4.2 a8 with a clogged dpf
Grantus
England
C?ID=366283
Hello and first post after lots and lots of looking
I have a 2007 a8 4.2 tdi with a clogged dpf code bank 1.. regen runs were attempted when the warning was on the dash but unfortunately it didn't clear the problem
skip forward a month and I purchased vcds with the intention of forcing a regen
I foolishly imagined it would be intuitive and fairly straightforward
skip on another few weeks of frustration and annoyance and im posting on here to get some help
I think I need a code for engine ii to force regen but everything ive tried seems to come up with a fail
here is my autoscan
if its in the incorrect format apologies
forgot to mention the dpf sensor was replaced thinking it was that as I heard a click when the original engine warning lamp came on, although it may have been a relay
Tuesday,23,April,2019,16:12:20:06585
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
VIN: WAUZZZ4E77N017251   License Plate: LV57USG
Mileage: 286500km-178022mi   Repair Order: 77
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 28 34 36
          37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
VIN: WAUZZZ4E77N017251   Mileage: 286500km-178022miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
65-Tire Pressure -- Status: Not registered 0011
   Part No SW: 4E1 910 409 B    HW: 4E1 907 409 A
   Component: 4.2L V8TDI  G000AGMª0010
   Revision: --H04---    Serial number: AUX3Z0G1315815
   Coding: 0011773
   Shop #: WSC 02313 785 00200
   VCID: 2313EEE9C7D4638FA3F-8076
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 001 - Restricted/Clogged
                    Fault Status: 11100001
                    Mileage: 286507 km
                    Date: 2019.04.23
                    Time: 15:25:11
                    (no units): 51.0
                    (no units): 51.0
                    Pressure: 0 mbar
                    (no units): 41.0
                    (no units): 41.0
                    Pressure: 0 mbar
                    Temperature: 98.6°C
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 S    HW: 09E 927 156 B
   Component: AG6 09E 4,2 TDI RdW 0010
   Revision: --H01---    Serial number:        0102169
   Coding: 0000001
   VCID: 33331EA97734F30F53F-8066
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0008557
   Shop #: WSC 02313 000 00000
   VCID: 221DEBEDD8CE6A87A89-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0G1315815
   Coding: 0412672
   Shop #: WSC 02311 785 00200
   VCID: 58E98905CE12F05786D-800C
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 1940
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   VCID: 2411EDF5C2DA64B7DA5-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 769 Q    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 300BR077578826
   Shop #: WSC 00272 210 89997
   VCID: 3A2D338D505E0247909-806E
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000093790
   Subsystem 3 - Serial number: 0115.07.100000000100010002ÿ
   Subsystem 4 - Serial number: 010002ÿ
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000114745
   Coding: 0088145
   VCID: 1C61D515FAAA5C77625-8048
00065 - Rear Left Footwell Heater (Z42)
                    Reset counter: 45
                    Mileage: 286409 km
                    Date: 2019.04.18
                    Time: 16:20:46
                    Voltage: 11.40 V
00066 - Rear Right Footwell Heater (Z43)
                    Fault Status: 01101100
                    Reset counter: 45
                    Mileage: 286409 km
                    Date: 2019.04.18
                    Time: 16:20:47
                    Voltage: 11.40 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0143121
   VCID: 363527BD6446E627741-8062
   Subsystem 1 - Part No: 4E2 910 113 C
   Component: Wischer WWS D3  H60 0440
   Coding: 00000034
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00139548
   Shop #: WSC 02313
                    Reset counter: 89
                    Mileage: 286409 km
                    Date: 2019.04.18
                    Time: 16:28:55
00908 - Control Module for Wiper Motor
                    Reset counter: 89
                    Mileage: 286500 km
                    Date: 2019.04.23
                    Time: 13:59:50
Address 0E: Media Player 1        Labels:
   VCID: 55F78031DC00CD3F9DB-FFFE
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276U8100762
   Coding: 0000001
   Component: 4.2L V8TDI  G000AGSª0010
   Coding: 0011773
   Shop #: WSC 13157 000 1048576
               P242F - 001 - Restricted/Clogged - MIL ON
                    Mileage: 286507 km
                    Date: 2019.04.23
                    Time: 15:25:11
                    (no units): 51.0
                    (no units): 51.0
                    Pressure: 0 mbar
                    (no units): 41.0
                    (no units): 41.0
                    Pressure: -7 mbar
                    Temperature: 110.2°C
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H14 4210
   Revision: 91H14421    Serial number: 0037P0G08B3U
   Coding: 0431707
   VCID: 270BFAF9B3EC8FAFFF7-8072
   Subsystem 1 - Serial number: 63328RB4021B0D5AK
   Subsystem 2 - Serial number: 63428RB4021B12C9H
   Subsystem 3 - Serial number: 63528RB4021B12ACJ
   Subsystem 4 - Serial number: 63628RB4021B12C4E
   Subsystem 5 - Serial number: 63729RB40206D930G
