Results 1 to 9 of 9
Thread: Relative compression test, make the car crank but not start
    New User
    Apr 2019
    Norway
    I have a 2005 Touareg with R5 engine and I want to perform a relative compression test. Therefore I need to make the car crank but not start. Is it possible to do something in VCDS to prohibit the car from starting?
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello
    This is the "new user" section.
    What's about a little hello from TregR5?
    After that, please get verified and send a complete Auto-Scan in
    https://forums.ross-tech.com/forumdi...Repair-Support
    Thank you
    -Wolfgang
    Drive more talk less
    New User
    Apr 2019
    Norway
    Oh hello, sorry, was maybe a little fast posting my question without any introduction. A little info about me: I have cars and motorbikes as a hobby and are interested in car/motorcycle diagnostics. I have now put my VCDS serial number, in my profile. I dont need to scan my car, but are interested if VCDS are able to prohibit my car from starting when cranking it. Do you know if it is possible and if so, what the procedure is? I am going to take a relative compression test with my oscilloscope so therefore i need to crank for some seconds. Thanks.
    Nov 2015
    The requirement for an autoscan is so that people know what hardware and such related stuff your particular car has. One answer for one person may not be relevant to another person with a similar car.
    New User
    Apr 2019
    Norway
    Thanks for the information. I will do the auto scan tomorrow and post the result.
    Unplug crank/cam sensors or unplug the PD injector loom where it goes into the cylinder head - it will throw fault codes but you have VCDS to remove them after.
  8. Likes Uwe liked this post
    New User
    Apr 2019
    Norway
    I got a bit delayed with the job but now I have performed it.
    I did unplug the PD injector loom and was then able to crank for as long as needed, thank you! The concern I have is a P0304 fault code which was the initial reason I wanted to perform a relative compression test. Is this cylinder no.4 or is it cylinder no.4 in the firing sequence (which is cylinder no.5)? Does anyone have an idea what might set this fault code? The results from the relative compression test seems ok, but I have not performed it a lot of times. I notice that the engine starts vibrating, which off course seems natural since one of the cylinders does not fire properly, when the fault code is set. It seems that this happens when engine are "semi warm", not at cold state and not at fully warm state. Attached is the report from the auto-scan.
    Sunday,12,May,2019,16:26:23:46421
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVGZZZ7LZ5D001609   License Plate:
    Mileage: 196740km-122248mi   Repair Order:
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ5D001609   Mileage: 196740km-122248miles
       Part No SW: 070 997 016 E    HW: 028 101 125 8
       Component: R5 2,5L EDC G001AG  9769
       Revision: 12345678    Serial number: VWZ3Z0D1205352
       Coding: 0011175
       Shop #: WSC 31414 000 00000
       VCID: 1C37968EDC1E92AA21-515E
    16502 - Engine Coolant Temp. Sensor (G62)
                P0118 - 000 - Signal too High - Intermittent
                        RPM: 1554 /min
                        Torque: 202.5 Nm
                        Speed: 44.0 km/h
                        Load: 31.0 %
                        Voltage: 14.36 V
                        Bin. Bits: 00001000
                        Temperature: 47.7°C
                        Temperature: 36.9°C
    16688 - Cylinder 4
                P0304 - 000 - Misfire Detected
                        RPM: 756 /min
                        Torque: 102.5 Nm
                        Voltage: 13.91 V
                        Inj. Quantity: 2.96 mg/str
                        Temperature: 51.3°C
                        (no units): 0.0
    Readiness: 0 0 0 X 1
       Part No: 09D 927 750 BP
       Component: AL 750 6A           0560
       Coding: 0004136
       VCID: 7DF1BB0A27443BA2B6-515E
       Part No SW: 3D0 909 135 J    HW: 5WK 470 21
       Component:    Kessy            6400
       Coding: 0000232
