Results 1 to 10 of 20
Thread: VW EOS - Tail Light Problem
    Apr 2019
    Hi all, I've got a weird problem with my 2007 EOS that I'm hoping someone can help me with.
    I've got a bulb out warning on the dash for the rear left and right taillights - the lights don't illuminate. If I clear the error code the lights come on fine. Which I'm guessing rules out a physical problem with wiring, fuses, etc.? I tried switching off the bulb check but still get the same issue. The car is completely standard, the lights are original and all other rear lights work (indicators, reverse, fog, etc.) apart from the side lights for both sides.
    Here's the scan:
    Friday,26,April,2019,10:24:09:20055
    VIN: WVWZZZ1FZ7V020223   License Plate:
    Chassis Type: 1F (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1FZ7V020223   Mileage: 84380km-52431miles
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 GR    HW: 022 906 032 GP
       Component: MOTRONIC ME7.1.1    9376
       Revision: --H02---    Serial number: VWX7Z0F83NR99K
       Coding: 0000078
       Shop #: WSC 00020 000 00000
       VCID: 619E53895D4D4F7FF13-8034
    009769 - Linear Oxygen (Lambda) Sensor B2 S1 Pump Current Trim Circuit
                   P2629 - 004 - Open
                        Mileage: 84358 km
                        Time: 09:39:23
                        RPM: 3137 /min
                        Load: 15.7 %
                        Speed: 64.0 km/h
                        Temperature: 84.0C
                        Temperature: 22.0C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 13.462 V
    008599 - Oxygen (Lambda) Sensor B2 S1
                   P2197 - 001 - Signal too Low (Lean)
                        Fault Status: 01100001
                        Mileage: 84378 km
                        Time: 14:17:03
                        RPM: 2211 /min
                        Load: 51.0 %
                        Speed: 63.0 km/h
                        Temperature: 87.0C
                        Temperature: 22.0C
                        Voltage: 13.589 V
    Readiness: 0010 1001
       Part No SW: 02E 300 043 B    HW: 02E 927 770 AE
       Component: GSG DSG         070 1181
       Revision: 04507000    Serial number: 00000609130473
       Shop #: WSC 44551 111 44551
       VCID: 13724941D7716DEF33F-8046
       Revision: 00H11001
       Coding: 0004834
       VCID: 73B229C1F7B1CDEF93F-8026
       Part No: 1Q0 820 047 E
       Component: Climatic PQ35   130 0101
       VCID: 2C00F2BD6A0FD217125-8078
       Part No SW: 3C8 937 049 AC    HW: 3C8 937 049 AC
       Component: Bordnetz-SG     H64 3205
       Revision: 00H64000    Serial number: 00000005257144
       Coding: E5048E070004100040000000000000000000FF075C000000000000000000
       VCID: 72BC2CC588ABC4E7989-8026
       Component: Wischer 101006 020  0501
       Coding: 00038805
       Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
       Component: RLS     290906 014  1201
       Coding: 00208933
    00984 - Left Tail Light (M4)
                        Fault Status: 01101100
                        Reset counter: 48
                        Mileage: 84377 km
                        Voltage: 12.45 V
    00985 - Right Tail Light (M2)
                        Reset counter: 48
                        Mileage: 84369 km
                        Voltage: 13.20 V
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 3D Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B3000ZTC7
       Coding: 0013124
       VCID: 3A2CC4E5905B7CA7909-806E
       Subsystem 1 - Serial number: 6332SRB403CDD3AAJ
       Subsystem 2 - Serial number: 6342SRB403F18F918
       Subsystem 3 - Serial number: 637  RB4        8
       Subsystem 4 - Serial number: 638  RB4        9
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0012101
       VCID: 015E7309BD0DEF7F913-8054
       Part No SW: 1Q0 920 973 X    HW: 1Q0 920 973 X
       Revision: V0003000    Serial number: VWX7Z0F83NR99K
       Coding: 0021403
       Shop #: WSC 00999 067 57207
       VCID: 48C8AE2DDEB71E3716D-801C
       Revision:   H12       Serial number: 310010691693C2
       Coding: 3F3F274007005001
       Component: IMMO            VDD 1610
       Shop #: WSC 06402 145 00197
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
       Component: Verdecksteuergeraet 0622
       Revision: 0032000K    Serial number: 062640777
       Coding: 0655362
       Shop #: WSC 00020 551 00000
       VCID: 372ADDD1A34961CF6F7-8062
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1Q0 959 701 C
       Component: Tuer-SG         024 2732
       Coding: 0000695
       VCID: 3430EADDB23F8AD74A5-8060
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       VCID: 3536D7D9B94593DF7DB-8060
       Component:    KSG PQ35 G2  020 0202
       Coding: 81908A000186285B0804840570085EC690BC00
       Shop #: WSC 00046 412 819200
       VCID: 03527901A711FD6F83F-8056
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 1Q0 951 177 A
       Component: Innenraumueberw.158 0502
    01134 - Alarm Horn (H12)
                        Reset counter: 48
                        Mileage: 84353 km
                        Time: 09:18:44
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1Q0 959 702 C
       Component: Tuer-SG         024 2740
       Coding: 0000694
       Shop #: WSC 00000 551 00000
       Part No: 1K0 035 195 D
       Component: Radio BVX       013 0033
       Coding: 0040400
       VCID: 270A0D9173E9F14FFF7-8072
                000 -  -
       Part No: 1Q0 959 703
       Component: Tuer-SG         021 2705
       Coding: 0000128
       Part No: 1Q0 959 704
       Coding: 0000128
       VCID: 74B02ADDF2BFCAD78A5-8020
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1Q0 919 283
       Component: 30 Einparkhilfe     0702
    01545 - Sensor for Parking Aid; Rear Left (G203)
    End----------(Elapsed Time: 01:19, VBatt start/end: 14.1V/13.9V)-----------
    Thanks!
