VW Passat Alltrack 2013 170 DSG Turbo noise.
nsangste
Scotland
C?ID=136094
My car makes a funny kind of chirping sound when the turbo is spooling changes with boost pressure, its kind of like the vanes are hitting something.
Also when car is cold there is like a pluffing sound from the exhaust from one of the cylinders, or it sounds like that.
Car done about 70K full service history.
Another thing just happened this last week when towing caravan, when car is under load going up a hill, and its done it twice now, it goes into Limp mode.
Which is quite tricky with DSG, as you have to pull over and stop car in N or park, then its fine again.
Does not do it when not towing.
Also is there a way to get the LED DRL to stop throwing up a bulb warning!!!
Thanks for your help.
Neil Sangster
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4F 52 53
          56 61 62 65 72
VIN: WVWZZZ3CZEE028207   Mileage: 113570km-70569miles
Address 01: Engine (J623-CFGC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 RF    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   X28 4779
   Revision: 41X28---    Serial number: 00000000000000
   Coding: 001D0012042701080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906018RF 003003
   ROD: EV_ECM20TDI01103L906018RE.rod
   VCID: 7F071605E62B29B2A2-802A
5171 - Boost Pressure Regulation
          P0299 00 [096] - Control Range Not Reached
                    Mileage: 113107 km
                    Date: 2019.03.29
                    Time: 18:42:45
                    Engine speed: 1999.50 /min
                    Normed load value: 72.2 %
                    Vehicle speed: 76 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 14.680 V
                    Charge air pressure specified value: 2757 hPa
                    Charge air pressure: actual value: 2346 hPa
                    Air mass: actual value (mg/stroke): 948.3 mg/stroke
                    EGR Solen.val.: actual value: 99.90 %
                    Throttle valve adapter: actual value: 99.98 %
                    Charge Pressure Actuator: acknowledgment: 83.68 %
                    Mean injection quantity: 54.48 mg/stroke
   Part No SW: 02E 300 016 H    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4011
   Revision: 05652104    Serial number: 00001306132600
   Coding: 0000024
   Shop #: WSC 05311 000 00000
   VCID: 1933D89DD04FE7823C-804C
   Part No SW: 3AA 614 109 AK    HW: 3AA 614 109 AK
   Component: J104   C2 450M V4DF 0055
   Revision: --H07---    Serial number: 00000006974948
   Coding: 0793361
   VCID: 76E9F321011168FAF1-8022
   Part No SW: 3AA 907 044 BA    HW: 3AA 907 044 BA
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 061400C803
   Shop #: WSC 00015 115 00000
   VCID: 70E5C539AB7546CA2B-8024
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0474
   Revision: BD422001
   Coding: 0008000000000000049800801400816403510088426D81606480C7200041
   VCID: 499348DDE06F57024C-801C
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 13061  26  0612
   Coding: 00B795
   Component: RLS 170613 05  54  0403
   Coding: 0230ED
                    Fault Status: 00101010
                    Fault Frequency: 56
                    Reset counter: 6
                    Mileage: 106714 km
                    Date: 2018.11.29
                    Time: 07:23:40
                    Voltage: 11.50 V
                    Fault Frequency: 49
                    Reset counter: 6
                    Mileage: 106714 km
                    Date: 2018.11.29
                    Time: 07:23:40
                    Voltage: 11.50 V
03789 - Terminal 75 Limp Mode Active
            000 -  -  - Intermittent
                    Reset counter: 7
                    Mileage: 113293 km
                    Date: 2013.08.21
                    Time: 14:12:17
                    Voltage: 13.20 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28261317202785
   Coding: 308105
   Shop #: WSC 99999 123 12345
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3F875605A6ABE9B2E2-806A
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__108 VW10 HI   2118
   Revision: 26019000    Serial number: 003L7PCTUS5V
   Coding: 0012344
   VCID: 7CFDE1093F3D32AA87-8028
   Subsystem 1 - Serial number: 6332MTS623061553
   Subsystem 2 - Serial number: 6342MTS676051543
   Subsystem 3 - Serial number: 6351HTS67ROD2CKJ
   Subsystem 4 - Serial number: 6361HTS6E3V22CKR
   Part No SW: 3C9 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010042    Serial number: 20130621201492