   Subsystem 6 - Serial number: 63829RB40206D972N
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0112141
   VCID: 6597B0F189605DBF0DB-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 B    HW: 4E0 920 951 B
   Component: KOMBIINSTR. VDO H82 0530
   Revision: D04         Serial number: AUDID3G1000911
   Coding: 0048413
   Shop #: WSC 12470 067 57207
   Part No SW: 4E0 910 105 A    HW: 4E0 815 069 G
   Component: Heizgeraet      H08 0140
   Revision: 0000000C    Serial number: 00000009013887
   Coding: 0000001
   VCID: 1A6DD30DF09E2247709-804E
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B072078402
   Coding: F5F9DFFF307E0E
   Shop #: WSC 00272 210 90061
   VCID: 6C81C5D56A8A6CF7525-8038
            000 -  -
                    Reset counter: 45
                    Mileage: 286409 km
                    Date: 2019.04.18
                    Time: 16:42:20
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4E0 910 158     HW: 4E0 919 158 D
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000019    Serial number: 00000000050969
   Coding: 0000000
   VCID: 619FA4E19D48319FF13-8034
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
   VCID: 2A0D03CDA0FEB2C7E09-807E
   Component: Sitzmemory FS  H02  0010
   Coding: 4063338
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 L
   Component: MNS ECE         H48 1030
   Revision: 00000000    Serial number: 364BZ077642895
   Shop #: WSC 00262 210 87570
   VCID: 3E253F9D4C762E67AC1-806A
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000703000070
   Coding: 0035988
   VCID: 1D67D811E1B0557F95B-8048
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
            000 -  -  - Intermittent
                    Reset counter: 89
                    Mileage: 262136 km
                    Date: 2019.04.23
                    Time: 13:59:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
   Component: Türsteuer.FS BRM005 0180
   Coding: 0028462
   VCID: 2019E1E5D6C27897BED-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 C    HW: 4E0 907 289 C
   Component: Komfortgeraet   H09 0020
   Revision: 00200009    Serial number:  W040702150192
   Coding: 0004861
   VCID: 290FFCC1A5F8B9DFE93-807C
   Component: Heckdeckel   P14H06 0070
   Component: Neigungssensor  H05 0020
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
   Component: DSP-High D3     H03 0120
   Revision: PROD_01     Serial number: 00000000004394
   Coding: 0000023
   VCID: 2C0105D5AA0AACF7125-8078
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000106925
   Coding: 0010101
   VCID: 1E65DF1DECB64E678C1-804A
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 D
   Component: Türsteuer.BF BRM005 0180
   Coding: 0028462
02126 - Central Locking Button; Exterior Door Handle
                    Fault Frequency: 0
                    Reset counter: 87
                    Mileage: 286416 km
                    Date: 2019.04.19
                    Time: 18:43:38
                    Fault Status: 01101000
                    Reset counter: 50
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0001031
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000018
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
                    Fault Status: 00101010
                    Reset counter: 40
                    Mileage: 286408 km
                    Date: 2019.04.18
                    Time: 16:42:17
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 S
   Revision: 00000000    Serial number: 396BX077560682
   Coding: 0000001
   VCID: 313F14A18D28C11F213-8064
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R0078 TVhybridT     0470
   Revision: R0H06000    Serial number: 76300800288102
   Coding: 0000003
   VCID: 2517F0F1C9E09DBFCDB-8070
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000002140
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  2702211611
   Coding: 344530393135313035412056413032373032323131363131
   Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0028462
                    Reset counter: 86
                    Mileage: 286400 km
                    Date: 2019.04.18
                    Time: 16:23:24
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000900049947
   Coding: 0252127
                    Fault Status: 01100010
                    Fault Frequency: 24
                    Reset counter: 0
                    Mileage: 286409 km
                    Date: 2019.04.18
                    Time: 16:22:49
                    (no units): 0.0
                    Temperature: 17.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000702160212
   Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J72107M
   Coding: 1020302
   VCID: 5CE19515BA2A1C77A25-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0028462
                    Fault Frequency: 0
                    Reset counter: 45
                    Mileage: 286400 km
                    Date: 2019.04.18
                    Time: 16:23:02
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720704000217
   Coding: 0221008
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 D    HW: 4F1 862 335
   Component: BTA             H10 1120
   Revision: 00H10000    Serial number: 00000007563759
   Coding: 0070001
   Shop #: WSC 00272 210 64254
End----------(Elapsed Time: 02:34, VBatt start/end: 14.0V/14.5V)-----------
I've looked and come up empty-handed for these ECUs.
