Evening RT,
I have a customer that has had some lights on the dash regarding the ABS, plugged it in and noticed the ABS pump coding was all 0000's
I have no original backup to go off and need some help from the higher beings on here lol
Attached is the autoscan from the car with the ABS pump data etc,
I will be going back to the car tomorrow to see if i can try and new coding i am given off here.
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUZZZ8PX9B002856   Mileage: 218640km-135856miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 TP    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  2595
   Revision: --H08---    Serial number: AUX7Z0H5FNQ031
   Coding: 0000071
   Shop #: WSC 00046 412 294912
   VCID: 804CF7FDD333C84A5D-80D4
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller - Intermittent
                    Mileage: 218649 km
                    Date: 2018.10.22
                    Time: 07:55:10
                    RPM: 798 /min
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 00101000
                    Torque: 151.3 Nm
                    Bin. Bits: 00000000
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   Shop #: WSC 55758 001 1048576
   VCID: F6A0912541F7F6FA77-80A2
            000 -  -
                    Reset counter: 244
                    Date: 2018.10.22
                    Time: 08:15:23
                    Count: 4608
                    Count: 195
                    Count: 50432
                    Count: 65024
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH08 0100
   Revision: 000086      Serial number: 8P0820043BG
   VCID: F2A8AD35ED9FEADA5B-80A6
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000008538745
   Coding: F5A83F81B0141380EF00001C0000000000084E0564010403002800000000
   Shop #: WSC 00046 412 57344
   VCID: C8DC2FDDBB83300AD5-809C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 00046
   Coding: 00150573
   Shop #: WSC 00046
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142383038303030374A55305238503053
   Shop #: WSC 00046 412 00000
   ROD: EV_Airba10AURB4.rod
   VCID: C9DA2AD96889C902CA-809C
   Serial number: 3572DRB4000076DC8B00
   Serial number: 3582DRB4000072A4C2D.
   Serial number: 35128RB400003D09BEAZ
   Serial number: 35228RB400003C8AF7B%
   Serial number: 35547RB400003CEE41C/
   Serial number: 35647RB400003CEE490.
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0002042
   Shop #: WSC 00046 412 335872
   VCID: C1CA32F998B9014212-8094
   Component: E0221           H02 0030
   Part No SW: 8P0 920 982 C    HW: 8P0 920 982 C
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 224NH006010063
   Coding: 0004428
   Shop #: WSC 01286 386 08256
   VCID: B93A5A19F06959825A-80EC
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K085098091
   Coding: E9807F061002022103
   Shop #: WSC 00046 412 303104
   VCID: B5225629DC71BDE2BE-80E0
   Revision: D0H18006    Serial number: AUX7Z0H5FNQ031
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000764
   VCID: C3C638F182A5135200-8096
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.078 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: B6205125C177B6FAB7-80E2
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1980200002186D0985054C9FC637
   Shop #: WSC 00088 210 91066
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H04 0020
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674802610203
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000764
   VCID: C4C43BED87AB146A39-8090
Address 56: Radio
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000216
   Shop #: WSC 00046 412 1012544
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000216
   VCID: C2C83DF59DBF1A5A0B-8096
End----------(Elapsed Time: 01:16, VBatt start/end: 14.1V/14.1V)-----------
Thank you
