Results 1 to 2 of 2
Thread: Transporter T5 GP retrofit Mk100 ABS from T6
Hybrid View
    Jan 2019
    Hallo @all.
    I am retrofitting the ABS from the T6 back into my T5 GP.
    To do this i analysed about 50 Autoscans from T6 to understand the Coding.
    My findings i already posted here: https://forums.ross-tech.com/showthr...l=1#post154762
    I did a lot of testing on the Bench over the Winter, now the ABS is in the Car and i am facing one last Error, whell two, but for the "Airbag_03 frame timeout" error i already have the solution, i just need Airbag Controller from T6.
    Now the Last Error wich i dont understand:
    8324 - Databus
              U1122 00 [137] - Implausible Message
              [ACAN: LW1_ID wrong value]
    What does this Error mean, from which ECU is this CAN Message comming ?
    Autoscan:
    Wednesday,24,April,2019,20:47:53:01479
    VIN: WV2ZZZ7HZEH______   License Plate: T6_ABS_OHNE_BERG
    Mileage: 166000km-103147mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 10 15 17 18 19 22 25 2E 37 3C 55 56 61 69
              6C 6E 77 0B
    VIN: WV2ZZZ7HZEH______   Mileage: 166000km-103147miles
    2E-Media Player 3 -- Status: Malfunction 0010
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 906 019 HM    HW: 03L 907 309 L
       Component: R4 2,0L EDC   H38 8375
       Revision: 22H38---    Serial number: 00000000000000
       Coding: 0125401A233601080000
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_ECM20BTD01103L906019HJ 003005
       ROD: EV_ECM20BTD01103L906019HJ.rod
       VCID: 7DA60C6E3D71329FF5B-8028
       Part No SW: 0BT 300 011 Q    HW: 0BH 927 711 G
       Component: DSG DQ500-7A  H11 2236
       Revision: 00H11V01
       ROD: EV_TCMDQ500021.rod
       VCID: 3C20C16A66EBFB97825-8068
    Address 03: ABS Brakes (J104)       Labels:. User\TEST-03.lbl
       Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 43036000000361
       Coding: 517E809865__80__8A__01__A6__0196380000
       VCID: 40D8B59A0A039F77DED-8014
    8229 - Databus
              [ACAN: Airbag_03 frame timeout]
                        Reset counter: 38
                        Mileage: 166000 km
                        Date: 2019.04.24
                        Time: 00:27:25
    8324 - Databus
                        Reset counter: 38
                        Mileage: 166000 km
                        Date: 2019.04.24
                        Time: 00:27:19
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
       Component: ClimatronicT5 H19 0407
       Revision: 00001004
       Coding: 0000000103
       Shop #: WSC 02756 790 50316
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 698E483E59F9BE3F293-803C
       Slave 1:
       Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
       Component: Heckbedienung  H10 0202
       Serial number: BHB-0010710130015098
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 090 B    HW: 7H0 937 090
       Component: BCM PQ25 Max4 H74 0712
       Revision: B9074001    Serial number: 0571 284130784
       Coding: E0A0393A0A21201301280F716EEB8FD50290662F7E857801320000020000
       VCID: 2D06FC2EAD11621F05B-8078
       Component: RLS 071013 05  54  0403
       Coding: 02252E
       Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8652
       Serial number: KU0KU008101300018609
       Coding: 0400A1
       Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8652
       Serial number: KU0KU002101300011203
       Coding: 1400A1
       Subsystem 4 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6  H07 0022
       Serial number: 70000000000000636886
       Coding: E20000
       Part No SW: 7E0 919 475 L    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0106
       Revision: --------    Serial number: 28261326801945
       Coding: 318102
       ASAM Dataset: EV_VW75XParkAssis8K 001003
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: 3B22C27663E5FCAF8BF-806E
       Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
       Component: VW10Airbag003 H07 0013
       Revision: --------    Serial number: 003HM003VZ7W