    HQ
    Please post the full Auto-Scan.
    Quick and easy, swap out the bulbs in tail lights, or at least move them around.
    Jef
    Tartu, Estonia
    EOS has passat like LED tails. Most likely they are out.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  4. Likes Dana liked this post
    Apr 2019
    Yep they're LED but like I said they work fine once I clear the fault code. Thinking about it the previous owner mentioned he'd changed the lights recently (I've only had the car a few weeks). I wondered if they were knock-off lights and were somehow triggering the bulb out warning - I turned off the check but it's still happening. By the way if I clear the error code the lights work fine until the next time I start the car. I'll post the full scan shortly.
  6. Likes Dana liked this post
    Apr 2019
    I've updated my original post with the full scan now.
    I've just cleared the code, the light has gone out on the dash and the lights work normally.
    Restart the car, the code comes back and both rear side lights stop working.
    HQ
    From what I can tell, this looks to be a replacement part number. Is there some back story we should now about?
    Jef
  9. Likes Dana, stashio liked this post
  10. #7
    United States
    I second that. We have Eos scans from this era with 09 modules such as:
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
    Component: Bordnetz-SG H46 1501
    Coding: 058C0F0700041500470A00000F00000000095D035C0000
    Coding: E58E8F0700041500470A00000F00000000095D035C0000
    I'm NOT suggesting pasting shorter 09 coding from another car into this module is going to resolve the problems but someone may have replaced 09/J519 in an attempt to correct this?
    If memory serves, the bold section of the "good" baseline scans is where someone with a Mk5 Jetta or Golf would tweak coding for LED tail light retrofits back in the day. I'm pretty sure all Eos models came with LED factory tails though as golfi_vend suggested and in that case the bold section of the coding may be worth entertaining.
  11. Likes Uwe, stashio liked this post
  12. #8
    Apr 2019
    I've only had the car a few weeks so don't know any of the back story. The previous owner said he'd replaced the rear lights as some of the LEDs had blown but that's as far as he went, didn't mention anything about swapping modules, etc. Interesting! You guys know your stuff.
    So by the sounds of it the module was swapped at some point is that right? I don't quite follow the fix suggested above? I'm fairly new to coding.
    Thank you for your help.
  13. Likes Dana liked this post
  14. #9
    United States
    Flames won't shoot out of the dashboard if you try using a portion of either of my example Eos scan coding strings but as a general rule you don't want to paste long coding from one car into another. Further, they aren't the same length so you would need to manually tweak things.
    So, this is your coding (top) compared to an older/shorter string from a good car:
    I would try this:
    E5048E0700041000400000000F0000000009FF075C000000000000000000
  15. Likes Uwe, stashio liked this post
  16. #10
    Apr 2019
    Thanks Dana, I understand now. I tried the updated code and it's cured the problem for the left side but not the right - so I guess we're on the right track?
    I've done an updated scan:
    Saturday,27,April,2019,11:05:11:20055
       Coding: 0000078
                   P2629 - 004 - Open
                        Mileage: 84358 km
                        Time: 09:39:23
                        RPM: 3137 /min
                        Load: 15.7 %
                        Speed: 64.0 km/h
                        Temperature: 84.0C
                        Temperature: 22.0C
                        Voltage: 13.462 V
                        Mileage: 84378 km
                        Time: 14:17:03
                        RPM: 2211 /min
                        Load: 51.0 %
                        Speed: 63.0 km/h
                        Temperature: 87.0C
                        Temperature: 22.0C
                        Voltage: 13.589 V
       Revision: 00H11001
       Coding: 0004834
       Coding: E5048E0700041000400000000F0000000009FF075C000000000000000000
       Shop #: WSC 12345 123 12345
       Coding: 00038805
       Shop #: WSC 12345
       Coding: 00471077
       Shop #: WSC 12345
                        Reset counter: 48
                        Mileage: 84386 km
                        Voltage: 13.85 V
       Coding: 0013124
       Coding: 0012101
       Coding: 0021403
       Coding: 0655362
       Coding: 0000695
                        Reset counter: 48
                        Mileage: 84353 km
                        Time: 09:18:44
       Coding: 0000694
       Coding: 0040400
                000 -  -
       Coding: 0000128
       Coding: 0000128
    End----------(Elapsed Time: 01:21, VBatt start/end: 14.0V/14.1V)-----------
  17. Likes Uwe liked this post
