Results 1 to 10 of 14
Thread: 4.2 a8 with a clogged dpf
    Apr 2019
    England
    Hello and first post after lots and lots of looking
    I have a 2007 a8 4.2 tdi with a clogged dpf code bank 1.. regen runs were attempted when the warning was on the dash but unfortunately it didn't clear the problem
    skip forward a month and I purchased vcds with the intention of forcing a regen
    I foolishly imagined it would be intuitive and fairly straightforward
    skip on another few weeks of frustration and annoyance and im posting on here to get some help
    I think I need a code for engine ii to force regen but everything ive tried seems to come up with a fail
    here is my autoscan
    if its in the incorrect format apologies
    forgot to mention the dpf sensor was replaced thinking it was that as I heard a click when the original engine warning lamp came on, although it may have been a relay
    Tuesday,23,April,2019,16:12:20:06585
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
    VIN: WAUZZZ4E77N017251   License Plate: LV57USG
    Mileage: 286500km-178022mi   Repair Order: 77
    Chassis Type: 4E (4L0)
    Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 28 34 36
              37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
    VIN: WAUZZZ4E77N017251   Mileage: 286500km-178022miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    65-Tire Pressure -- Status: Not registered 0011
       Part No SW: 4E1 910 409 B    HW: 4E1 907 409 A
       Component: 4.2L V8TDI  G000AGMª0010
       Revision: --H04---    Serial number: AUX3Z0G1315815
       Coding: 0011773
       Shop #: WSC 02313 785 00200
       VCID: 2313EEE9C7D4638FA3F-8076
    009263 - Diesel Particulate Filter (Bank 1)
                   P242F - 001 - Restricted/Clogged
                        Fault Status: 11100001
                        Mileage: 286507 km
                        Date: 2019.04.23
                        Time: 15:25:11
                        (no units): 51.0
                        (no units): 51.0
                        Pressure: 0 mbar
                        (no units): 41.0
                        (no units): 41.0
                        Pressure: 0 mbar
                        Temperature: 98.6°C
       Part No SW: 4E1 910 156 S    HW: 09E 927 156 B
       Component: AG6 09E 4,2 TDI RdW 0010
       Revision: --H01---    Serial number:        0102169
       VCID: 33331EA97734F30F53F-8066
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
       Component: ESP 5.7 allrad  H46 0510
       Coding: 0008557
       Shop #: WSC 02313 000 00000
       VCID: 221DEBEDD8CE6A87A89-8076
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 K
       Component:     FBS AUDID3  H10 0190
       Revision: 01904910    Serial number: AUX3Z0G1315815
       Coding: 0412672
       Shop #: WSC 02311 785 00200
       VCID: 58E98905CE12F05786D-800C
       Subsystem 1 - Part No: 4E0 905 852 E
       Component: ELV                 1940
       Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
       Component: Sitzmemory BFS H02  0010
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 4063328
       VCID: 2411EDF5C2DA64B7DA5-8070
    Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
       Part No SW: 4E0 910 769 Q    HW: 4E0 035 729 A
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 300BR077578826
       Shop #: WSC 00272 210 89997
       VCID: 3A2D338D505E0247909-806E
       Subsystem 1 - Part No: 4E0 910 611
       Component: E0380 BedienteilH01 0050
       Subsystem 2 - Serial number: 00000000093790
       Subsystem 3 - Serial number: 0115.07.100000000100010002ÿ
       Subsystem 4 - Serial number: 010002ÿ
       Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
       Component: KLIMAAUTOMAT    017 0450
       Revision: 00000032    Serial number: 00000000114745
       Coding: 0088145
       VCID: 1C61D515FAAA5C77625-8048
    00065 - Rear Left Footwell Heater (Z42)
                        Reset counter: 45
                        Mileage: 286409 km
                        Date: 2019.04.18
                        Time: 16:20:46
                        Voltage: 11.40 V
    00066 - Rear Right Footwell Heater (Z43)
                        Reset counter: 45
                        Mileage: 286409 km
                        Date: 2019.04.18
                        Time: 16:20:47
                        Voltage: 11.40 V
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
       Component: ILM Fahrer      H15 0230
       Coding: 0143121
       VCID: 363527BD6446E627741-8062
       Subsystem 1 - Part No: 4E2 910 113 C
       Component: Wischer WWS D3  H60 0440
       Coding: 00000034
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
                        Reset counter: 89
                        Mileage: 286409 km
                        Date: 2019.04.18
                        Time: 16:28:55
                        Reset counter: 89
                        Mileage: 286500 km
                        Date: 2019.04.23
                        Time: 13:59:50
    Address 0E: Media Player 1        Labels:
       VCID: 55F78031DC00CD3F9DB-FFFE
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276U8100762
    Address 11: Engine II        Labels: Redir Fail!
