Hi guys,below is an autoscan of a 2009 GTI that had its ABS/ESP control replaced with an updated one elsewhere, owner claims the old one lost and refused to communicate.....unfortunately I forgot to check Advanced ID of cluster,Immo and ECU,however I think they've not been tampered with.....any help is greatly appreciated
Friday,26,April,2019,10:58:39:21182
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WVWZZZ1KZ9U005513 License Plate: KCH629S 2.OL GTI
Mileage: 98060km-60931mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 62 72
VIN: WVWZZZ1KZ9U005513 Mileage: 98060km-60931miles
03-ABS Brakes -- Status: Not registered 0011
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H43ND86H
Coding: 040300431C070160
Shop #: WSC 00046 412 00000
VCID: 34311E55A23E44474A5-8060
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow
Fault Status: 01100010
Fault Frequency: 11
Mileage: 97587 km
Time: 00:20:19
RPM: 758 /min
Load: 16.9 %
Temperature: 75.0°C
Temperature: 34.0°C
Absolute Pres.: 830.0 mbar
Voltage: 14.097 V
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Mileage: 97626 km
Time: 23:01:24
RPM: 1370 /min
Load: 31.0 %
Speed: 57.0 km/h
Temperature: 85.0°C
Temperature: 39.0°C
Voltage: 13.970 V
Part No SW: 02E 300 041 A HW: 02E 927 770 AD
Component: GSG DSG 041 0821
Revision: 00004010 Serial number: 00000409220170
Shop #: WSC 01279 785 00200
VCID: 1079B2C5F66658670ED-8044
01208 - Data Records in Control Unit Altered
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Shop #: WSC 30173 002 1048576
VCID: 00598285AA0628E79ED-8054
Fault Status: 01100101
Reset counter: 0
Mileage: 97848 km
Count: 7
Count: 14
Count: 12800
Count: 279
Count: 44032
Reset counter: 0
Mileage: 97848 km
Count: 7
Count: 14
Count: 12800
Count: 295
Count: 44032
Reset counter: 0
Mileage: 97848 km
Count: 7
Count: 14
Count: 12800
Count: 270
Count: 44032
Reset counter: 64
Mileage: 97848 km
Count: 7
Count: 14
Count: 12800
Count: 195
Count: 44032
Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6C81C635BA8EDC87525-8038
Revision: 00H54000 Serial number: 00000008542185
Coding: E78F0F2700041500471400001400000000097F075C000100000000000000
VCID: 33331D49A730437F53F-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 250808 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 020708 046 0204
Coding: 00733221
Shop #: WSC 00046
01506 - Bulb for Rear Fog; Right (L47)
Fault Status: 00101100
Reset counter: 116
Mileage: 97848 km
Voltage: 12.10 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 15 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BD5R3
Coding: 0012597
Subsystem 1 - Serial number: 6332MSME37550214+
Subsystem 2 - Serial number: 6342MSME3B320A225
Subsystem 3 - Serial number: 6352QSME691C1767Q
Subsystem 4 - Serial number: 6362QSME685B134FV
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 752 0101
Coding: 0012142
VCID: 04518E95B21E34C7BA5-8050
Component: E0221 002 0010
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K6 920 864 HW: 1K6 920 864
Component: KOMBIINSTRUMENT VDD 1214
Revision: V0002000 Serial number: VWX7Z0H43ND86H
Coding: 0007503
Shop #: WSC 00000 263 1385455
VCID: 6FBBD1398B98279F777-803A
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 080608F1001131
Coding: E5817F060000020003
Shop #: WSC 55455 002 1048576
VCID: 35372351A9445D4F7DB-8060
Fault Frequency: 49
Mileage: 97848 km
Time: 19:59:58
Component: IMMO VDD 1214
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1210
Coding: 0000694
VCID: 392F2F61855CB92F993-806C
00914 - Window Regulator Switch; Rear Left; Driver (E53)
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A0D002D70FA02B7E09-807E
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 899002005103087F2D0484056008DF03E0FCA0
VCID: 71BFD7419DAC316F613-8024
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000950
VCID: 3A2D306D805AB237909-806E
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1DE55E2BE04478A5-8020
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 38292A65BE56A02766D-806C
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End----------(Elapsed Time: 01:13, VBatt start/end: 13.6V/13.8V)-----------
