Results 1 to 10 of 10
Thread: Problem with VCDS coding on VW T5.1
    Mar 2019
    Italy
    hi @all,
    i have a problem with vcds,
    on a vw T5.1 i installed the fulled headlight,
    fisical installation and rewire the connectors goes ok, but with coding i have a problem,
    trying to coding on "07 mený (cent.elect)"
    on long coding, the program can't permit me to change bit on Byte 18,
    a message RED COLORED tell me that extremely dangerous to change the code...
    i know and i want to change in anyway (the modification is tested from many users)
    but not is possible, the program can't allow me...
    there is a solution to make a change in Byte 18???
    tia
    Alex
    Mar 2019
    Italy
    sorry now i can't have the vehicle near me, tomorrow i post the AUTOSCAN image.
    Did you not make an Auto-Scan before you started working on this vehicle?
    If byte 18 is all zeros that means the real coding is "hidden" in an EEPROM value, so there's no way to simply revert if the new coding is wrong nor to calculate what the changed coding should be based on the current coding.
    Many owners have caused all sorts of lighting issues by changing a byte 18 value of all zeroes, so you need to be 101% sure that the value you plan to be use is correct.
    Aug 2016
    The Hague, NL
    The byte 18 being masked won't be an issue on pq25. Let's see if there's a scan somewhere
  6. Likes Uwe liked this post
    Mar 2019
    Italy
    obviously i did the autoscan before start the work,
    yesterday when i wrote the post i was at home, and the transporter and the vcds laptop was in my workshop...so yesterday i didn't post the scan.
    This is the condition at the start of the entire working process
    Monday,25,March,2019,16:27:31:65308
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: WV1ZZZ7HZCH019405   License Plate:
    Mileage: 328200km-203934mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 10 15 17 18 19 25 56 69 6E 77 0B
    VIN: WV1ZZZ7HZCH019405   Mileage: 328200km-203934miles
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H42 9970
       Revision: 26H42---    Serial number: 00000000000000
       Coding: 0119401A231400080000
       Shop #: WSC 38837 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
       ROD: EV_ECM20TDI01103L906022CH_002.rod
       VCID: 6D92CA46BC6EE22206-8038
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0107
       Revision: 00H43001
       Coding: 708724AD89A50E9E24A69171696310
       Shop #: WSC 02736 790 49152
       VCID: 373E282E86B298F22C-8062
       Part No SW: 7E5 907 047 BC    HW: 7E5 907 047 BC
       Component: Climatic-T5   H19 0404
       Revision: 00001008
       Coding: 0000000002
       Shop #: WSC 02756 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 71AAD636A05606C222-8024
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 089 F    HW: 7H0 937 089
       Component: BCM T5GP Li4  H50 0251
       Revision: BS050001    Serial number: 0465 184111185
       Coding: A0A0393A0E21200201280E706EEB8E548290610F60862C41300000000000
       Shop #: WSC 02756 123 09999
       VCID: 393A2E16B0A68E82DA-806C
       Component: RLS 290611 05  54  0403
       Coding: 02302E
       Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3311
       Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3311
       Subsystem 4 - Part No SW: 2H0 959 442     HW: 2H0 959 442
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39180001165610038245
       Coding: A4FFFF
    03428 - Activation of Left Adaptive Light
                        Fault Status: 01101011
                        Reset counter: 173
                        Mileage: 328203 km
                        Date: 2013.09.17
                        Time: 00:13:51
    03429 - Activation of Right Adaptive Light
                        Reset counter: 173
                        Mileage: 328203 km
                        Date: 2013.09.17
                        Time: 00:13:51
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 173
                        Mileage: 328203 km
                        Date: 2013.09.17
                        Time: 00:13:51
                        Reset counter: 173
                        Mileage: 328203 km
                        Date: 2013.09.17
                        Time: 00:13:51
       Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H11 0013
       Revision: --------    Serial number: 47401115500700
       Coding: 118004
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_VW75XParkAssis8K A01005
       ROD: EV_VW75XParkAssis8K_A01.rod
       VCID: 34241F229FC473EA09-8060
       Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
       Component: VW10Airbag007 H06 0013
       Revision: --------    Serial number: 003HM0018V84
       Coding: 000000000000000000000000000000003037
       Shop #: WSC 02734 790 50316
       VCID: 3620252A89B861FA37-8062
       Serial number: 3495ZRB40670D6ISH1Q5
       Serial number: 3505ZRB404V0DD24IPO9
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [137] - Resistance Too High
                        Mileage: 328203 km
                        Date: 2019.03.25
                        Time: 00:13:55
    9439771 - Front Passenger's Side Airbag Igniter
              B100A 1B [137] - Resistance Too High
                        Mileage: 328203 km
                        Date: 2019.03.25
                        Time: 00:13:55
       Part No SW: 7E0 920 870 E    HW: 7E0 920 870 E
       Component: KOMBI         H04 0305
       Coding: 160E00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       VCID: 2B16045E42FA2C1258-807E
       Part No: 7E0 819 008 D
       Component: J737__Standheizung  0605
       Revision: 00084000    Serial number: 09019169F00000
       Coding: 0000322
       Shop #: WSC 68578 123 12345
       VCID: 2A18015A8500351AA3-807E
       Part No SW: 6N0 909 901     HW: 7H0 937 089
       Component: GW-K-CAN TP20 H50 0251
       Revision: BS050001
       Coding: 042200
       VCID: 70ACD332A35C0FCA2D-8024
       Component: IMMO          H04 0305
       VCID: 6A98C15A8D80F51A63-803E
    Address 56: Radio
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Revision: 3A001001    Serial number: 00000150316427
       Coding: 410D000100000000
       Shop #: WSC 02736 790 00000
       VCID: 302C133263DC4FCA6D-8064
    Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
       Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
       Component: Dachdisplay   H15 0175
       Revision: 10100010    Serial number: 209624
       Coding: 000202
       Shop #: WSC 02756 000 09999
       VCID: 352222269CBE6AE23E-8060
       Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661281841
       Coding: 0A01010001010101
       Shop #: WSC 21903 124 106850
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 2600F56A5918117A87-8072
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 173
                        Mileage: 328203 km
                        Date: 2019.03.25
                        Time: 00:13:52
    End----------(Elapsed Time: 01:54, VBatt start/end: 12.0V/12.0V)-----------
    Mar 2019
    Italy
    i don't have all zero in original coding, but the problem is that VCDS don't permit me to insert, delete, copy or past no one bit in byte 18, no modification permitted by the program
  9. #8
    Quote Originally Posted by Tommo View Post
    Huh?
    You should be able to edit the yellow ones and zeros in field labeled "Binary:"
    In addition there is a drop-down box with a few documented values. However, your original value of 0x61 is not one of those.
  10. #9
    Mar 2019
    Italy
    Huh?
    No! The problem is this! In the field with 0 and 1 in yellow, the program don't allow me to do any modification!
    If I go in byte 17 or 19 yes, no problem, I can insert new code or modify a single bit in the string... i solved using the LCode2 windows.
    Thanks!
  11. #10
    Aug 2016
    The Hague, NL
    Try these values, for PQ25 byte 18:
    - 41 H7/H4 headlights
    - 61, 65 H7/H4 headlight (for models with automatic headlights)
    - 67 bi-xenon
    - 60, 66, for LED headlights (factory Polo 6R)
    - 73 for LED headlights (factory T6)
  12. Likes Uwe liked this post
