Results 1 to 7 of 7
Thread: S7 C7 ABS Brake Bleed
    Apr 2019
    Hello guys,
    A simple question for the pros. I need to run the ABS pump to bleed it. I've seen videos that use 03- ABS Brake / Output Tests-03, however I don't see the same function for my platform.
    Tuesday,23,April,2019,16:21:27:62274
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUW2AFC6DN15xxxx   License Plate:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 3C 42 44 46
              47 52 53 55 56 5F 62 6C 6D 72 8F 90 A9 BA
    VIN: WAUW2AFC6DN15xxxx   Mileage: 89795km-55796miles
    Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 014 B    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0009
       Revision: NCH62---
       Coding: 1A2500326526000E1000
       Shop #: WSC 54979 001 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906014B 001009
       ROD: EV_ECM40TFS0114G0906014B.rod
       VCID: 21486FAF303AA842F2-8074
       Part No SW: 4G1 927 156 S    HW: 0B5 927 156 J
       Component: 0B5 40TFSINAR H02 0014
       Revision: --H02---
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_TCMDL501021 001025
       ROD: EV_TCMDL501021.rod
       VCID: 3D70B3DFAC82ECA2F6-8068
       Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
       Component: ESP PREMIUM   H09 0361
       Coding: 65B64F03A66DF2C05B00
       VCID: 3662ACF389B43FFA37-8062
       Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
       Component: BCM2 2.0      H33 0433
       Coding: 0D8A2006000000000000
       VCID: 7BF47DC7FA16229288-802E
       Serial number: 2313000069846012
       Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
       Component: KLIMA 4 ZONEN H13 0086
       Serial number: 26041300041117
       Coding: 688320B849
       ASAM Dataset: EV_AirCondiComfoUDS 002040
       VCID: 62CA20A375BCF35AAB-8036
       Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
       Revision: 11012002    Serial number: 00000001718331
       Coding: 02002091163C9FE0E90088C7A0003928CF9CD208A2080221800008406000
       Shop #: WSC 28826 002 1048576
       VCID: 6FEC5997BE6E4E3234-803A
       Component: WWS57X 130420  H36 0080
       Serial number:         130424135221
       Coding: 0045F7
       Serial number: 21261670
       Coding: 02006E
       Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
       Component: E1 - LDS  H07 0044
       Serial number: 10 04 2013  00000446
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R5NCF02
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA105265000003440253
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 532947A6000000000001
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Revision: 11001001    Serial number: 61061311501358
       Coding: A8C109
       VCID: 71E85FEFA05A58C222-8024
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H33 0033
       Revision: --------    Serial number: 003D8002Z9SC
       Coding: 303145313131303030314A55304C34473853
       VCID: 336495E79AC62AD210-8066
       Serial number: 6940000Y130000SPJ808
       Serial number: 3575HRB400I50FIII8JQ
       Serial number: 3585HRB40044UO4C98RU
       Serial number: 3515JRB400450HHSRH1J
       Serial number: 3525JRB400650HQ6HHUS
       Serial number: 3554VRB400Q50H9MR97/
       Serial number: 3564VRB401050H9MM1VR
       Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
       Revision: --------    Serial number: 90372MDM0011V
       Coding: 000434
       VCID: 387EA2CB8BA0C98A25-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 02 04 2013  D0191924
       Part No SW: 4G8 920 983 R    HW: 4G8 920 983 R
       Component: TBenUsa   Nv  H76 0515
       Revision: 30460214    Serial number: 658230413596025
       Coding: 0BEF01079B43CF05020300
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K.rod
       VCID: 4486C63BCF689D6AB9-8010
       Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000000917779
       Coding: 00E1034800
       ASAM Dataset: EV_GatewPkoUDS 001018
       Serial number: 5387120403
              U140B 00 [008] - -
                        Reset counter: 153
                        Mileage: 89795 km
                        Date: 2019.04.22
                        Time: 17:21:21
                        Voltage terminal 30: 11.0 V
                        Voltage terminal 15: 11.0 V
                        Control Module temperature: 25 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 1
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0013
       Serial number: 001904130001530
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       VCID: 275C71B75E1E5672BC-8072
       Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
