HN network profile count lower after delete profile
ninethree2cc
Minnesota USA
C?ID=258688
I found something that may or may not be normal, and figured I would ask since I couldn't find the answer using the forum search.
I recently removed a network profile from my HN. after removing, I had 7 total profiles available rather than 8. Is this normal?
does the count only reset to 8 if you perform the 45-50 second button hold to reset all network profiles?
If this is normal I'll just forget about it. I don't anticipate needing 7 unique network profiles...
DGMotors
C?ID=57532
I think 1 is always the AP mode setting for a direct connection to the hexnet. so 1 is AP and 7 are infrastructure
ninethree2cc
Minnesota USA
C?ID=258688
Correct, profile 1 is AP mode, after removing one profile I now have 6 profiles for infrastructure mode and 1 profile for AP mode
Shaun
It sounds like a bug... how did you delete the profile, through VCI-Config or VCDS-Mobile? Does it come back if you do a 45-second button reset?
Mike@Gendan
Swansea, UK
C?ID=57030
Just tried this on our test interface.
Connected to Wi-Fi via VCI-Config then checked profiles in VCDS-Mobile.
Removed and re-added via VCI-Config, and sure enough, one less profile:
ninethree2cc
Minnesota USA
C?ID=258688
I've been making changes to the network profiles via VCDS-Mobile UI. The SSID for main network doesn't show up in VCIConfig.
The 45-50 second reset puts the profile count back to 8.
