Results 11 to 20 of 23
Thread: Audi green screen
    Dec 2016
    DE
    Check your Private Messages for a possible fix for the Security Access.
  2. Likes Dana liked this post
  3. #12
    United States
    I added that 5F module to our redirect file. It should make it to the next VCDS Dataversion but you can drop an e-mail to Support with a link to this thread if you need it sooner.
  4. Likes Uwe liked this post
  5. #13
    Nov 2018
    Not sure what this means Dana, what is a redirect file? The next data version means the next update? I downloaded the beta and i can’t use it because my older cable is not compatible. Didn’t think the issue was with VCDS because I get denied with a similar error when using ODIS.
    2016 Audi A6 TDI
    So Cal, USA
  6. #14
    United States
    Hi Manny,
    I believe Daniel (TBAx) set you up with the manual instructions but you need the latest VCDS Beta which requires a current interface. I'm not sure if civilian level ODIS allows you to change diagnostic modes but you would receive an error if it wasn't in developer mode.
    We can resolve this easily. I'll send you a redirect file via email so you can use VCDS Release.
  7. Likes Uwe liked this post
  8. #15
    Nov 2018
    Daniels file worked! Thanks you 2!
    2016 Audi A6 TDI
    So Cal, USA
  9. Likes Uwe, Dana liked this post
  10. #16
    Nov 2018
    Does this feature expire somehow? Developer mode reverted back to “not activated” and I tried to change it back and the 5F won’t accept the S12345 log in anymore.
    2016 Audi A6 TDI
    So Cal, USA
  11. #17
    Dec 2016
    DE
    Normally it should not. I got this once, after the dealer installed an firmware update to the main unit. Other than that (and obviously a swap of the unit) I do not see a reason for this to happen.
  12. Likes Uwe liked this post
  13. #18
    Nov 2018
    It may have reverted back after I had CarPlay installed. How about the user label file you sent me, any reason why that would not work again?
    2016 Audi A6 TDI
    So Cal, USA
  14. #19
    Dec 2016
    DE
    Yes, it should still work. Has the part number changed in the CarPlay activation process? Or asked in another way: the SW part number is still "4G1 035 025 E"?
  15. #20
    Nov 2018
    Looks like it did. 4G1035025F
    2016 Audi A6 TDI
    So Cal, USA