       Component: KLIMA FOND    H07 0086
       Serial number: 26041300040374
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
       VCID: 377CA1F78EBEC6F22C-8062
    0025 - Motor for Rear Left Upper Body Vent
              B10D3 22 [008] - Signal Amplitude Too High
                        Fault Frequency: 143
                        Reset counter: 130
                        Mileage: 84877 km
                        Date: 2018.09.26
                        Time: 15:25:25
                        Voltage terminal 30: 14.48 V
                        Outside air temperature: 22.0 °C
                        Left Rear Upper Body Vent Motor-Act.val.: 11721
                        Left Rear Upper Body Vent Motor-Specified value: 11721
                        Left Rear Upper Body Vent Motor-Stop open: 11420
                        Left Rear Upper Body Vent Motor-Stop closed: 10000
    0026 - Motor for Rear Left Upper Body Vent
              B10D3 21 [008] - Signal Amplitude Too Low
                        Fault Frequency: 37
                        Reset counter: 117
                        Mileage: 85977 km
                        Date: 2018.11.14
                        Time: 12:11:13
                        Voltage terminal 30: 14.39 V
                        Outside air temperature: 13.5 °C
                        Left Rear Upper Body Vent Motor-Act.val.: 9699
                        Left Rear Upper Body Vent Motor-Specified value: 9699
    0036 - Motor for Rear Right Upper Body Vent
              B10D4 31 [009] - No Signal
                        Reset counter: 102
                        Mileage: 84774 km
                        Date: 2018.09.20
                        Time: 09:26:14
                        Voltage terminal 30: 13.70 V
                        Outside air temperature: 18.5 °C
                        Right Rear Upper Body Vent Motor-Act.val.: 10052
                        Right Rear Upper Body Vent Motor-Specified value: 0
                        Right Rear Upper Body Vent Motor-Stop open: 11428
                        Right Rear Upper Body Vent Motor-Stop closed: 10000
       Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
       Coding: 008000
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E52849371E4073A7F-807A
    403200 - Function Shut-Off Active
              C10C8 00 [009] -  -
                        Reset counter: 113
                        Time: 00:00:00
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000058915609
       Coding: 00581B0000002001000001010101102030303232203232
       VCID: 77FC61F7C63E06F2EC-8022
       Component: SARA 6D red   H02 0056
       Revision: --------    Serial number: EJ1BPA7E00ET3I
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 J    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0050
       Revision: 00H04000    Serial number: 6PZ 010 287-08
       Coding: 0000003
       VCID: 3662ACF341B43FFA37-8062
       Subsystem 1 - Part No: 4G0 907 568 J
       Component: J770  SWA Slave H04 0050
       Subsystem 2 - Serial number: 6PZ 010 287-28
       Subsystem 3 - Serial number: 5F25.04.1300H04000AMS15405˙
       Subsystem 4 - Serial number: S15405˙
       Coding: 011F57025E00628002000412
       VCID: 479CD137F65EB6725C-8012
       Component: RCEPS         H36 0010
       Revision: 00001000    Serial number: 0013052368
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 326A90E365DC23DA1B-8066
       Revision: 00002001    Serial number: 0306272248
       Coding: 0126023A20FAF08580B00A8002010D000000000000000000000000000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000147335
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO2162635%
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00003345666
       Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA106021000003548040
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 14
                        Reset counter: 179
                        Mileage: 84780 km
                        Date: 2018.09.20
                        Time: 10:02:53
    02615 - Fuel Tank Cap; Lock
                        Fault Frequency: 7
                        Reset counter: 177
                        Mileage: 84803 km
                        Date: 2018.09.22
                        Time: 10:27:04
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000007943
       Coding: 030000
       VCID: 1C365E5B1F5885AA21-8048
       Coding: 011F57025E00628002000402
       VCID: 4682DC33F154AF7AA7-8012
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000663440
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B548D8742F6721258-807E