       VCID: 2C57464E8CBE622A51-515E
       Subsystem 1 - Part No: 4E0 905 852 D
       Component: ELV                 1834
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 H
       Component: CLIMAtronic R/L   X 3716
       Coding: 0000030
       VCID: 3561632A5FF423E23E-5140
    02193 - Supply Voltage for Regulator for Fresh Air Blower
                010 - Open or Short to Plus
    00353 - Function Return Message from Fresh Air Blower Regulator
                        Voltage: 14.40 V
                        Voltage: 11.83 V
                        Voltage: 0.00 V
                        Voltage: 14.00 V
                014 - Defective
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 K
       Component:                     2703
       Coding: 0103677
       Shop #: WSC 00795 218 05193
       VCID: 44870EEE042E8A6AB9-515E
       Part No: 3D0 909 601 E
       Component: 0B Airbag 8.4E+ H10 0951
       Coding: 0012354
       VCID: 2541B36AEF5453628E-5140
       Part No: 7L6 953 549 D
       Component: Lenksäulenmodul     3301
       Coding: 0000031
       VCID: 408F02FE1036964A9D-5140
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 880 M
       Component: KOMBIINSTRUMENT RB8 2935
       Coding: 0005111
       Shop #: WSC 00795 218 92423
       VCID: 418907FA1B3C9F4292-5140
    Address 18: Aux. Heat        Labels: 7L6-819-008.clb
       Part No: 7L6 815 071 B
       Component: Standheizung  E1MAC 0235
       Coding: 0000000
       VCID: 3169573AAB9C0FC262-5140
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70EF923E601646CA2D-5140
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F0D41022D4829B2A4-5140
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       Coding: 0000003
       VCID: 66C3F46652D2987A47-5140
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       VCID: 3663642642F228FA37-5140
       Part No: 7L0 959 760
       Component: Sitzverstellung     0702
       VCID: 77FDA922057811F2EC-5140
    Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
       Part No: 7L6 919 887 B
       Component:      Navigation     0629
       VCID: 458113EA0F14B362AE-5140
       Part No: 3D0 909 158
       Coding: 0000003
       VCID: 67DDF96255D881727C-5140
       Part No: 7L0 959 933 G
       Component: 1N HSG              3213
       Coding: 0000065
       Shop #: WSC 00490 218 186825
       VCID: 408F02FE1036964A9D-4AE8
       Subsystem 1 - Part No: 7L0 959 701 A
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 A
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703
       Subsystem 4 - Part No: 7L0 959 704
       Subsystem 5 - Part No: 7L0 907 719
       Component:    Neigungssensor   0020
       Subsystem 6 - Part No: 7L6 951 171
       Component: A  Innenraumsensor  0019
    Address 56: Radio        Labels: 7L6-035-186-CD.lbl
       Part No: 7L6 035 186 A
       Component:        Radio        0629
       Coding: 0007447
    00878 - Connection to Speaker Front Left
    00881 - Connection to Speaker Rear Right
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
       Part No: 7L0 955 119 F
       Component: Front Wiper         2416
       Coding: 0000004
       Shop #: WSC 31414 000 376832
       VCID: 377D692245F8D1F22C-515E
    Address 76: Park Assist        Labels: None
       Part No: 7L0 919 283 E
       Component: 0E Einparkhilfe     0907
       VCID: 387F6A1E48E6DE8A25-515E
    Address 77: Telephone        Labels: Redir Fail!
       Part No: 7L6 035 729 E
       Component: CIB PAH  HW 202 SW  0307
       Coding: 0000372
    End-------------------------(Elapsed Time: 08:22)--------------------------
  10. #8
    I would suggest fixing the G62 fault first and then see again whether the misfire is still present.
  11. Likes Uwe liked this post
  12. #9
    New User
    Apr 2019
    Norway
    I am working on the G62 now, the sensor seems to give a stable resistance and it is increasing with decreasing temperatur. Anyone know how likely it could it be that the sensor itself could be intermitently working? I am also very open for suggestions regarding the misfire since I suspect that these two faults codes are separate issues, even though I think it is a good idea to focus on the G62. Thank you.
