Results 1 to 10 of 12
Thread: ABS module coding error (B6 S4 Bosch 5.7)
    Apr 2019
    Canada
    Audi s4 b6 ABS Control Module Incorrectly Coded 01044
    Hi i changed my control module in my Audi , after adapting codes everything went smooth , login, coding, i cleared the codes except the code 00287 ABS wheel speed sensor , rear right ( g44) which was changed last week to brand new one , i took the car for a spin came back to the garage to rescan the ABS module when i was doing that my car battery died o well I charged the battery , hooked up vag com cable scanned ABS module again , and what happened ABS Control Module Incorrectly Coded 01044 , i tried few times already scan and rescan steering wheel angle and still canít clear that code , any one please advise what else i can do to clear the code , thanks in advance
    Apr 2019
    Canada
    Here is my scan
    Wednesday,24,April,2019,22:21:41:07754
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUPL68E14A214677   License Plate: S4 B6
    Mileage: 142720km-88682mi   Repair Order:
              67 69 75 76 77
    VIN: WAUPL68E14A214677   Mileage: 142720km-88682miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8E0 910 560 UM    HW: 8E0 907 560
       Component: 5.0  93Oct JHM  G   0010
       Revision: 00000000    Serial number: AUZ6Z0C0477665
       Coding: 0007711
       Shop #: WSC 12340 412 460390
       VCID: 0407C2B34405556AF9-5122
    Readiness: 0110 1100
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      4529
       Coding: 04277
       Shop #: WSC 12345
       VCID: 2643B83BC2F9477A87-50E8
                35-00 -  -
                30-00 - Open or Short to Plus
    Are you sure that 8E0 614 517 A is the correct ABS part number for this car?
    And it clearly is coded incorrectly. It's coded for a 4 or 5 cylinder gasoline engine and an Automatic Trans. Have a look here and be sure to watch the video at the bottom of the page.
    Apr 2019
    Canada
    Hi Uwe no the part it is not the part from the s4 i bought from the a4 abs pump number was 8E0 614 517 A mine is 8E0 614 517 Q i thought i can adapt the module to S4
    Nov 2017
    Latvia
    Maybe... 517Q is for 8-cylinder quattro, 517A is for 4- and 6-cylinder quattro.
  6. Likes Uwe liked this post
    Apr 2019
    Canada
    517 Q it is for 8 cylinder quattro , i was thinking the pump its self not the module i guess I wasnít right and the module can not be adapted from A to Q
    Apr 2019
    Canada
    I found the module matching my numbers but i have my car in manual transmission and that module is from automatic transmission is that gonna work ? Please let me know
  9. #8
    Apr 2019
    Canada
    Anybody in that forum can help me or not ?
  10. #9
    Please see the link in post #3 of this thread.
  11. #10
    Apr 2019
    Canada
    So i guess because its from automatic transmission and i have a manual transmission the new module itís not gonna work