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0020
       Serial number: 130426-0004-099
       Coding: 12236F33701AA400
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H01 0031
       Coding: 3A0000
    H01 0031
       Coding: 3A0000
       Part No SW: 4G0 035 082 E    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 156D 0D7720584
       Coding: 020007010000000001
       VCID: 224A60A33D3CB35AEB-8076
       Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
       Component: H-BNT-NA      H50 0622
       Revision: --------    Serial number: 194D20D7531598
       Coding: 0A0200040203F1EF55128B1E00000003100001000000000000
       VCID: 285E728B5B00590AB5-807C
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD001KDU6
       Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
       Serial number: 90349MDU00054
       Component: CD-Database  4949
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 123
                        Mileage: 89183 km
                        Date: 2019.03.29
                        Time: 12:39:01
                        Voltage: 12.10 V
       Coding: 010F17024000628002000002
       VCID: 4998D70FE04A40024A-801C
       Part No SW: 4G0 907 441 B    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H06---    Serial number: 525 PA8J34G3I5
       Coding: 1080013
       VCID: 26427CB391144F7A87-8072
       Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
       Component: HDSG-Modul    H13 0043
       Revision: 12013001    Serial number: 101300050
       Coding: 0A3305C102
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571.rod
       Coding: 0006E008031F0300070308014244CA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 31689FEF60DA18C262-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 130322200307
       VCID: 2C568E9B47F8752A51-8078
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H05 0006
       Revision: 00001001    Serial number: 97804001845804
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X_AU57.rod
       VCID: 66C23CB399948F7A47-8032
    End-------------------------(Elapsed Time: 07:03)--------------------------
    Curious: What have you done to your ABS pump that makes you think you need to do anything involving a scan tool to bleed it?
    FWIW, your ABS should have this Output Test:
    IDE03309-MAS01168 -- ABS return flow pump
    Apr 2019
    I had to deplete the brake system of fluid in order for some brake upgrades. Unfortunately, IDE03309- ABS return flow pump does not activate the pump. Once I select the output "ABS return flow pump" and click start, the dash beeps four times and immediately says "not running". I'm on version 18.9.1
    I can post a video if that helps.
    Just gravity bleed it and then vacuum bleed it from outlet ports or calipers.
    ABS pumps are free flowing at all times during being static and only close ports when in use by the EDL/HH or pulsed interference for stopping.
    It doesn't pay to use the ABS pump when possibly has air in it and should not be put through such a cycle before mechanical manual bleeding is done.
    Don't circumvent & try to shortcut shit!
  5. Likes Dana liked this post
    Dec 2016
    Amsterdam
    This^
    And when there really is no bleeding procedure, you can always (after properly bleeding it the normal way) engage the ABS during a test drive and then bleed it again with a vacuum bleeder. Engaging the ABS pump is what youre after anyway when trying to bleed air stuck inside the unit.
    Current:
    United States
    I absolutely agree with the above suggestions, meaning I never attempt to use a scan tool before all of the conventional methods have been exhausted when it comes to brake bleeding, however there are specific instructions in VCDS when you click on Basic Settings and select [ENG108448-ENG102674] RepairBleed - Bleeding_Phase.
  8. Likes Jack@European_Parts, Uwe liked this post
    A scan tool is not a substitute nor should it be relied on to perform "mechanical tests" or "work procedures" unless part of the written work procedure in the RTFB & or required during a calibration.
    Better than half the problems today with failure to diagnose a condition have become a reliance on OBD2 quasi tests with replacement of a component because it has a DTC and often mechanical or electronic DVOM tests or work operations are now being ignored or forgotten because of stupidity and laziness or too pay attention to basics or design and function familiarity of details!
    Mechanical tests in the end will always show the FOD too!
  10. Likes Uwe, Dana, Bruce liked this post
