Results 1 to 10 of 15
Thread: Bug: Live Data HUD
    Oct 2015
    Bug: Live Data HUD
    Hi, first of all thanks for the recent updates. One of them seems to have improved the responsiveness of the interface. Also, controller 31 finally has the label file for my RS4.
    The Live Data HUD is a good idea, but it currently has a bug where it does not display the selected fields correctly. If you go and configure multiple panes for one hud, it mixes data from the first pane into the second pane.
    In the following example, I've selected 3 unique fields for each pane.
    I configured Adaptation idle, adaptation partial, and lambda control for bank 1 on the left pane
    Then configured the same fields for bank 2 on the right pane
    I just used controller 31 as an example, the same thing happens with other controllers.
    Like I said this is a very good feature once it's working correctly. It would be even better if we could create shortcuts to these huds on the main menu. Having the option to start logging the fields within the HUD would be really nice too.
  2. Likes Uwe, Eric, jocamero liked this post
  3. #2
    Feb 2016
    Denver, CO, USA
    I've also had issues with the HUD displaying the correct fields or simply no labels.
    +1 for shortcuts
  4. Likes Uwe liked this post
  5. #3
    Alright guys thanks for the report. I will look into it and let you know. Can you confirm that it works as expected if using only one pane?
  6. Likes Uwe, flerp liked this post
  7. #4
    Oct 2015
    Yes, it works correctly when configuring only 1 pane with up to 4 measuring blocks.
  8. Likes Eric, Uwe liked this post
  9. #5
    Feb 2016
    Denver, CO, USA
    I'm still having this issue. Was it ever addressed? Is there an update I can apply to fix it?
  10. #6
    Aug 2018
    I can confirm that this issue still exists with version 0.4435 of VCDS Mobile.
    I try to configure two blocks of Measuring Values, side-by-side with an individually different set of values to display. In any case, after saving and displaying, all values configured in the first block, except the first one, bleed over to the next block where only the last one is shown as originally configured.
  11. Likes Uwe liked this post
  12. #7
    Feb 2016
    Denver, CO, USA
    There must still be a bug related to this. After the latest update I applied last week, none of my previously saved measuring values would work and I was required to recreate them all. Working once again, but this should probably be looked at.
  13. Likes Uwe, henbo liked this post
  14. #8
    I made some fixes for live data hud, and a new build is on alpha, V0.4443. jocamero and henbo, I flipped both of you guys to the alpha channel. If you want to test the new build, go ahead and download the updates and try out the live data hud and feel free to report back here.
  15. Likes jocamero, Eric, Uwe, henbo liked this post
  16. #9
    Aug 2018
    Sorry for the late reply, I didn't check back for a while and only today found a little time for digging thru.
    So, there are no more duplicates between 2 HUD Measuring Values blocks (2x4), but each block shows some (1-2) "random" values. It's not really random (the same for every attempt), but its not one of the expected (configured) values. Apparently its not even a value for the same controller.
    Config
    01 - Engine, MVB, selection
    01 - Engine, HUD, after selection
    01 - Engine, HUD, result
    17 - Instruments, MVB, selection
    17 - Instruments, MVB, result
    Also, some time ago we discussed using the URL of the HUD as a bookmark for quick access. The HUD is empty if I do that. I would guess the session to the controller needs to be created before the HUD is shown, so it cannot possible work with a single URL.
  17. Likes Uwe, Dana liked this post
  18. #10
    Aug 2015
    I tried to use HUD and the values displayed do not match the values from advanced measuring blocks. I know I can measuring blocks but it would be nice to have a set of value pre-selected for the HUD instead of searching every time. Is there something I need to refresh or delete to get the dataset's in sync?
    I'm on
    CB: 0.4502
    FW: 0.256
    CFB:0.10
    BL: 0.28
    DS: 60000057
    Trying to log engine 01it's an old log but the vin is correct.
    #hndoc:?docid=00002882&xt=hnh:1E5EEEDE671F7AB9F5BBE10F63A3F1403E0F2BA760417CF3F1A4031C81D8BAA9
    Sun,Feb,05,2017,10:55:51
    VCDS Mobile 0.4334.0.4
    VIN: WA1DGAFP9DA055175
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
    	 6C 6D 72
    Address 01: Engine  (CTUC4 J623)	Labels: 8R-01.lbl
    	Part No SW: 8R0 907 551 A	HW: 4G0 907 551 A
    	Component: 3.0l V6 TFSI
    	Revision: --H07---
    	Coding: 2A2A0034052601060000
    	Shop #: WSC 06208 000 00000
    	ASAM Dataset: EV_ECM30TFS0218R0907551A 001002
    	ROD: EV_ECM30TFS0218K5907551E.rod
    	VCID: 362FB5DB315FF5884C1F549B2F-8063
    No fault codes found.
