Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: AUDI A1 8X Abs not coded fault
    Verified VCDS User Pnr_coding's Avatar
    Mar 2017
    london
    Hi guys i recently did some work on this audi a1 airbags to be specific, and now i have abs, traction and tyre light on. I didn't do a scan prior to work, well not with my vagcom so don't know what the long coding is, how can i get the right long coding? please help.
    Chassis Type: 8X-AU21 (8U0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 5F
    VIN: WAUZZZ8X6CB243319   Mileage: 27280km-16951miles
    Address 01: Engine (J623-CAVG)       Labels:. 03C-907-309-V1.clb
       Part No SW: 03C 906 027 CF    HW: 03C 906 027 CF
       Component: 1.4l R4/4V TS H08 3064
       Revision: LFH08---    Serial number:
       Coding: 00250012000400000000
       Shop #: WSC 00046 790 00000
       ASAM Dataset: EV_ECM14TSI01103C906027CF 001007
       ROD: EV_ECM14TSI01103C906027CF.rod
       VCID: 6788B2D6CFE0148F3F7-8032
    4650 - Brake Booster Pressure Sensor
              P0557 00 [039] - Short to GND
                        Mileage: 27286 km
                        Date: 2019.03.24
                        Time: 21:50:14
                        Coolant temperature: 78 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 11.968 V
                        Mass flow through throttle valve: 0.0 kg/h
    Readiness: 1110 0101
       Part No SW: 0AM 300 053 G    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 3072
       Revision: 00043014    Serial number: CU501203196852
       Shop #: WSC 00046 000 00000
       VCID: 303A198A363E93372ED-513C
    Address 03: ABS Brakes
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 8X0 820 043 B    HW: 8X0 820 043 B
       Component: Klima 1 Zone  H12 0070
       Serial number: 00000000123049
       Coding: 6420000000
       ASAM Dataset: EV_AirCondiFrontAU210 006035
       ROD: EV_AirCondiFrontAU210_006.rod
       VCID: 33301686CBB8A82F53F-8066
    Address 09: Cent. Elect.
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8X0 959 655 B    HW: 8X0 959 655 B
       Component: Airbag10.41   H05 0009
       Revision: --------    Serial number: 003KZ001BAD7
       Coding: 30314539303330303034554A305238583053
       ASAM Dataset: EV_Airba1041BPAAU210 001018
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 49CC546EB934C2FF093-801C
       Serial number: 3554VRB404T0R8AC20T$
       Serial number: 3575HRB405N1TEI4DP2+
       Serial number: 3585HRB405N1TEI47H1R
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB40610OPMM61Q9
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
       Revision: FF010017    Serial number: 20120423100292
       Coding: 1994004000
       VCID: 392C24AEE9D4527F993-806C
    365080 - Controls in Steering Wheel
                        Reset counter: 246
                        Mileage: 27286 km
                        Date: 2019.03.24
                        Time: 21:51:25
    1140738 - Steering angle sensor
                        Reset counter: 246
                        Mileage: 27286 km
                        Date: 2019.03.24
                        Time: 21:51:25
                        UBat: 12.10 V
                        MC1 interner Fehlercode: 0
                        MC2 interner Fehlercode: 0
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8X0 920 980 E    HW: 8X0 920 980 E
       Component: KOMBI_MEDIUM  H03 0180
       Coding: 43DE00
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
       VCID: 41DC4C4E81040ABFD13-8014
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 G    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0058
       Revision: 1P090032    Serial number: 3241P124170370
       Coding: F0C40064000100010153
       VCID: 46D65F52A8AA2D87E41-8012
       Component: IMMO          H03 0180
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
       Component: TSG FA        H10 0415
       Coding: 011E02200C01000100
       VCID: 55F4881E650C961F9DB-8000
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11251
       Shop #: WSC 00046
       VCID: 2F381AF62E508CCF377-807A
    Address 46: Central Conv.
