Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Audi green screen
  1. #21
    Please post a new Autoscan.
  2. Likes Uwe liked this post
  3. #22
    Dec 2016
    DE
    Quote Originally Posted by wuplur View Post
    Looks like it did. 4G1035025F
    Check your PMs
  4. #23
    Jun 2019
    Question I've the same question as the original poster of this thread!
    Hello People,
    I'm resurrecting this old thread as I'm exactly in the same predicament as the thread-starter and have probably the same car as well.
    On my Audi A6 (2015 C7 / 4G facelift Avant), I'm unable to perform the developer mode adaptation of 5F control module as I do not know/have the security access. I'm posting the full VCDS scan below and would appreciate immensely any help and guidance on how to proceed in order to eventually enable Green Screen or Engineering menu in my car.
    Thursday,20,June,2019,21:15:13:08519
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    Dealer/Shop Name:
    Workshop Code:
    VIN: WAUZZZ4G6FN0XXXXX   License Plate:
    Mileage: 91433km-56813mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 28 36 3B 3C 42 44 46 52 53
              55 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
    VIN: WAUZZZ4G6FN0XXXXX   Mileage: 91433km-56813miles
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FQ    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 0655
       Revision: 85H23---
       Coding: 12254012234401080000
       ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
       ROD: EV_ECM20TDI01104L906021FQ_002.rod
       VCID: 79AE1876395B46BF8DB-802C
       Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
       Component: 0CK 20TDI RdW H01 0002
       Revision: --H01---    Serial number: 0000000192
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002014
       ROD: EV_TCMDL382021_AU57.rod
       VCID: 323CEF5AA4AD75E70C1-8066
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 06A29E49604579929B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3FDAB66E67FFA88FF3F-806A
    161024 - Tire Pressure Warning
              C102D 00 [040] - -
                        Mileage: 89356 km
                        Date: 2019.06.06
                        Time: 12:49:11
                        VzRef: 79
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        Uz: BB
                        Unlearning counter according OBD: 25
    161280 - Tire Pressure Warning
              C102D 00 [032] - -
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01A9700E000000000000
       VCID: 7AAC077A3CDD4DA7841-802E
    00955 - Key 1
                        Reset counter: 50
                        Mileage: 91293 km
                        Date: 2019.06.15
                        Time: 17:29:02
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 10021500040856
       Coding: 340209782D0000
       VCID: 63925A1EABD7AC6FB77-8036
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001007965701
       Coding: 0105001440349FE2C101408380001800CF9CC7082E08020100000894E10112020040003D030000
       VCID: 71BE205661AB0EFF35B-8024
       Component: WWS57X 150128  H37 0080
       Serial number:         150203202021
       Coding: 0045F7
       Serial number: 23712486
       Coding: 0200FD
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 06 02 2015  00001605
       Serial number: D499C297000000000001
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 290E0836897B363FBDB-807C
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P10038096
       Coding: 30333130313630323437554A304C34473053
       VCID: 3B22C27E73E7B4AFDF7-806E
       Serial number: 3575HRB405V34OD489EM
       Serial number: 3585HRB405133HNG68KA
       Serial number: 3515JRB40085358S7OPG
       Serial number: 3525JRB406335IMMF1BA
       Serial number: 3554VRB400652RDA4PAK
       Serial number: 3564VRB4006533VUBHQ8
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372OBB00019
       Coding: 0000DD
       VCID: 372ADE4E4F4F90CF3BF-8062
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 27 01 2015  E0078995
       Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
       Component: TDieRdwAcc    H08 0043
       Revision: 04001037    Serial number: 658140215592001
       Coding: 138612000F550008000000
       Shop #: WSC 38916 002 1048576
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3332EA5E5BB77CEF077-8066
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001734972
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75B61446154322DFE93-8020
       Serial number: 5347185803
       Voltage stabilizer:
       Serial number: 14120200000000000421
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0112
       Serial number: 12021500041832
       Coding: 20
       VCID: 3D26CC666DF3BA9FE13-8068
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 43
                        Mileage: 89799 km
                        Date: 2019.06.06
                        Time: 19:44:21
                        Outside air temperature: 19.0 °C
                        Left rear vent temperature: 18.6 °C
       Revision: AA000000    Serial number: 00000134977168
       Coding: 0058130000006001000001010101102030303232203232
       VCID: 77AA1E4E0FCF50CFFBF-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA8208Z64E
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3634D34A48C569C7209-8062
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0360468980
       Coding: 040311
       VCID: 392ED87679DB86BFCDB-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0360399313
       Coding: 040311
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F17015E00628002080013
       VCID: 45D6A48605A3F25FB93-8010
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0004380674
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0359956359
       Coding: 0100063820B93094C32009040E010F470000000000000000000000000000
       Subsystem 1 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS20.403  H03 0004
       Serial number: 0000FST0004DFC800000
       Coding: 901F00
       Subsystem 2 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS20.403  H03 0004
       Serial number: 0000FST0004DCUN00000
       Coding: 801F00
    03128 - Switch 1 for Sunroof
                        Fault Status: 00101100
                        Reset counter: 48
                        Mileage: 89263 km
                        Date: 2019.06.05
                        Time: 17:09:44
    00204 - Sunroof Button (E325)
                        Reset counter: 48
                        Mileage: 89263 km
                        Date: 2019.06.05
                        Time: 17:09:44
       Coding: 011F17015E00628002080002
       VCID: 46D4A38A38A5F947B09-8012
       Revision: --------    Serial number: 00000001357850
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D06FC26BD932A1F513-8078
       Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0081
       Coding: 04FA02202A170200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
       Coding: E01F00
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
       Part No SW: 4G1 035 020 H    HW: 4G1 035 020
       Component: MU-H-ND-EU    041 0924
       Serial number: A590B0F7501530
       Coding: 017502010000000013111102000A00032F0006E5F17001009F
       Shop #: WSC 17616 002 1048576
       VCID: 1E642BEAC035C187D89-804A
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9EY800Q3X
       Multimedia Operating Unit:
       Serial number: 90349OBA000OJ
       Component: Gracenote2  --- 1012
    0014 - Connection between Antenna Amp 1 for Digital Radio and Antenna
              B1274 13 [009] - Open Circuit
                        Reset counter: 250
                        Mileage: 89259 km
                        Date: 2019.06.05
                        Time: 09:54:52
                        Voltage terminal 30: 11.6 V
                        Status of digital radio antenna 1-Antenna current: 0 mA
                        Status of digital radio antenna 1-Connection between radio and antenna amplifier: Electrical OK
                        Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Open circuit
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
       Coding: 010F15004000628002080002
       VCID: 49CEA8B629BB163F5DB-801C
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
       Component: D4-PA RVC Mid H07 0050
       Coding: 027502010201000300
       ASAM Dataset: EV_CamSysRearPANAAU914 002002
       ROD: EV_CamSysRearPANAAU914_VW51.rod
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 027500152
       Coding: 093205C010
       ROD: EV_HDSGAu571.rod
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 6A160000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C00F1228689231746D-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 270A0E0E9F6F004FABF-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000621102157
       Coding: 04C0B9181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313EE056A1AB4EFF75B-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 150160316
       ROD: EV_RDCMA00100_008.rod
    End----------(Elapsed Time: 02:10, VBatt start/end: 12.1V/12.1V)-----------
    Thank you in advance for any help in this regard.