    Address 02: Auto Trans  (J217)	Labels: 8R-02.lbl
    	Part No SW: 8R0 927 158 AM	HW: 0BK 927 156 AM
    	Component: 0BK 30TFSIUSA H16 1003
    	Revision: --H16---
    	Coding: 000002
    	ASAM Dataset: EV_TCMAL551211 002020
    	ROD: EV_TCMAL551211_AU48.rod
    	VCID: 88538B238B2B33786E53DA7305-80DD
    Address 03: ABS Brakes  (J104)	Labels: None
    	Part No SW: 8R0 907 379 AL	HW: 8R0 907 379 AL
    	Component: ESP8 quattro  H09 0040
    	Revision: --------
    	Coding: 191D1C03
    	Shop #: WSC 06335 123 12345
    	VCID: 8A57B12B952759687867F06BEB-80DF
    Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
    	Part No SW: 8K0 907 064 GP	HW: 8K0 907 064 FP
    	Coding: 0DA54040000000000000
    	Shop #: WSC 06335 000 00000
    	VCID: 844B9F13B7030F18022BAE2359-80D1
    	Subsystem 1 - 	Part No SW: 8K0-905-852-E
    Address 08: Auto HVAC  (J255)	Labels: 8K-08.clb
    	Part No SW: 8K1 820 043 T	HW: 8K1 820 043 T
    	Revision: C1000000
    	Coding: 6621228000
    	VCID: 3935BEE7004102F0A13D77BF06-806C
    Address 09: Cent. Elect.  (J519)	Labels: 8K0-907-063.clb
    	Part No SW: 8K0 907 063 DH	HW: 8K0 907 063 DH
    	Revision: 08016001
    	Coding: 26000095813CAFE00201480300003D0D4F9C4708A6090321000008004000030100000034000000
    	VCID: 78B37BE37BCBDBF89EB32AB3F5-802D
    	Subsystem 1 - 	Part No SW: 8R1-955-119-A	Labels: 1Kx-955-119.clb
    	Component: WWS416 121210H11 0050
    	Coding: 01DD13
    	Subsystem 2 - 	Part No SW: 8U0-955-559-B	Labels: 8U0-955-559.clb
    	Component: G397_RLFS    H06 0002
    	Coding: 02005C
    	Subsystem 3 - 	Part No SW: 8K0-941-531-AS
    	Component: E1 - LDS     H03 0031
    	Subsystem 4 - 	Part No SW: 4G0-907-410-A
    	Component: USHL4.2      H30 0030
    	Subsystem 5 - 	Part No SW: 4H0-907-658
    	Component: AQ_Hum_SensorH03 0003
    Address 15: Airbags  (J234)	Labels: 8R0-959-655.clb
    	Part No SW: 8R0 959 655 F	HW: 8R0 959 655 F
    	Coding: 303634313432303030304A55304C38523053
    	ROD: EV_AirbaAU10SMEAU416.rod
    	VCID: 47D1C81F46B57C0027C9114770-8012
    	Subsystem 1 - 	Part No SW: 8R0-959-339-A
    	Component: BF-Gewichtss.H02 0040
    	Serial Number: 5810000R120000BKTBªª
    	Subsystem 2 - 	Serial Number: 6334MSME7435280ACBªª
    	Subsystem 3 - 	Serial Number: 6344MSME754412726Bªª
    	Subsystem 4 - 	Serial Number: 6352QSME52281F4AOBªª
    	Subsystem 5 - 	Serial Number: 6362QSME76281566JBªª
    	Subsystem 6 - 	Serial Number: 63732SME5F2557566Bªª
    	Subsystem 7 - 	Serial Number: 63832SME5F25426C8Bªª
    Address 16: Steering wheel  (J527)	Labels: 8K0-953-568.clb
    	Part No SW: 8K0 953 568 L	HW: 8K0 953 568 L
    	Revision: --------
    	Coding: 000037
    	VCID: 43C9DC0F728D4820FBA1E53784-8016
    	Subsystem 1 - 	Component: E221 - MFL   H03 0004
    Address 17: Instruments  (J285)	Labels: 8R0-920-xxx-17.clb
    	Part No SW: 8R0 920 980 T	HW: 8R0 920 980 T
    	Revision: 00000000
    	Coding: 83FF22000300D705020201
    	VCID: 4AD7F12B55A7996838E7306B2B-801F
    Address 19: CAN Gateway  (J533)	Labels: 8T0-907-468.clb
    	Part No SW: 8R0 907 468 N	HW: 8R0 907 468 C
    	Component: GW-BEM 4CAN-M H11 0055
    	Revision: 1Y060027
    	Coding: 80CF03FF00
    	Subsystem 1 - 	Part No SW: 8R0-915-181
    	Component: J367-BDM     H07 0141
    Address 36: Seat Mem. Drvr  (J136)	Labels: None
    	Part No SW: 8R0 959 760 D	HW: 8R0 959 760 B
    	Component: MEM-FS        H07 0076
    	Revision: AA000000