   Coding: 1982250000
   VCID: 6FE7C645B64B593232-803A
   Coding: E20000
   Part No SW: 3AA 920 980 Q    HW: 3AA 920 980 Q
   Component: KOMBI         H04 0611
   Coding: 451F00
   Shop #: WSC 05314 115 00000
   VCID: 42815FF1D559845A8D-8016
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 070613F1001802
   Coding: 462007
   Shop #: WSC 05314 000 00000
   VCID: 7CFDE109FF3D32AA87-8028
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 468943E13171B87AA1-8012
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         043 0407
   Shop #: WSC 11391 000 1048576
   VCID: 38753D194B85DE8A23-806C
   Revision: A1001003    Serial number: 7664970286
   Coding: 020100
   VCID: 2B5F12554AD365125E-807E
   Part No SW: 3C8 035 279 M    HW: 3C8 035 279 M
   Component: RNS315-EU   H70 0407
   Serial number: VWZAZ2N0373853
   Coding: 040004410400110000019002
   Shop #: WSC 00015 115 12345
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 356B342D949723E238-8060
   Component: EUR_W_V9  0069
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0007191618
   Coding: 0202B7
   Shop #: WSC 05311 115 00000
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0503
   Serial number: 00000003551492
   Coding: 010290
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 197    3501
   Revision: 00H22000
   VCID: 3973381D708FC782DC-806C
   Component:    KSG PQ47 ELV 043 0645
   Coding: 0191020052830E76340494157C085FCE105804
   Component: EZE_2         H56 1642
   Coding: 00000008
   VCID: 6FE7C645BE4B593232-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0007161580
   Coding: 0202B6
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 36693321899128FA31-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0503
   Serial number: 00000003554885
   Coding: 010290
   Revision:   H19       Serial number: 00000001175083
   Coding: 0022167
   VCID: 36693321419128FA31-8062
   Component: Batt.regelung H56 1642
   Coding: 030F1859
   VCID: 71E3C03DA87F4FC224-8024
   Component: J367-BDM  H07 0180
   Serial number: 30174D21371491633351
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000227804
   ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod VCID: 356B342D949723E238-8060 No fault code found. End-------------------------(Elapsed Time: 03:30)--------------------------
DrPeter
16.4905° S, 151.7375° W
Thanks for including your Auto-Scan and welcome to the Ross-Tech forum. We have a Ross-Tech wiki page for the fault code P0299, see link below.
P0299- Boost Pressure Regulation: Control Range Not Reached
Maybe there is a possible turbo or turbo control concern? .. I would check for loose parts around the turbo when cold, also check for potential boost leaks too, split hoses etc.
Maybe make a video with sound so we can hear what you are hearing :)
Hope this helps,
drpeter
nsangste
Scotland
C?ID=136094
Thanks for the info, I have been reeding into the P0299 code, and I have some things to check.
I was more worried regarding low MPG and sound from Turbo, Car on motorway at 70mph unladen gets about 30mpg, which i think is low.
Car has been professionally mapped to 225HP, but this has made MPG better slightly not worse.
And car had this issues before map, only got map really for torque for towing caravan.
I will try to get a recording of the noise when i return home from business trip
Regards, Neil
nsangste
Scotland
C?ID=136094
Also can you tell if this car has had the recal for the emisions done to it, As i understand it this is not very good if it has.
Thanks in advance,
Neil
DrPeter
I was able to fing this website from Volkswagen, Emissions Information, however your VIN does not seem to display anything, just this message:
Sorry. We cannot find the vehicle registration you entered. If you’re sure you’ve entered it correctly, get in touch by clicking ‘Contact Volkswagen’.
We have this page in the states, VW Emissions Modification Lookup , I have not seen one for the rest of world market.
Volkswagen of North America also has this page, Recall / Service Campaign Lookup
You may have to contact the manufacture directly.
Hope this helps,
drpeter
Vehicle Identification No.WVWZZZ3CZEE028207
ModelPassat Alltrack
4Motion/BlueMotion
PA
Date of production08.07.2013
Model year2014
Sales type365C9R
Engine CodeCFGC
Transmission CodePQW
Emission standard7MJEmission standard EU5 plus
Component: R4 2,0L EDC X28 4779 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware updates 9979 of higher right?
That looks like a "fix/fail" update. If it is, I personally wouldn't do it.
