Problem with VCDS coding on VW T5.1
Projekt-T
Italy
C?ID=352618
hi @all,
i have a problem with vcds,
on a vw T5.1 i installed the fulled headlight,
fisical installation and rewire the connectors goes ok, but with coding i have a problem,
trying to coding on "07 menù (cent.elect)"
on long coding, the program can't permit me to change bit on Byte 18,
a message RED COLORED tell me that extremely dangerous to change the code...
i know and i want to change in anyway (the modification is tested from many users)
but not is possible, the program can't allow me...
there is a solution to make a change in Byte 18???
tia
Alex
Projekt-T
Italy
C?ID=352618
sorry now i can't have the vehicle near me, tomorrow i post the AUTOSCAN image.
Did you not make an Auto-Scan before you started working on this vehicle?
If byte 18 is all zeros that means the real coding is "hidden" in an EEPROM value, so there's no way to simply revert if the new coding is wrong nor to calculate what the changed coding should be based on the current coding.
Many owners have caused all sorts of lighting issues by changing a byte 18 value of all zeroes, so you need to be 101% sure that the value you plan to be use is correct.
iichel
Netherlands, eastern part
C?ID=284912
The byte 18 being masked won't be an issue on pq25. Let's see if there's a scan somewhere
Projekt-T
Italy
C?ID=352618
obviously i did the autoscan before start the work,
yesterday when i wrote the post i was at home, and the transporter and the vcds laptop was in my workshop...so yesterday i didn't post the scan.
This is the condition at the start of the entire working process
Monday,25,March,2019,16:27:31:65308
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WV1ZZZ7HZCH019405   License Plate:
Mileage: 328200km-203934mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 56 69 6E 77 0B
VIN: WV1ZZZ7HZCH019405   Mileage: 328200km-203934miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H42 9970
   Revision: 26H42---    Serial number: 00000000000000
   Coding: 0119401A231400080000
   Shop #: WSC 38837 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: 6D92CA46BC6EE22206-8038
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 708724AD89A50E9E24A69171696310
   Shop #: WSC 02736 790 49152
   VCID: 373E282E86B298F22C-8062
   Part No SW: 7E5 907 047 BC    HW: 7E5 907 047 BC
   Component: Climatic-T5   H19 0404
   Revision: 00001008
   Coding: 0000000002
   Shop #: WSC 02756 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 71AAD636A05606C222-8024
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 089 F    HW: 7H0 937 089
   Component: BCM T5GP Li4  H50 0251
   Revision: BS050001    Serial number: 0465 184111185
   Coding: A0A0393A0E21200201280E706EEB8E548290610F60862C41300000000000
   Shop #: WSC 02756 123 09999
   VCID: 393A2E16B0A68E82DA-806C
   Component: RLS 290611 05  54  0403
   Coding: 02302E
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180001165610038245
   Coding: A4FFFF
03428 - Activation of Left Adaptive Light
                    Fault Status: 01101011
                    Reset counter: 173
                    Mileage: 328203 km
                    Date: 2013.09.17
                    Time: 00:13:51
03429 - Activation of Right Adaptive Light
                    Reset counter: 173
                    Mileage: 328203 km
                    Date: 2013.09.17
                    Time: 00:13:51
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 173
                    Mileage: 328203 km
                    Date: 2013.09.17
                    Time: 00:13:51
                    Reset counter: 173
                    Mileage: 328203 km
                    Date: 2013.09.17
                    Time: 00:13:51
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47401115500700
   Coding: 118004
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: 34241F229FC473EA09-8060
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag007 H06 0013
   Revision: --------    Serial number: 003HM0018V84
   Coding: 000000000000000000000000000000003037
   Shop #: WSC 02734 790 50316
   VCID: 3620252A89B861FA37-8062
   Serial number: 3495ZRB40670D6ISH1Q5
   Serial number: 3505ZRB404V0DD24IPO9
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 328203 km
                    Date: 2019.03.25
                    Time: 00:13:55
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 328203 km
                    Date: 2019.03.25
                    Time: 00:13:55
   Part No SW: 7E0 920 870 E    HW: 7E0 920 870 E
   Component: KOMBI         H04 0305
   Coding: 160E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2B16045E42FA2C1258-807E
   Part No: 7E0 819 008 D
   Component: J737__Standheizung  0605
   Revision: 00084000    Serial number: 09019169F00000
   Coding: 0000322
   Shop #: WSC 68578 123 12345
   VCID: 2A18015A8500351AA3-807E
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 H50 0251
   Revision: BS050001
   Coding: 042200
   VCID: 70ACD332A35C0FCA2D-8024
   Component: IMMO          H04 0305
   VCID: 6A98C15A8D80F51A63-803E
Address 56: Radio
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Revision: 3A001001    Serial number: 00000150316427
   Coding: 410D000100000000
   Shop #: WSC 02736 790 00000
   VCID: 302C133263DC4FCA6D-8064
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0175
   Revision: 10100010    Serial number: 209624
   Coding: 000202
   Shop #: WSC 02756 000 09999
   VCID: 352222269CBE6AE23E-8060
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661281841
   Coding: 0A01010001010101
   Shop #: WSC 21903 124 106850
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 2600F56A5918117A87-8072
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 173
                    Mileage: 328203 km
                    Date: 2019.03.25
                    Time: 00:13:52
End----------(Elapsed Time: 01:54, VBatt start/end: 12.0V/12.0V)-----------
Projekt-T
Italy
C?ID=352618
i don't have all zero in original coding, but the problem is that VCDS don't permit me to insert, delete, copy or past no one bit in byte 18, no modification permitted by the program
Huh?
You should be able to edit the yellow ones and zeros in field labeled "Binary:"
In addition there is a drop-down box with a few documented values. However, your original value of 0x61 is not one of those.
Projekt-T
Italy
C?ID=352618
Huh?
No! The problem is this! In the field with 0 and 1 in yellow, the program don't allow me to do any modification!
If I go in byte 17 or 19 yes, no problem, I can insert new code or modify a single bit in the string... i solved using the LCode2 windows.
Thanks!
iichel
C?ID=284912
Try these values, for PQ25 byte 18:
- 41 H7/H4 headlights
- 61, 65 H7/H4 headlight (for models with automatic headlights)
- 67 bi-xenon
- 60, 66, for LED headlights (factory Polo 6R)
- 73 for LED headlights (factory T6)
