Hello fellows. Just got Engine Check light on. VCDS saying that
"18193 - Temperature Sender for Particulate Sensor
P24C6 00 [175] - Electrical Malfunction
MIL ON - Confirmed - Tested Since Memory Clear" (full scan below)
Didn't fine any "sender". ElsaWin gave Temp Sensor for particulate filter.
But on picture there are two sensors.
Is there any way I can know exactly which is failed (if it is) or using VCDS can I get part number?
Thank you.
Thank you.
Tuesday,02,April,2019,18:04:29:01286
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WA1DMCFP6FA0XXXXXX License Plate:
Mileage: 36790km-22860mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
6D 72 AC
VIN: WA1DMCFP6FA036400 Mileage: 36790km-22860miles
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 401 AC HW: 4G0 907 401 E
Component: 3.0TDI FSA X14 0008
Revision: 58X14---
Coding: 2A2A4012052603050000
ASAM Dataset: EV_ECM30TDI0118K5907401AC 002008
ROD: EV_ECM30TDI0118K5907401AC_002.rod
VCID: 71BFD6D791294AEF613-8024
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
U1113 00 [032] - -
U1113 00 [032] - -
Mileage: 36745 km
Date: 2019.04.01
Time: 16:46:58
Engine speed: 1552.00 /min
Vehicle speed: 33 km/h
Coolant temperature: 88 °C
Intake air temperature: 8 °C
Voltage terminal 30: 14.560 V
Exh u PP Ds Batt Snsr Raw: 14.4 V
Com i PP Ds IDE Raw: 0.000 µA
Exh i PP Ds IDE Shnt Circ: 0.0 µA
Exh st PP Ds St Ma-Bits 0-7: 0
Particle sensor: surface temperature: 949.98 °C
Particle sensor: heat voltage: 0.00 V
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H18 1007
Revision: --H18---
Coding: 000001
VCID: 4BC3643FD345403F3BF-801E
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 23150C03
Shop #: WSC 06335 000 00000
VCID: 117FB657F1692AEF013-8044
Part No SW: 8K0 907 064 JP HW: 8K0 907 064 JP
Component: BCM2 2.0 H14 0650
Coding: 0DA54040000000000000
VCID: 074B980F8F2D645FDF7-8052
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000134947013
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01200820142082
Coding: 3621228080
VCID: 77ABE8CFFFCD14DFAF7-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000868793001
Coding: 26000096863CAFE00100488300003D0D0F9CC708A6090221000008004400030100000034000000
VCID: 78A9EBF3F2D31BA7A6D-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140717 H12 0050
Serial number: 90243014140703141916
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 23082962
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002307141332
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z009A5F31
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: FF288B37000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12CZ1I
Coding: 30373431343238313230554A304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC16723D64B4707325-8018
Serial number: 6334MSME483E262CO
Serial number: 6344MSME483A507DO
Serial number: 6352QSME3C433068G
Serial number: 6362QSME45434F78S
Serial number: 63732SME35434F72%
Serial number: 63832SME3243435E
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NH1000NR
Coding: 000037
VCID: 48C95B33C2B3AB2716D-801C
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 T HW: 8R0 920 930 T
Component: KOMBIINSTR. H35 0564
Revision: 00300000 Serial number: ZD456FN8F
Coding: 8BA6220002010008020000
VCID: 45D75207F5A1B64FEDB-8010
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y147200C5F
Coding: 80CF07FF00
VCID: 4ACD613BDCBF5937009-801E
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 3552144103
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 14210001707011200181
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000113924111
Coding: 01581B00000000000000
VCID: 42DD491BE48F8177C89-8016
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000112231608
Coding: 011D13205E00440004
VCID: 4FFB702F27DD7C1F577-801A
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0013861819
Coding: 100000010001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: 3FDB40EF97FDEC9FA77-806A
Revision: 00002001 Serial number: 0344262116
Coding: 0126023A20FA709584A0053600040047
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000871569
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 15
Reset counter: 236
Mileage: 30116 km
Date: 2018.10.09
Time: 11:33:38
02616 - Fuel Tank Cap; Unlock
Reset counter: 232
Mileage: 30116 km
Date: 2018.10.09
Time: 12:01:47
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000113961286
VCID: 4EC56D2B20D775175C1-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000488820
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D31FB8CDFC9B7909-806E
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156H$0E8051537
Coding: 020007020100000001
VCID: 2411EF831EDBAF47DA5-8070
Part No SW: 8R1 035 664 F HW: 8R1 035 664 D
Component: H-BN-NA H41 0812
Revision: -------- Serial number: 203H%0EB008785
Coding: 16020006000581EF45028B4E00000403F40000020000000000
VCID: 392F2EF78959C2AF993-806C
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130GK0E3102166
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001945822
Component: CD-Database 5950
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000114459250
Coding: 010C13204000240004
VCID: 46D5550BC8A7BD57E41-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J46A0SS
Coding: 1020010
VCID: 34311FC3A23B3FC74A5-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D273AE79D71FE8FB5B-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000114451651
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 142160244
ROD: EV_RDCMA00100_008.rod
VCID: 2D070AA74D916E0F05B-8078
End----(Elapsed Time: 02:03, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 8K5 907 401 AC HW: 4G0 907 401 E
Component and/or Version: 3.0TDI FSA X14 0008
Software Coding: 2A2A4012052603050000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_ECM30TDI0118K5907401AC 002008 (AU48)
U1113 00 [032] - -
U1113 00 [032] - -
U1113 00 [032] - -
U1113 00 [032] - -
Mileage: 36745 km
Date: 2019.04.01
Time: 16:46:58
U1113 00 [032] - -
U1113 00 [032] - -
U1113 00 [032] - -
U1113 00 [032] - -
Mileage: 36745 km
Date: 2019.04.01
Time: 16:46:58
Address 01: DTCs cleared
Address 46: DTCs cleared