There's some stuff for EGR and Throttle replacements, but nothing for the DPF.
Grantus
England
C?ID=366283
thanks anyway Uwe
Ive done the full super scan thingy..would that be any help?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
You might need to trigger it through address 31, for a dual-ECU setup. That's a magic virtual address for speaking to both ECUs at once. Speaking of...
Never seen address 31 in a GVL before. Ross-Tech, is that legit?
OP you may want to try default re-coding the ECU's with VCDS and there is a firmware update, sometimes a re-flash update opens up a regen or even resets the ADP!
I'm fairly confident it's legit.
CAN cars with dual ECUs are pretty rare.
Good point. It looks like there's a version 0020 available for these ECUs.
But there's also the factor that this car has 178,000 miles on it, which make it entirely plausible that a DPF is past its useful service life.
siLc
Tallinn, Estonia
C?ID=330192
Speaking of DPF-s, the 4.2 TDI has not one, but two DPF-s. So "Bank 1" should mean the left one?
Grantus
England
C?ID=366283
I was lead to believe bank 1 is lhs
as an update I've took both dpf's off and jetwashed them thoroughly..tons of black soot etc came out and now its running clean water straight through..awaiting a spare ramp so I can pop them back on
In the meantime I've looked at the readings for what I think is measured blocks on the dpf sensors (103 to 106 in engine ii) and there's no change running engine without the sections in at all (still sitting at 50 and 40) and the pressure is showing 0 and -14mbar where the other one is showing 0 and 0
This suggests to me I might be needing an adaption of the sensors to reset the numbers once the dpf sections are back in
does that sound right and any idea how I would do that?
thanks
Please elaborate under what conditions you're seeing what pressure. And please look in the other ECU as well.
Grantus
England
C?ID=366283
engine off and also idling with both the dpf filters still sat in the boot.
There was no change in the reading in engine ii and the same blocks don't measure the same things in engine 1 (I went right through the range one at a time and couldn't see these values in any blocks)
this makes me suspect that they are only measured in engine ii
I monitored these blocks on a long run and they slowly increased but this was to be expected with the engine in limp mode.
Grantus
England
C?ID=366283
attempt 2 at posting this
I checked these with engine off and also engine idling with no change. This is with both dpf's still in the boot whilst I wait for a ramp at my local garage
I looked at the measured blocks in engine 1 but I cant see these values or anything similar in it... in fact I went right through all measured blocks in engine 1 looking... all values seem to go back to engine ii in measured blocks from 102 to 106 for temps and pressures and values.
I monitored these same values on a run before I popped the dpf's off and they slowly increased which I suspected they would bearing in mind its in limp mode
I did try and look in engine other and it wouldn't let me in measured blocks, so I suspect this is a virtual unit as someone above suggested.
thanks for the help Uwe
OP
Don't forget that faulty PSI sensors or lines too the DPF can make the DPF appear in ECU as they are not functioning proper.
Be sure to read SSP
The fact it is on one bank means that something mechanically could be additionally wrong & that should be investigated!
Grantus
England
C?ID=366283
looking at the values, bank one was slightly higher than bank 2 so it triggered the error? also bank 1 dpf sensor was suspected to have failed and it has been replaced
interestingly if you look at the full scan theres a bit of stuff down the left of the car that appears to be in fault and I did initially wonder about a bus error but I thought that would affect much more than passenger and rear doors and heaters
the more I look into it, it seems like I've actually cleared the original fault but don't have the ability to reset the ecu values to say it has a new sensor or the dpf has been replaced / cleaned.
