Results 1 to 6 of 6
Thread: Audi A3 8V5 2017
    Verified VCDS User langyyyy's Avatar
    Jun 2014
    Slovakia
    Audi A3 8V5 2017
    Need wiring for 5Q0 907 561 G front acc sensor (J428)... What colors to pins. (8 pin)
    I have on car 8 wires, so need connect all 8 PINS.
    Thank you.
    Jun 2014
    Slovakia
    erwin show me just 6pin option....
    May 2017
  6. Likes Uwe, Jack@European_Parts liked this post
    Jun 2014
    Slovakia
    Thank you friend, but there is too just 6pin option.
    Pins 4 and 7 are empty. I have crashed car with 8 wires... and plug to the sensor is broken, pins are outside of plug, so I dont know which wire i have to connect to pins 4 and 7. Somewhere I read that it is heater but not sure how to connect it.
    May 2017
    I can check from ELSA. Heating is not controlled by voltage, it's controlled by CAN. I don't think the pins 4 and 7 are connected actually anywhere. All the pinouts I've seen only have 6 pins defined.
    Edit :
    Unfortunately my ELSA stops at model year 2016. That only has 6 pins connected from the 8 and has been like that since March 2012. Probably the new features introduced for >MY2017 for the front assist require the 4 and 7 to be connected as well, I don't know, sorry.
    You can buy time from Erwin and print the diagrams for that car. Only about 7 € / hour so you'll easily print the ACC diagram and some other stuff as well in that one hour.
  9. Likes Uwe liked this post
