71,12.89,25.00,12.98,3.45,12.11,4.71,12.20,1.73,12.32,0.02,12.42,1.66,12.54,0.00,,,,,,,
,13.68,25.00,13.76,3.05,13.88,25.00,13.98,3.05,13.10,3.05,13.20,-0.06,13.32,0.00,13.44,0.00,13.54,0.00,,,,,,,
,14.66,25.00,14.76,3.05,14.88,25.00,14.99,3.05,14.10,3.05,14.21,-0.06,14.32,0.00,14.45,0.00,14.54,0.00,,,,,,,
,15.66,25.00,15.78,3.05,15.88,25.00,16.01,3.05,15.10,3.05,15.24,-0.07,15.32,0.00,15.43,0.00,15.54,0.00,,,,,,,
,16.66,25.00,16.80,5.08,16.88,25.00,17.00,5.07,16.10,3.05,16.22,-0.06,16.32,0.00,16.43,0.00,16.55,2.05,,,,,,,
,17.66,25.00,17.78,5.04,17.88,25.00,18.00,5.04,17.10,5.06,17.21,-0.05,17.34,2.23,17.44,0.00,17.57,1.99,,,,,,,
,18.66,25.00,18.77,5.04,18.88,25.00,19.00,5.04,18.11,5.04,18.22,-0.05,18.36,2.21,18.44,0.00,18.56,1.99,,,,,,,
,19.66,25.00,19.78,5.04,19.91,25.00,20.00,5.04,19.13,5.04,19.22,-0.05,19.34,2.21,19.44,0.00,19.56,1.99,,,,,,,
,20.69,25.00,20.78,5.04,20.90,25.00,21.00,5.04,20.12,5.04,20.22,-0.05,20.34,2.21,20.44,0.00,20.56,1.99,,,,,,,
,21.68,25.00,21.78,3.05,21.89,25.00,22.01,3.05,21.11,5.04,21.22,-0.05,21.34,2.21,21.48,0.00,21.56,0.00,,,,,,,
I know the next step is to take the gearbox back out and look at clutches and mechatronic however any suggestions welcome.
