2 questions for a newb ....what platform?
dillenger1
C?ID=368041
where do i find the platform operating system information and where can i find what i have?and what is the easiest way to transfer your autoscan from a file folder.this is a test
Saturday,20,April,2019,19:29:54:61679
VCDS Version: 18.9.1.0 (x64)
VIN: 3VWCA7AU9FM501766   License Plate:
Mileage: 92834km-57684mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU9FM501766   Mileage: 92834km-57684miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9459
   Revision: 85X23---
   Coding: 011D0012032410081000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B7FDB52B2954F92C8-806E
Readiness: 0 0 0 1 0
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01501120125
   Shop #: WSC 00066 790 00201
   ROD: EV_TCMDQ250021.rod
   VCID: 234F03322A251752E0-8076
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 50075000000447
   Coding: 04FA6AA12420096D007E020681C92520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 4797B7A2FE5D1B725C-8012
   Revision: 00021000    Serial number: 0355862780
   Coding: 030C0C
   VCID: 3A71DE56BDAF769AD3-806E
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Revision: 00001K01
   Coding: 02020104200100000000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 050B7DAA84D1C962EE-8050
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86581712140706
   Coding: 000118424041804169E44000000403001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4993B19AE849ED024A-801C
   Component: WWS    141210  043 0581
   Serial number:         150203070414
541973 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
559125 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
555541 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
542229 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
542485 - Databus
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:26:34
329480 - Heated Passenger Seat
          B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                    Reset counter: 118
                    Mileage: 92834 km
                    Date: 2019.04.19
                    Time: 07:01:30
   Serial number: 003GCR013TGL
   ROD: EV_AirbaVW20SMEVW37X.rod
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J1500029OTJ0P
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 001 112 14
   Serial number: 35700000000942F8321G
   Subsystem 3 - Part No SW: -----------    HW: 480 001 112 14
   Serial number: 3580000000023D21221%
   Subsystem 4 - Part No SW: -----------    HW: 480 401 112 14
   Serial number: 3510002B31811B90813P
   Subsystem 5 - Part No SW: -----------    HW: 480 400 812 14
   Serial number: 35200029D1811B91527.
   Subsystem 6 - Part No SW: -----------    HW: 480 400 212 14
   Serial number: 3550002C718B3AB3F1CN
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 212 14
   Serial number: 3560002C718B3AB2B23B
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141217500378
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 040D60AE8FEBF06AF9-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA4121A2180CF05020868001000000000000000
   VCID: 65CB5D2A649129624E-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 22011510001256
   Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   VCID: 71E3397AA059F5C222-8024
   Component: E221__MFL-DC1  H16 0101
   Serial number: 27140003150690014527
   Coding: 29FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0020000
   Revision: 00000000    Serial number: 15000015147004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DF06E9FCB80EA09-8060
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 080115060502XI
   Coding: 003013200000040000000000
   VCID: 3E79D246A1875ABAEF-806A
   Serial number: 00000000000000550428
   Coding: 011000
65588 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 72
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:14
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 438FA3B2CA65375280-8016
19460 - Databus
                    Fault Frequency: 47
                    Reset counter: 112
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:15
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 43.0 °C
                    KFC: 4C
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 11.72 V
                    uAdSensI_SwitchedKl30_xdu16: 11.72 V
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 131214060503EY
   VCID: 3D7BD54AAC8141A2F6-8068
   Serial number: 00000000000000539641
   Coding: 091000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B00401151026
   Coding: 02730200FF00000021220001001800001F0100140100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64CD402E6FAB506A59-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS50155R
          B11CF 53 [009] - Deactivated
                    Reset counter: 72
                    Mileage: 92639 km
                    Date: 2019.04.11
                    Time: 08:45:15
                    Voltage terminal 30: 11.7 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Not available
                    Satellite radio tuner status-Antenna current: 0 mA
                    Satellite radio tuner status-Reception quality: Not available
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Component: OCULowMQBUS   007 0564
   Coding: 02730002C2821A017F1E06000000
   Shop #: WSC 00066 790 00123
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:45)--------------------------
dillenger1
C?ID=368041
for the autoscan is it just a matter of copy paste from notepad?or is there an easier way
What do you mean by "platform operating system information"?
When an Auto-Scan finishes in VCDS, you can just click the [Copy] button, and presto, the whole thing will be in your Clipboard, ready to paste here. But of course opening a saved file using Notepad and copying the contents thereof also works.
dillenger1
C?ID=368041
I assume the operating system for kessy? cant find an example of course.maybe the software/hartdware designations for different years and models?if i find an example ill post it.I was reading about a channel adaptation that was available with one system and not another .Theres Chassis designations(b5,a3...) and electrical designations? Thats how i perceived it.
dillenger1
C?ID=368041
DIN component identifier maybe?
I think you're over thinking this.
The software in the vast majority of modules in the car won't be using a well known operating system - most time critical embedded software systems don't use an operating system.
Whether an adaptation channel is available or not depends on software and hardware revisions, and usually it's not valid to compare modules between different vehicle platforms such as PQ25 or MQB.
dillenger1
C?ID=368041
yes!! MQB!?thats what im asking about. so mqb is mk7 and pq25 is mk6?or can the systems interchange through chassis platforms
MQB is Mk.7 and all derivatives, up to an including the Atlas SUV.
PQ25 is technically a previous generation Polo, but some of the body and comfort systems are also used in a variety of other cars, such as the T5 van, the Amarok pickup, and some of the low-end Mk.6 cars.
dillenger1
C?ID=368041
my dad has a passat sel with pq25.i was playing with it yesterday and its very limited compared to my mk7.at least it seemed very limited
Not surprising. PQ25 is at least one generation older stuff than MQB.
dillenger1
C?ID=368041
im absolutley in love with the vcds system.I work for a caterpillar dealer and do alot of troubleshooting,programming and configuration changes on new emergency generator start ups.Old volkswagens(diesels) have always been my "thing" but these new cars are amazing!!im impressed with the ease and fluidity of the adaptation channels