    	Coding: 01581B00000000000000
    	VCID: 42C7D90B6D974128F097D80BB3-8017
    Address 42: Door Elect, Driver  (J386)	Labels: 8K0-959-793.clb
    	Part No SW: 8K0 959 793 R	HW: 8K0 959 793 P
    	Component: TSG FA        H02 0506
    	Revision:
    	Coding: 011D13205E00440004
    	VCID: 4FE1E03FAEC5BC406F1969A7E8-801A
    Address 44: Steering Assist  (J500)	Labels: 8K0-909-144.clb
    	Part No SW: 8R0 909 144 F	HW: 8R0 909 144 B
    	Revision: 00001000
    	Coding: 100000010001
    	Shop #: WSC 42520 123 104857
    	ROD: N/A
    	VCID: 3B39A4EF0A7D28E0B3518DD7EC-806E
    	No ASAM data for: "EV_RCEPSAU48X"
    Address 46: Central Conv.  (J393)	Labels: 8K0-907-064-46.clb
    	Coding: 01260E3A30FA709787B0053602040007
    	Shop #: WSC 06334 123 12345
    	Subsystem 1 - 	Part No SW: 8K0-959-719-B
    	Component: GTO BF       H01 0080
    	Subsystem 2 - 	Part No SW: 1K0-951-605-C
    	Component: LIN BACKUP HOH05 1501
    	Subsystem 3 - 	Part No SW: 8R0-959-591-A
    	Component: J245EE20SKB13H05 0220
    	Subsystem 4 - 	Part No SW: 8R0-959-591-A
    	Component: J394EE20SKB13H05 0220
    Address 47: Sound System  (J525)	Labels: 8T0-035-223-BOM.clb
    	Part No SW: 8T1 035 223 A	HW: 8T1 035 223 A
    	Revision: 00005001
    	Shop #: WSC 00000 000
    	VCID: 2D1D9AB7C409AE503DC5F30FA2-8078
    Address 52: Door Elect, Pass.  (J387)	Labels: 8K0-959-792.clb
    	Part No SW: 8K0 959 792 R	HW: 8K0 959 792 P
    	Component: TSG BF        H02 0506
    	Revision:
    	VCID: 4EDFFD3BA9CFB548640F5CBB17-801B
    Address 53: Parking Brake  (----)	Labels: 8K0-907-801-V2.clb
    	Part No SW: 8K0 907 801 L	HW: 8K0 907 801 J
    	Revision: --------
    	ROD: N/A
    	VCID: 3833BBE33B4B03F85E336AB335-806D
    	No ASAM data for: "EV_ParkiBrake"
    Address 56: Radio  (R)	Labels: None
    	Part No SW: 4G0 035 082 E	HW: 4G0 035 082
    	Component: Radio U SIRIU H60 0121
    	Revision: AB001007
    	Coding: 020007010000000001
    	VCID: 2207798B8DD761289057788B53-8077
    Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
    	Part No SW: 8R1 035 746 C	HW: 8R1 035 746 B
    	Component: H-BNT-NA      H44 0624
    	Revision: --------
    	Coding: 1C0200060105E1EF47029B5C00000403140000000000000002
    	VCID: 3731B8DF365514805729618720-8062
    	Subsystem 1 - 	Part No SW: 8R0-060-884-BAø
    	Component: NAR 2013     0703
    	Subsystem 2 - 	Part No SW: 8R0-919-604-A
    	Component: DU7 High     H42 0104
    	Subsystem 3 - 	Part No SW: 8T0-919-611-L
    	Component: E0380 BedientH02 0030
    	Subsystem 4 - 	Part No SW: 8R0-060-961-E
    	Component: CD-Database  4949
    Address 62: Door, Rear Left  (J388)	Labels: 8K0-959-795.clb
    	Part No SW: 8K0 959 795 G	HW: 8K0 959 795 D
    	Revision:
    	Coding: 010C13204000240004
    	VCID: 46CFC51B41BF7D08DCBF045B7F-8013
    Address 6C: Back-up Cam.	Labels: 8T0-907-441.clb
    	Part No SW: 8R0 907 441 A	HW: 4L0907441B
    	Component: J772__Rearview       0040
    	Revision: --H07---	Serial Number: 525PA8-J2YA23J
    	Coding: 1020010
    	VCID: 342B8FD327237F98720B3E6349-8061
    Address 6D: Trunk Elect.  (J605)	Labels: None
    	Part No SW: 8R0 827 851 B	HW: 8R0 827 851 B
    	Component: J605  Master  H52 0330
    	Revision: --------
    	VCID: 3B39A4EF0A7D30E0B3518DD7EC-806E
    	Subsystem 1 - 	Part No SW: 8R0-827-852-B
    	Component: J756  Slave  H52 0330
    Address 72: Door, Rear Right  (J389)	Labels: 8K0-959-795.clb
    	Revision:
