Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Audi green screen
    Nov 2018
    Audi green screen
    Does anyone know how to activate the green screen for the 2016< MIB C7.5 A6/A7? I’ve seen everywhere that it only applied to the older MMI but now there is someone installing CarPlay in these vehicles and he’s able to activate it.
    https://www.audizine.com/forum/showt...rPlay-actived!
    2016 Audi A6 TDI
    So Cal, USA
    Nov 2018
    Just realized this should probably be moved to “tweaks”
    2016 Audi A6 TDI
    So Cal, USA
    Quote Originally Posted by wuplur View Post
    BAM!
    Nov 2018
    Thanks Uwe. Figured out that it’s the developer mode adaptation in the 5F but it won’t accept my input and just gives me in error. Tried in both VCDS & Odis.
    2016 Audi A6 TDI
    So Cal, USA
    Dec 2016
    DE
    Did you use the special SA (in VCDS) / switch to Engineer session (in ODIS) before changing the adaption?
    Nov 2018
    Please explain, I have no idea what either of those are. Are you referring to the module login access? I went there in VCDS but it did not have a suggested code. Not sure what engineer session is in Odis.
    2016 Audi A6 TDI
    So Cal, USA
  7. #7
    Dec 2016
    DE
    Please post an Auto-Scan for further reference.
  8. #8
    I would suppose it's the same car as he posted about here.
  9. #9
    Nov 2018
    Correct, thanks UWE.
    Here it is to simplify.
    Monday,31,December,2018,11:33:51:59771
    VCDS Version: 18.9.0.2 (x64)
    VIN: WAUFMAFC1GN044315   License Plate:
    Mileage: 11085km-6887mi   Repair Order:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 52 53
              55 5F 62 6C 72 8F 90 AC
    VIN: WAUFMAFC1GN044315   Mileage: 11085km-6887miles
    Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 AA    HW: 4G0 907 401 E
       Component: 3.0TDI FSA    H14 0010
       Revision: 58H14---
       Coding: 0A2A4012052601050000
       Shop #: WSC 14119 002 1048576
       ASAM Dataset: EV_ECM30TDI0114G0907401AA 002009
       ROD: EV_ECM30TDI0114G0907401AA_002.rod
       VCID: 62CBEE0D75A6CA5AA3-8036
    Readiness: 0 0 0 1 1
       Part No SW: 4G0 927 158 AQ    HW: 0BK 927 156 AM
       Component: 0BK 30TDIUSA  H19 1006
       Revision: --H19---
       Coding: 000001
       VCID: 7DF1BD71EC1815A2BE-8028
       Coding: 47A79641E2E569821B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41890181D060B1429A-8014
       Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
       Component: BCM2 2.0      H37 0572
       Coding: 0DA86F4E000000000000
       VCID: 7F0D4779EE1407B2AC-802A
       Serial number: 3215000104981001
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 23061500041829
       Coding: 36013178490000
       VCID: 63C5EB096ABCC352A8-8036
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
       Revision: 21020001    Serial number: 00001100701701
       Coding: 01050011043C9FE08100408780003800CF9CD208A608022180000814F110150200600034030000
       Shop #: WSC 44079 002 1048576
       VCID: 76E3A25DC12E46FAFF-8022
       Component: WWS57X 150531  H37 0080
       Serial number:         150616052211
       Coding: 0045F7
       Serial number: 24044822
       Coding: 02006D
       Component: E1 - LDS  H07 0044
       Serial number: 18 06 2015  00001116
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01FA4865
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA121037000013741817
       Coding: 020300
       Serial number: F16885B7000000000001
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0080
       Revision: --------    Serial number: 56291508303015
       Coding: B83B14
       ASAM Dataset: EV_EPHVA2CAU64X0000 001014
       ROD: EV_EPHVA2CAU64X0000.rod
       VCID: 3663625D89AE06FA3F-8062
    6 Faults Found:
    1080083 - Rear Parking Aid Sensor(s)
              B107B 13 [009] - Open Circuit
                        Reset counter: 230
                        Mileage: 11049 km
                        Date: 2018.12.27
                        Time: 18:10:39
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [009] - Open Circuit
                        Reset counter: 230
                        Mileage: 11049 km
                        Date: 2018.12.27
                        Time: 18:10:07
    1080340 - Parking Aid Speaker
              B107C 14 [009] - Open or Short to Ground
                        Reset counter: 230
                        Mileage: 11049 km
                        Date: 2018.12.27
                        Time: 18:10:05
    1111316 - Speaker for Front Parking Aid
              B10F5 14 [009] - Open or Short to Ground
                        Reset counter: 230
                        Mileage: 11049 km