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
       Component: TSG BF        H10 0415
       VCID: 54F2751A6EF68F176A5-8000
       Part No SW: 8X0 907 357 B    HW: 8X0 907 357 A
       Component: ****LWR12**** H02 0021
       Serial number: 120419-0001-166
       Coding: 1131941010002400
       ROD: EV_HeadlRegulBasic.rod
    0077 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
              [Fehlerhaftes Signal in CAN-Message mBremse_2 (0x5A0)]
                        Reset counter: 246
                        Mileage: 27286 km
                        Date: 2019.03.24
                        Time: 21:52:01
    393989 - Headlight
                        Reset counter: 246
                        Mileage: 27286 km
                        Date: 2019.03.24
                        Time: 21:52:00
       Part No SW: 8X0 035 193 E    HW: 8X0 035 193 D
       Component: RMC Cnct Nav  H52 0775
       Coding: 01010001008051070023000103010000000000
       VCID: 3A2E3BA2EC525967909-806E
       Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9462D.0C2544982
    Quote Originally Posted by Pnr_coding View Post
    Your problem most likely isn't coding - it's that three modules cannot be reached (ABS, Cent Elect and Central Conv).
    SVM & maybe just maybe if you JPPSG
    It would probably be wise to establish communications with controllers first by checking fuses & RTFB of WD!
  4. Likes PetrolDave, Dana liked this post
    Mar 2017
    london
    Thank you, when I did the first scan it said not coded, I'll go back to the drawing board.
  6. Likes Dana liked this post
    Mar 2017
    london
    Audi A1 abs long coding
    I am trying to input new long coding number supplied by visvag but it won't accept, there is a warning from vis4vag suggesting I may need to contact you guys as my manufacturer for my diagnostic device please help me this is stressing me out.
    For us to be able to suggest ABS coding you'll need to post a full unedited VCDS Auto-Scan here - see my signature for a link to a HowTo.
    Mar 2017
    london
    thanks for such a rapid response petroldave, I hope I've done that right. my battery voltage is low but only because I've been at this for hours I had to jump start my car and run it just to get the voltage backup
    VIN: WAUZZZ8X6CB243319 Mileage: 27730km-17230miles
    VCID: 6788B2D6CFE0148F6B3-8032
    VCID: 303A198A363E93377A9-513C
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
    Component: ESP8.2i front H07 0001
    Revision: --------
    VCID: 7F580AB6B7B0BC4FB33-802A
    Coding: 6420000000
    VCID: 33301686CBB8A82F07B-8066
    Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
    Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
    Component: BCM PQ35 M 110 0655
    Revision: 00110 AE
    Coding: 0E000A28A805F100201843E02100894C53FF721721215922E40800870040
    Shop #: WSC 00046 123 12345
    VCID: 40DA494A8A8E03B78A9-8014
    Subsystem 3 - Part No: 8X0 951 177
    Component: DWA-Sensor H0 H01 0020
    VCID: 49CC546EB934C2FF5D7-801C
    Coding: 1994000000
    Shop #: WSC 00046 790 12345
    VCID: 392C24AEE9D4527FCD7-806C
    Reset counter: 34
    Mileage: 27732 km
    Date: 2019.08.23
    Time: 16:39:09
    Reset counter: 34
    Mileage: 27732 km
    Date: 2019.08.23
    Time: 16:39:09
    UBat: 11.30 V
    Coding: 43DC00
    VCID: 41DC4C4E81040ABF857-8014
    VCID: 46D65F52A8AA2D87B05-8012
    Coding: 000002
    VCID: 55F4881E650C961FC9F-8000
    Coding: 11251
    Shop #: WSC 00046
    VCID: 2F381AF62E508CCF633-807A
    Coding: 011E02200C01000102
    VCID: 54F2751A6EF68F173E1-8000
    Coding: 1131941010000400
    393989 - Headlight
    Reset counter: 34
    Mileage: 27732 km
    Date: 2019.08.23
    Time: 16:39:28
    VCID: 3A2E3BA2EC525967C4D-806E
    End----(Elapsed Time: 01:31, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
  10. #8
    What caused this ABS to lose coding and why do you not have a prior scan?
  11. #9
    Mar 2017
    london
    Hello uwe, stupidly I never scanned the car upon purchase I won't be making that mistake again, I bought it as a salvage car and changed the airbags I also had the battery off for several days as I was doing the work in between my regular job
  12. #10
    Mar 2017
    london
    I'm still learning about the do's and don'ts of vcds. I've had it for some time now but never really applied myself but now I want to learn all I can as I am now considering buying damaged cars and repairing them as a hobby.
