I purchased a set of these, haven't yet installed them, as they require 'provisioning' via VCP. I've checked every high-end garage in the area, can't seem to find one with VCP. Another AudiWorld member has said that he has heard that the latest version of VCDS is, in fact, now capable of making the necessary changes, although he doesn't yet know how to do it. Does any one know if this can be done with VCDS? Thanks for any help anyone can offer.
Here's an auto-scan from earlier today, and the VCP instructions:
Wednesday,24,April,2019,16:28:50:31486
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4437.4
VIN: WUARWAF55JA904570 License Plate:
Mileage: 11048km-6864mi Repair Order:
Chassis Type: F5-AU49 (8W8)
Scan: 01 02 03 06 08 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46
47 52 5F 65 6C 74 81 82 8B A5 A9 CA CF D6 D7
VIN: WUARWAF55JA904570 Mileage: 11048km-6864miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DECA) Labels: None
Part No SW: 8W0 907 551 A HW: 06M 907 309 H
Component: V6 2.9l TFSI H11 0002
Revision: B9H11000
Coding: 1A2A00322566080E34280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM29TFS0118W0907551A 001002
ROD: EV_ECM29TFS0118W0907551A.rod
VCID: 3B36DABDB21F5E92C8-806E
10537 - Evap System Leak Detection or Fuel Vapor Temp Sensor
P2026 00 [032] - Signal too Low
4814 - System Voltage
P0562 00 [032] - Too Low
12352 - Coolant Pump for Intercooler
P023A 00 [032] - Open Circuit
34209 - Exhaust Pressure Control Valve 2
P04A0 00 [096] - Regulation Fault
33795 - Unknown Error Code
P25B4 00 [096] - -
Mileage: 10984 km
Date: 2019.04.21
Time: 15:04:53
Engine speed: 1283.50 /min
Normed load value: 7.5 %
Coolant temperature: 54 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.640 V
Unlearning counter according OBD: 38
Engine status: COENG_RUNNING
16516 - Fuel Trim; Bank 1
P0172 00 [096] - System Too Rich
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 8W0 927 158 L HW: 0D5 927 156 H
Component: 0D5 29TSIUSA H05 1001
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002013
ROD: EV_TCMALX52011.rod
VCID: 4BD68A7DE2BFEE1278-801E
Part No SW: 8W0 907 379 AA HW: 8W0 907 379 AA
Component: ESP9 Premium H13 0200
Coding: 50AA6C9A30A28A9A11A34898427D18A2E6259A0A360C51881242184567A459
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 044461418F61E16AF9-8050
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M2 959 760 A HW: 4M2 959 760 A
Component: MEM-BFS 009 0042
Serial number: 00000322874830
Coding: 00163004000CB2010003010141010000000000000000000000000000802002
Shop #: WSC 06325 790 00001
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 383CC5B18329758A25-806C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0210
Coding: 4608050D4544010D10020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44C4A141CFE1216AB9-8010
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002404430
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: A2E2D42900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501D63E0690CCD050D591918AD9CBA110B3D040000000000000000200016010A69012B825709
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 024867599575EF5ACB-8056
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 050418 036 0471
Serial number: 00000001803290303034
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21424932X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AL HW: 4M0 941 531 AL
Component: E1 - LDS H06 0008
Serial number: 12 01 2018 01260031
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z00TT02
Coding: 350000
Garage Door Opener Operating Unit:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180508043837 00408
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE126021823610075
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00805969
Subsystem 8 - Part No SW: 8W0 925 301 M HW: 8W0 925 301 M
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000035701003
Valve Block 1 In Driver Side Front Seat:
Subsystem 9 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0036
Serial number: 7008174235B181742679
Coding: BF0500
Valve Block 1 In Passenger Side Front Seat:
Subsystem 10 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0036
Serial number: 7008174235B181743088
Coding: B30500
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 C HW: 8W0 907 561
Component: LRR4 H10 0340
Coding: B4779FF258FFEC05757A61A1
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X.rod
VCID: 3E30D3A9A10D4BBAEF-806A
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 J HW: 8W0 959 655 J
Component: Airbag10.44 H09 0107
Serial number: 003US000KUL3
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 50EC9D110B99CDCA0D-8004
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W6857705D0044S00004
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W6857706D0030S00085
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180009DOXU0B
Subsystem 4 - Part No SW: ----------- HW: 442 061 505 18
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00A72771CD374CC
Subsystem 5 - Part No SW: ----------- HW: 442 061 505 18
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00A92771CD134B8
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 405 18
Component: SideSensor_Dr 1C7 0148
Serial number: 35177009D296E60662EO
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 405 18
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700C72A2D0F13238
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 605 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C929A7886B13P
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C0 605 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C929A7884D34T
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 LL HW: 4M0 907 129 LL
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 05427C45845BD862EE-8050
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H19 0377
Coding: 050F21CF7CA8000802B3ED641800401000000000
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU49.rod
VCID: 43C6A25DCAEF265280-8016
Part No SW: 8W8 907 468 F HW: 8W8 907 468 E
Component: Gateway H42 0123
Revision: 7D000001 Serial number: 0187D520618516
Coding: 03010001000002405407000000590012FC980007920000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4FEE9E6D16A7D23214-801A
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180509065533 30431
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 9607457504
Part No SW: 8W0 907 144 J HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0710
Serial number: 30303030303030
ASAM Dataset: EV_SCUZFLSAU49X 002019
ROD: EV_SCUZFLSAU49X_002.rod
VCID: 42C8A759D5F52F5A8B-8016
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
ROD: EV_LCMLeftHELLAAU736_VW48.rod
VCID: 78BC05B1C3A9B58AE5-802C
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605819312201207
