2016 Tiguan w/2017 Tiguan Radio Head - Bluetooth Inoperative
rcrowell
C?ID=273550
Hi All,
I'm new to the site and hoping for help to provide any long coding tips to allow my replacement radio head to enable blueTooth, then set ultimately up AppleCarplay.
I have a 2016 Tiguan 4Motion S that had a standard radio head.
I purchased a radio head from a totalled 2017 Tiguan that had a larger screen, navigation and Apple CarPlay, as I assumed that the installation of a factory radio head unit would be "plug & play".
Vehicle and radio head details:
2016 Tiguan 4 Motion S – VIN WVGBV7AX3GW576621
Radio head unit: from 2017 Tiguan – VIN WVGAV7AX3HK013962
head unit s/n – VWZAZ2S0600954 – MIB STD2 PQ+/NAV
Problem details:
When I first installed the 2017 radio – the Bluetooth phone paired and was functional; backup camera worked; radio was in “safe mode”; no AppleCarplay.
Dealer was required to reset the radio out of "safe mode".
After dealer reset work: the radio receiver functions, backup camera works, but the phone is no longer recognized and Bluetooth is not functional.
Tried the “hard reset” of radio – "key on power, engine off, hold radio power button down until VW symbol appears – Bluetooth still not recognized."
I spoke with a VW Tech friend (who is out of state & couldn't look at car) who suggested that the 5F Module may not have been functioning correctly & needed software update"
I also figure that I'll need another USB connection to the head unit for AppleCarplay to operate.
I hope that this download provides sufficient details for troubleshooting and recommended next steps:
Saturday,27,April,2019,14:51:53:09951
VCDS Version: 18.9.1.0 (x64)
VIN: WVGBV7AX3GW576621   License Plate: 6BTX80_MA
Mileage: 47420km-29465mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 42 44 46 4C 52 53 5F
          62 72
VIN: WVGBV7AX3GW576621   Mileage: 47420km-29465miles
   Part No SW: 06J 906 027 JP    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 1335
   Revision: P3H08---    Serial number:
   Coding: 0423010A190F0160
   VCID: 022570AE5D29CE5ACB-8056
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2627
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 073361BA760BEB729C-8052
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VDC2 0021
   Revision: --H07---    Serial number: 00000009078976
   Coding: 0005161
   VCID: 78D112460BF5948AE5-802C
   Revision: 00092000    Serial number: 0389578479
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW36.rod
   VCID: 3753D17A8E6B5BF22C-8062
   Part No SW: 561 907 426 G    HW: 561 907 426 G
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010001002
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1F6319DA069B03B2C4-804A
   Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
   Component: BCM PQ35 B    122 0183
   Revision: BG122001
   Coding: EF1A0A1B80232EC4008800C11400044448510086566D8DF064800000A040
   VCID: 3D5FC352A45771A2F6-8068
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 011215  24  0664
   Coding: 009795
   Component: RLS 141215 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
   Component: J234__005 VW10 HI   5418
   Revision: 36023000    Serial number: 003MAPRJW86N
   Coding: 0012341
   VCID: 7DDF035224D7B1A2B6-8028
   Subsystem 1 - Part No: 5N0 959 339 B
   Component: BF-Gewichtsens. 003 0001
   Subsystem 2 - Serial number: 0000000000PQE3
   Subsystem 3 - Serial number: 0019.10.150000300000650044ÿ†63
   Subsystem 4 - Serial number: 650044ÿ†6332MTS6864331252ÿ†63
   Subsystem 5 - Serial number: 331252ÿ†6342MTS6296731256ÿ†63
   Subsystem 6 - Serial number: 731256ÿ†6351HTS6J5ED4EKJVÿ†63
   Subsystem 7 - Serial number: D4EKJVÿ†6361HTS6VCM53EKJ7ÿ†63
   Subsystem 8 - Serial number: 53EKJ7ÿ†63727TS6JT9B3EKJ/ÿ†63
   Subsystem 9 - Serial number: B3EKJ/ÿ†63827TS6OCLA3EKR5ÿ
   Subsystem 10 - Serial number: A3EKR5ÿ
   Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20151215200213
   Coding: 1102140000
   VCID: 78D11246C3F5948AE5-802C
   Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0933045
   Coding: 820000
   Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
   Component: KOMBI         H04 1008
   Coding: 211F010000
   VCID: 3D5FC352AC5771A2F6-8068
   Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1663
   Revision:   H57       Serial number: 141115F1001566
   Coding: 356022
   VCID: 022570AE9D29CE5ACB-8056
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00016.11.15
   Coding: 0001
   VCID: 528580EE05C99EDA3B-8006
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: 6AF5380E8D59361A63-803E
   Revision: 00000000    Serial number: 15000260702002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041EA666B058CCA6D-8064
   Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0601
   Revision: 13100010    Serial number: 0010185509
   Coding: 0004B4
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 3A55C84EBD79469AD3-806E
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009635858
   Coding: 000490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.285 1401
   Revision: 1BH04841    Serial number: 00153210176901
   Coding: 0000258
   VCID: 41A7BFA218AF154292-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0010265949
   Coding: 0004B4
   VCID: 3957D742B87F4D82DA-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009648063
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000993370
   Coding: 0026156
   VCID: 3851D2464B75548A25-806C
   Part No SW: 5C0 035 200 B    HW: 5C0 035 200 B
   Component: MU-S-S-US     H31 0359
   Serial number: VWZAZ2S0600954
   Coding: 02130600FF00000011220001001808009F0100D40020010002
   Shop #: WSC 00040 028 00056
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 140946F6FF5D50EA69-8040
13697024 - Component Protection
          U1100 00 [008] - No Basic Setting
                    Reset counter: 198
                    Mileage: 46640 km
                    Date: 2019.04.11
                    Time: 22:23:58
                    Voltage terminal 30: 13.7 V
          B11CF 53 [009] - Deactivated
                    Reset counter: 129
                    Mileage: 46169 km
                    Date: 2019.03.29
                    Time: 00:00:06
                    Voltage terminal 30: 12.4 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Channel selection for satellite radio: 0
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
0009 - Antenna for Satelite Radio
          B10F4 13 [009] - Open Circuit
                    Reset counter: 129
                    Mileage: 46168 km
                    Date: 2019.03.29
                    Time: 13:24:18
                    Voltage terminal 30: 13.5 V
End-------------------------(Elapsed Time: 02:25)--------------------------
Any help is greatly appreciated.
Thanks!
Rich
rcrowell
C?ID=273550
Anybody who can help with 5F coding for radio functionality?
Thanks!
Reset counter: 198
Mileage: 46640 km
Date: 2019.04.11
Time: 22:23:58
You'll need someone able to clear the Component Protection first (such as a VW dealer or workshop with ODIS), that needs access to the VAG cloud servers so cannot be done with VCDS.
siLc
Tallinn, Estonia
C?ID=330192
Did the old radio have Bluetooth?
rcrowell
C?ID=273550
The original radio did have Bluetooth.
When I first installed the new radio, it was in "safe" mode, meaning the radio tuner was locked out. However, the Bluetooth was functional.
I was told by a VW Tech that the radio needed to be unlocked by the dealer for the tuner to work.
I brought the car to a dealer to unlock (clear component protection service(?)), which enabled the tuner to work, but the Bluetooth was then disabled.
I was told that since the tuner works, the operation of the Bluetooth should be able to be "turned on" either by or through the 5F module with long code changes.