       Coding: 000000000000000000000000000000003033
       Shop #: WSC 02754 790 50316
       VCID: 3634D34258C721C7741-8062
       Serial number: 3495ZRB400250KJKP1GY
       Serial number: 3505ZRB400450KJKN9O%
       Serial number: 3515ZRB400450KJKR8R6
       Serial number: 3525ZRB400450KJKDQ1S
       Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
       Component: KOMBI         H03 1104
       Coding: 050F010300
       VCID: 3A2CC7726CDFC5A7909-806E
       Part No: 7E0 819 008 F
       Component: J737__Standheizung  0605
       Revision: 00086000    Serial number: 09024901A00000
       Coding: 0021332
       Shop #: WSC 02757 790 00000
       VCID: 2C00F12A9A0B6B17125-8078
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H74 0712
       Revision: B9074001
       Coding: 042200
       VCID: 70B8255A7AA34FF76ED-8024
       Part No SW: 09N 907 554 B    HW: 09N 907 554 B
       Component: Haldex 4Motion      6008
       Coding: 0000001
       Shop #: WSC 02756 790 00000
       VCID: 372ADE46534DD8CF6F7-8062
       Component: IMMO          H03 1104
       VCID: 6A8C37325CFFB527209-803E
       Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
       Revision: A1001003    Serial number: 7665304253
       Coding: 010100
       VCID: 2B02F23693056C2F1BF-807E
    03138 - Input AUX IN
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 38
       Part No SW: 7E0 035 680 B    HW: 7E0 035 680 B
       Component: RNS-MID       H09 5274
       Revision: AB001001    Serial number: VWZ6Z7N7280058
       Coding: 04000402040000A00014
       Shop #: WSC 02754 790 00000
       VCID: 2410190AFEDBA357DA5-8070
       Component: EU West V15  8515
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
       Component: J0769 SWA MasterH13 0120
       Revision: 00H13000    Serial number: 6PZ 009 014-07
       Coding: 0010161
       VCID: 2F3AE626AB1D100F377-807A
       Subsystem 1 - Part No: 7E0 907 568 B
       Component: J0770 SWA Slave H10 0120
       Subsystem 2 - Serial number: 6PZ 009 014-27
       Subsystem 3 - Serial number: 5F26.09.1300H10000AMS14437\FF
       Subsystem 4 - Serial number: S14437\FF
    Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
       Part No SW: 6R0 907 357     HW: 6R0 907 357
       Component: LWR-ECU       H02 0070
       Coding: 028A000001000000
       Shop #: WSC 02757 790 50316
       ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
       ROD: EV_HeadlRegulVWLWRPt_VW25.rod
       VCID: 77AA1E461F4D18CFAF7-8022
       Part No SW: 7H0 907 534     HW: 7H0 937 090
       Component: Batt.regelung H74 0712
       Coding: 330B1A73
       VCID: 6B8232365385AC2F5BF-803E
       Subsystem 1 - Part No SW: 7E0 915 181 D    HW: 7E0 915 181 D
       Component: J367-BDM  H08 0182
       Serial number: 50262E43111931975854
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Anhaenger     H10 0110
       Revision: 3B001001    Serial number: 00000194554106
       Coding: 410D000101000000
       VCID: 313EE05EB12906FF213-8064
       Part No SW: 7E0 907 441     HW: 7E0 907 441
       Revision: 00H12000    Serial number: 525PA8-J390101
       Coding: 0030015
       VCID: 6596440EB9619A5F0DB-8030
    Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
       Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
       Component: Dachdisplay   H15 0185
       Revision: 10100011    Serial number: 308907
       Coding: 000203
       VCID: 3536D44E45412ADF7DB-8060
    Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
       Component: Telefon       022 0971
       Revision: --------    Serial number: 35502105055314
       Coding: 020101000100000000000101
       ASAM Dataset: EV_UHVPremi 002709
       ROD: EV_UHVPremi.rod
       VCID: 2410190AFE5BA357DA5-8070
    End----------(Elapsed Time: 02:19, VBatt start/end: 13.0V/13.0V)-----------
    Jan 2019
    Whell, since no one helped, i had to find it myself.
    8324 - Databus
    LW ==> German: Lenkwinkelsensor ==> Steering Angle Sensor
    Simply needed to change to the T6 Steering Angle Sensor
  3. Likes Uwe, m87a liked this post