Coding: 0003
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 79BA00B5F8A3AC829A-802C
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 009 0042
Serial number: 00000321428078
Coding: 001E3B04000CB2010003010141010000000000000000000000000000802002
ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 3620CB89893D83FA37-8062
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0129
Serial number: 0000321120050
Coding: 005D4B425E0010A5000124B2
196742 - Belt feeder
B1546 01 [008] - Electrical Failure
Fault Frequency: 158
Reset counter: 109
Mileage: 638 km
Date: 2018.07.23
Time: 19:22:35
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 85008380000080
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Coding: 011200004FB00080658FA0006E01000233000000810126502F0400000B04003D201E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 014A68559073F442D2-8054
Ignition key:
Subsystem 1 - Part No SW: 8W0 959 754 BN HW: 8W0 959 754 BN
Component: ID-Geber H40 0105
Serial number: 3618000071627009
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY181031BB0
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099611456
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Reset counter: 109
Mileage: 419 km
Date: 2018.07.16
Time: 14:24:53
Supply voltages-Supply voltage: Terminal 30: 12.854 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.881 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.854 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 00 80
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAJJA043JSF
Coding: 0194040800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
VCID: 76A00B89C9BDC3FAF7-8022
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0129
Serial number: 0000320933378
Coding: 005D4B425E0010A5000124B0
Reset counter: 93
Mileage: 10279 km
Date: 2019.03.21
Time: 19:47:38
Part No SW: 8W5 035 880 D HW: 8W5 035 880
Component: MU-P-LNS-US 034 1320
Serial number: A798E0JB100155
Coding: 019464020000000053220002041A00002F0013E401700104BE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 40CCAD51DBF93D4A9D-8014
Subsystem 1 - Part No SW: V03 959 802 DK HW: -----------
Component: NAR 2018/2019 --- 0066
Subsystem 2 - Part No SW: 8W0 919 605 HW: 8W0 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9JBJ04WTG
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK130041800040618
Component: Gracenote2 --- 3012
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0010
Serial number: 40000000017268
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 2F2EFEED7667B23274-807A
8390147 - Tire Pressure Monitoring
C10DC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 106
Mileage: 10982 km
Date: 2019.04.21
Time: 13:48:10
Expanded ambient data 1-Left front tire pressure sensor: identification: Not available
Expanded ambient data 1-Right front tire pressure sensor: identification: Not available
Expanded ambient data 1-Left rear tire pressure sensor: identification: Not available
Expanded ambient data 1-Right rear tire pressure sensor: identification: Not available
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG065665
Coding: 02940402BA0FA10038004004
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
VCID: 3522CC85943B88E23E-8060
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 Q HW: 8W0 907 777 C
Component: Fahrwerk-SG H37 1251
Serial number: 1205180431
Coding: 546040315A
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
VCID: 55E26C05347BA8E2DE-8000
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 F HW: 4M1 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18051047277675
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736_AU49.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W6 919 617 HW: 8W6 919 617
Component: HeadUpDisplay H09 1640
Coding: 4F01D0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736.rod
VCID: 06407B49B95DD37AE7-8052
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 C HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X.rod
VCID: 3C34D9A1B71159AAC1-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H16 0050
Coding: 040409040000020301202386A50000FCB0F0C020C020
ROD: EV_BVSMLBevKOSTAAU736.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number: 180405202364
VCID: 41CAA855D0F3344292-8014
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 208000049401
VCID: 3D32D4A5AC0B50A2F6-8068
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 3326F29D9A4F96D210-8066
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 177E260DEEF75AF20C-8042
Component: LED1R H09 0008
End----(Elapsed Time: 02:23, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Setting Parameters with VCP
- Before proceeding with this portion of the installation please check for basic
functionality on all four taillights, though some functions will have changed
- If you do not have some functionality please stop and contact for assistance
Vag Can Pro is REQUIRED for completing this portion of the installation
- Open the VCP Activator with VCP plugged into your laptop
- Click Recheck Dongle, Click the picture with green arrow, Click Connect
- Click File Management, in the search window type 8W0907064, Click FindNext
- Find this file and download it: BCM2_s5_8w0907064dc.zdc
- Once you have downloaded the proper file please follow the instructions below:
Video Example - https://www.youtube.com/watch?v=jOxtS-uNoqg
*Note video shows slightly older version of VCP
- Click Guided Function
- Click the Apps radio button on the right
- Select Upload Parameter Data
- Click Next 3 times until the Config Data Uploader window appears
- Click Open ZDC File
- Locate the needed ZDC file and click Open
- Select 46 Central Module Comfort System from the list of ECUs
- In the Data to Upload portion of the window select:
Select: LAMPCONFIG_1_COUPE_LHD_LED_EU
- Click Upload Selected Data
- Wait for the lower left hand corner to state ECU Flashing Finished Successfully!
- Continue to select the following and Upload each in order:
LAMPCONFIG_2_COUPE_LHD_LED_EU
LAMPCONFIG_3_COUPE_LHD_LED_EU
LAMPCONFIG_4_COUPE_LHD_LED_EU
LAMPCONFIG_5_COUPE_LHD_LED_EU
LAMPCONFIG_6_COUPE_LHD_LED_EU
LAMPCONFIG_7_COUPE_LHD_LED_EU
- After each you should receive a successful flashing message
- Click Close
- On the next window click Next and Finish
- Clear all trouble codes with the Erase Errors button on the VCP home screen
- Check for proper functions of each light individually. Parking lights, headlights, turn
signals, hazards, rear fog light, brake and reverse
- IF all functions are working properly without any bulb errors on the dashboard all of
the panels that were removed or loosened can be put back into place and the installation
is complete.
- IF any functions are NOT working properly please stop work and contact for assistance