                        Date: 2018.12.27
                        Time: 18:10:05
    1113874 - Parking Aid Indicator Lamp
              B10FF 12 [009] - Short to Plus
                        Reset counter: 230
                        Mileage: 11049 km
                        Date: 2018.12.27
                        Time: 18:10:05
    12727552 - Databus
                        Fault Frequency: 7
                        Reset counter: 232
                        Mileage: 11049 km
                        Date: 2018.12.27
                        Time: 18:10:06
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0086
       Revision: --------    Serial number: 003G00028K4A
       Coding: 303331343135303334394A55304C34473053
       VCID: 346758559FD214EA01-8060
       Serial number: 6940000Y150001D17500
       Serial number: 3575HRB405J3DASA4100
       Serial number: 3585HRB40553DV8QFGSF
       Serial number: 3515JRB400Q54SDQE1EY
       Serial number: 3525JRB400Q54SDQCORQ
       Serial number: 3554VRB40593F0KQ2ODZ
       Serial number: 3564VRB405L3F0KQF01P
       Revision: C0068538    Serial number: 90862OFH001MA
       Coding: 000034
       VCID: 3B757369BA8CDB92C0-806E
       Serial number: 10 06 2015  G0028216
       Part No SW: 4G8 920 986 R    HW: 4G8 920 986 R
       Component: TDieUsa   Nv  H10 0106
       Revision: 06001087    Serial number: 658220615596042
       Coding: 03EF0A040B41D705020000
       Shop #: WSC 42403 001 104857
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K.rod
       VCID: 479D1F99FE448F7254-8012
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000001900500
       Coding: C0CD078110
       ASAM Dataset: EV_GatewPkoUDS 001028
       VCID: 3B757369B28CDB92C0-806E
       Serial number: 3705017003
       Voltage stabilizer:
       Serial number: 15040200000000000391
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0112
       Serial number: 25061500040754
       Coding: 20
       VCID: 3D717D71AC98D5A2FE-8068
       Revision: AA000000    Serial number: 00000145760815
       VCID: 77FDAF59C6243FF2E4-8022
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720J8AEB
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 33655B499ADC13D218-8066
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0372927037
       Coding: 040211
       VCID: 39796961B8B0E982D2-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0371975844
       Coding: 040211
       Coding: 011F17015E00628002000012
       VCID: 479D1F99F6448F7254-8012
       Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
       Component: RCEPS         H43 0012
       Revision: 00001000    Serial number: 0012933979
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0371680308
       Coding: 0106063A00FA418583A0080402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000296508
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST000DCACB00000
       Coding: 101F02
       Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93569235
       Coding: 011F17015E00628002000002
       VCID: 4683129DF14E967AAF-8012
       Revision: --------    Serial number: 00000001511441
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D514D317CF845224E-8078
       Coding: 04FA021122200400
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 025 E    HW: 4G1 035 025
       Component: MU-H-LNS-US   042 1062
       Serial number: A278F0F7504982
       Coding: 017501020000000013220002041A00102F0006E5F1700104FE
       VCID: 204FA4053B2A984AF5-8074
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9FY801TCZ
       Multimedia Operating Unit:
       Serial number: 90349OFP000W8
       Component: Gracenote2  --- 3006
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 15
                        Mileage: 11049 km
                        Date: 2018.12.27
                        Time: 18:06:14
                        Voltage terminal 30: 14.8 V
                        BAP-BAP_Function_ID: 01
       VCID: 499919A1E050790242-801C
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
       Component: D4-PA RVC Mid H07 0050
       Coding: 027501010201000300
       ASAM Dataset: EV_CamSysRearPANAAU914 002002
       ROD: EV_CamSysRearPANAAU914_VW51.rod
       VCID: 326B5E4D65C61ADA13-8066
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 3169514160C021C26A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 151561097
       ROD: EV_RDCMA00100_008.rod
    End-------------------------(Elapsed Time: 05:41)--------------------------
    2016 Audi A6 TDI
    So Cal, USA
  10. #10
    Nov 2018
    I get an error “request out of range” when the only 2 options are activated/not activated.
    2016 Audi A6 TDI
    So Cal, USA
