Hi all, I've got a weird problem with my 2007 EOS that I'm hoping someone can help me with.
I've got a bulb out warning on the dash for the rear left and right taillights - the lights don't illuminate. If I clear the error code the lights come on fine. Which I'm guessing rules out a physical problem with wiring, fuses, etc.? I tried switching off the bulb check but still get the same issue. The car is completely standard, the lights are original and all other rear lights work (indicators, reverse, fog, etc.) apart from the side lights for both sides.
Here's the scan:
Thanks!
Here's the scan:
Friday,26,April,2019,10:24:09:20055
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WVWZZZ1FZ7V020223 License Plate:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 72 76
VIN: WVWZZZ1FZ7V020223 Mileage: 84380km-52431miles
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 GR HW: 022 906 032 GP
Component: MOTRONIC ME7.1.1 9376
Revision: --H02--- Serial number: VWX7Z0F83NR99K
Coding: 0000078
Shop #: WSC 00020 000 00000
VCID: 619E53895D4D4F7FF13-8034
009769 - Linear Oxygen (Lambda) Sensor B2 S1 Pump Current Trim Circuit
P2629 - 004 - Open
Mileage: 84358 km
Time: 09:39:23
RPM: 3137 /min
Load: 15.7 %
Speed: 64.0 km/h
Temperature: 84.0°C
Temperature: 22.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.462 V
008599 - Oxygen (Lambda) Sensor B2 S1
P2197 - 001 - Signal too Low (Lean)
Fault Status: 01100001
Mileage: 84378 km
Time: 14:17:03
RPM: 2211 /min
Load: 51.0 %
Speed: 63.0 km/h
Temperature: 87.0°C
Temperature: 22.0°C
Voltage: 13.589 V
Readiness: 0010 1001
Part No SW: 02E 300 043 B HW: 02E 927 770 AE
Component: GSG DSG 070 1181
Revision: 04507000 Serial number: 00000609130473
Shop #: WSC 44551 111 44551
VCID: 13724941D7716DEF33F-8046
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0004834
VCID: 73B229C1F7B1CDEF93F-8026
Part No: 1Q0 820 047 E
Component: Climatic PQ35 130 0101
VCID: 2C00F2BD6A0FD217125-8078
Part No SW: 3C8 937 049 AC HW: 3C8 937 049 AC
Component: Bordnetz-SG H64 3205
Revision: 00H64000 Serial number: 00000005257144
Coding: E5048E070004100040000000000000000000FF075C000000000000000000
VCID: 72BC2CC588ABC4E7989-8026
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 101006 020 0501
Coding: 00038805
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 290906 014 1201
Coding: 00208933
00984 - Left Tail Light (M4)
Reset counter: 48
Mileage: 84377 km
Voltage: 12.45 V
00985 - Right Tail Light (M2)
Reset counter: 48
Mileage: 84369 km
Voltage: 13.20 V
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 3D Airbag VW8C 0180
Revision: 92009018 Serial number: 003B3000ZTC7
Coding: 0013124
VCID: 3A2CC4E5905B7CA7909-806E
Subsystem 1 - Serial number: 6332SRB403CDD3AAJ
Subsystem 2 - Serial number: 6342SRB403F18F918
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012101
VCID: 015E7309BD0DEF7F913-8054
Component: E0221 002 0010
Part No SW: 1Q0 920 973 X HW: 1Q0 920 973 X
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWX7Z0F83NR99K
Coding: 0021403
Shop #: WSC 00999 067 57207
VCID: 48C8AE2DDEB71E3716D-801C
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 310010691693C2
Coding: 3F3F274007005001
Component: IMMO VDD 1610
Shop #: WSC 06402 145 00197
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 B HW: 1Q0 959 255 B
Component: Verdecksteuergeraet 0622
Revision: 0032000K Serial number: 062640777
Coding: 0655362
Shop #: WSC 00020 551 00000
VCID: 372ADDD1A34961CF6F7-8062
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1Q0 959 701 C
Component: Tuer-SG 024 2732
Coding: 0000695
VCID: 3430EADDB23F8AD74A5-8060
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
VCID: 3536D7D9B94593DF7DB-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 81908A000186285B0804840570085EC690BC00
Shop #: WSC 00046 412 819200
VCID: 03527901A711FD6F83F-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 3 - Part No: 1Q0 951 177 A
Component: Innenraumueberw.158 0502
01134 - Alarm Horn (H12)
Reset counter: 48
Mileage: 84353 km
Time: 09:18:44
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1Q0 959 702 C
Component: Tuer-SG 024 2740
Coding: 0000694
Shop #: WSC 00000 551 00000
Part No: 1K0 035 195 D
Component: Radio BVX 013 0033
Coding: 0040400
VCID: 270A0D9173E9F14FFF7-8072
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1Q0 959 703
Component: Tuer-SG 021 2705
Coding: 0000128
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1Q0 959 704
Coding: 0000128
VCID: 74B02ADDF2BFCAD78A5-8020
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1Q0 919 283
Component: 30 Einparkhilfe 0702
End----------(Elapsed Time: 01:19, VBatt start/end: 14.1V/13.9V)-----------
Thanks!
