Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: VW EOS - Tail Light Problem
    Apr 2019
    I went out for a drive and the error came back for both lights unfortunately.
    Would a solution be to find an original module and switch it back? Would you know which part number I'd be looking for?
  2. #12
    Apr 2019
    Do you guys think this is problem that could be corrected by coding? Could it be a hardware issue? Thanks!
  3. #13
    Any FOD?
    JPPSG
  4. #14
    Apr 2019
    Nope no visible signs of any damage, although I haven't taken the module out to inspect it - is that worth doing?
  5. #15
    All FOD potential should always be verified!
  6. #16
    Apr 2019
    Hi guys - so I swapped out my newer BCM for the older 'Q' variant that originally came with my car and coded using one of the examples provided by Dana in this tread - I then tweaked using the long coding helper to disable the rear wiper bit (as my car doesn't have one) and switch off all the cold lamp diag.
    I still get the errors BUT now the side lights actually come on, although they are dimmed. If I clear the fault code the lights come on full power for a second before tripping the code and dimming again. Do you have any suggestions please?
    Updated scan below:
    Thursday,02,May,2019,21:47:13:20055
    VIN: WVWZZZ1FZ7V020223   License Plate:
    Chassis Type: 1F (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1FZ7V020223   Mileage: 84810km-52698miles
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 GR    HW: 022 906 032 GP
       Component: MOTRONIC ME7.1.1    9376
       Revision: --H02---    Serial number: VWX7Z0F83NR99K
       Coding: 0000078
       Shop #: WSC 00020 000 00000
       VCID: 619E53895D4D4F7FF13-8034
    Readiness: 0110 1001
       Part No SW: 02E 300 043 B    HW: 02E 927 770 AE
       Component: GSG DSG         070 1181
       Revision: 04507000    Serial number: 00000609130473
       Shop #: WSC 44551 111 44551
       VCID: 13724941D7716DEF33F-8046
       Revision: 00H11001
       Coding: 0004834
       VCID: 73B229C1F7B1CDEF93F-8026
       Part No: 1Q0 820 047 E
       Component: Climatic PQ35   130 0101
       VCID: 2C00F2BD6A0FD217125-8078
       Revision: 00H46000    Serial number: 00000005595089
       Coding: E5048A0700041500470A00000F000000000900005C0000
       Shop #: WSC 00020 123 12345
       VCID: 372ADDD1A34961CF6F7-8062
       Component: Wischer 101006 020  0501
       Coding: 00038805
       Shop #: WSC 00020
       Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
       Component: RLS     290906 014  1201
       Coding: 00471077
       Shop #: WSC 00020
    00984 - Left Tail Light (M4)
                        Reset counter: 55
                        Mileage: 84815 km
                        Voltage: 13.60 V
    00985 - Right Tail Light (M2)
                        Reset counter: 55
                        Mileage: 84815 km
                        Voltage: 13.65 V
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 3D Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B3000ZTC7
       Coding: 0013124
       VCID: 3A2CC4E5905B7CA7909-806E
       Subsystem 1 - Serial number: 6332SRB403CDD3AAJ
       Subsystem 2 - Serial number: 6342SRB403F18F918
       Subsystem 3 - Serial number: 637  RB4        8
       Subsystem 4 - Serial number: 638  RB4        9
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Component: J0527           036 0070
       Coding: 0012101
       VCID: 015E7309BD0DEF7F913-8054
       Part No SW: 1Q0 920 973 X    HW: 1Q0 920 973 X
       Component: KOMBIINSTRUMENT VDD 1610
       Revision: V0003000    Serial number: VWX7Z0F83NR99K
       Coding: 0021403
       Shop #: WSC 00999 067 57207
       VCID: 48C8AE2DDEB71E3716D-801C
       Part No SW: 1K0 907 530 H    HW: 1K0 907 951
       Component: J533__Gateway   H12 0150
       Revision:   H12       Serial number: 310010691693C2
       Coding: 3F3F274007005001
       Component: IMMO            VDD 1610
       Shop #: WSC 06402 145 00197
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
       Component: Verdecksteuergeraet 0622
       Revision: 0032000K    Serial number: 062640777
       Coding: 0655362
       Shop #: WSC 00020 551 00000
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1Q0 959 701 C
       Component: Tuer-SG         024 2732
       Coding: 0000695
       VCID: 3430EADDB23F8AD74A5-8060
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       VCID: 3536D7D9B94593DF7DB-8060
       Component:    KSG PQ35 G2  020 0202
       Coding: 81908A000186285B0804840570085EC690BC00
       Shop #: WSC 00046 412 819200
       VCID: 03527901A711FD6F83F-8056
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 1Q0 951 177 A
       Component: Innenraumueberw.158 0502
    01134 - Alarm Horn (H12)
                        Reset counter: 55
                        Mileage: 84815 km
                        Time: 21:44:02
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1Q0 959 702 C
       Component: Tuer-SG         024 2740
       Coding: 0000694
       Shop #: WSC 00000 551 00000
       Part No: 1K0 035 195 D
       Component: Radio BVX       013 0033
       Coding: 0040400
       VCID: 270A0D9173E9F14FFF7-8072
       Part No: 1Q0 959 703
       Component: Tuer-SG         021 2705
       Coding: 0000128
       Part No: 1Q0 959 704
       Coding: 0000128
       VCID: 74B02ADDF2BFCAD78A5-8020
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1Q0 919 283
       Component: 30 Einparkhilfe     0702
       VCID: 72BC2CC588ABC4E7989-8026
    End----------(Elapsed Time: 01:20, VBatt start/end: 13.3V/13.8V)-----------
  7. #17
    HQ
    M2 = T4b/2, black, 58R
    M4 = T4a/2, black, 58L
    If you pull those wires out of the terminal housings, cleanr codes, what codes come back?
    Are these LEDs within the tail light (non servicable)? If yes, what are the tail light part numbers?
    Demons?
    Jef
  8. Likes Uwe, Jack@European_Parts liked this post
  9. #18
    Apr 2019
    It's fixed! Just to wrap this up it turns out one of the resistors had blown on the right side light, as revealed by a strip down of the light. The PCB had some scorch marks. Swapped it out with a working used PCB from eBay, cleared the error and finally it's working
    Cheers
  10. Likes Jack@European_Parts, Uwe liked this post
  11. #19
    HQ
    Thanks for the update! Always nice to have the story wrapped up.
    You want to be a ROCK STAR? You should totally post photos showing what you found and how you swapped it out. We have a section for fun stuff like this:
    https://forums.ross-tech.com/forumdi...-To-s-and-Tips
    Jef
  12. Likes Uwe, Jack@European_Parts liked this post
  13. #20
    Induced FOD wins again...........