       Component: 4.2L V8TDI  G000AGSª0010
       Coding: 0011773
       Shop #: WSC 13157 000 1048576
                   P242F - 001 - Restricted/Clogged - MIL ON
                        Mileage: 286507 km
                        Date: 2019.04.23
                        Time: 15:25:11
                        (no units): 51.0
                        (no units): 51.0
                        Pressure: 0 mbar
                        (no units): 41.0
                        (no units): 41.0
                        Pressure: -7 mbar
                        Temperature: 110.2°C
    Address 15: Airbags        Labels: 4E0-910-655-94.lbl
       Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
       Component:    Airbag 9.41  H14 4210
       Revision: 91H14421    Serial number: 0037P0G08B3U
       Coding: 0431707
       VCID: 270BFAF9B3EC8FAFFF7-8072
       Subsystem 1 - Serial number: 63328RB4021B0D5AK
       Subsystem 2 - Serial number: 63428RB4021B12C9H
       Subsystem 3 - Serial number: 63528RB4021B12ACJ
       Subsystem 4 - Serial number: 63628RB4021B12C4E
       Subsystem 5 - Serial number: 63729RB40206D930G
       Subsystem 6 - Serial number: 63829RB40206D972N
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549
       Component: Lenksäulenmodul H14 0040
       Coding: 0112141
       VCID: 6597B0F189605DBF0DB-8030
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 951 B    HW: 4E0 920 951 B
       Component: KOMBIINSTR. VDO H82 0530
       Revision: D04         Serial number: AUDID3G1000911
       Coding: 0048413
       Shop #: WSC 12470 067 57207
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4E0 910 105 A    HW: 4E0 815 069 G
       Component: Heizgeraet      H08 0140
       Revision: 0000000C    Serial number: 00000009013887
       VCID: 1A6DD30DF09E2247709-804E
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B072078402
       Coding: F5F9DFFF307E0E
       Shop #: WSC 00272 210 90061
       VCID: 6C81C5D56A8A6CF7525-8038
                        Reset counter: 45
                        Mileage: 286409 km
                        Date: 2019.04.18
                        Time: 16:42:20
       Part No SW: 4E0 910 158     HW: 4E0 919 158 D
       Component: KLIMA-STG. FOND 017 0230
       Revision: 00000019    Serial number: 00000000050969
       Coding: 0000000
       VCID: 619FA4E19D48319FF13-8034
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
       Component: LUFTFDR.-CDC    H06 6310
       Coding: 0015510
       VCID: 2A0D03CDA0FEB2C7E09-807E
       Component: Sitzmemory FS  H02  0010
       Coding: 4063338
       Part No SW: 4E0 910 887 T    HW: 4E0 919 887 L
       Component: MNS ECE         H48 1030
       Revision: 00000000    Serial number: 364BZ077642895
       Shop #: WSC 00262 210 87570
       VCID: 3E253F9D4C762E67AC1-806A
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H05 0090
       Serial number: 00000703000070
       Coding: 0035988
       VCID: 1D67D811E1B0557F95B-8048
    00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
                000 -  -  - Intermittent
                        Reset counter: 89
                        Mileage: 262136 km
                        Date: 2019.04.23
                        Time: 13:59:00
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
       Component: Türsteuer.FS BRM005 0180
       Coding: 0028462
       VCID: 2019E1E5D6C27897BED-8074
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 C    HW: 4E0 907 289 C
       Component: Komfortgeraet   H09 0020
       Revision: 00200009    Serial number:  W040702150192
       Coding: 0004861
       VCID: 290FFCC1A5F8B9DFE93-807C
       Component: Heckdeckel   P14H06 0070
       Component: Neigungssensor  H05 0020
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
       Component: DSP-High D3     H03 0120
       Revision: PROD_01     Serial number: 00000000004394
       Coding: 0000023
       VCID: 2C0105D5AA0AACF7125-8078
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H11 0070
       Revision:             Serial number: 00000000106925
       Coding: 0010101
       VCID: 1E65DF1DECB64E678C1-804A
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 801 D
       Component: Türsteuer.BF BRM005 0180
       Coding: 0028462
                        Fault Frequency: 0
                        Reset counter: 87
                        Mileage: 286416 km
                        Date: 2019.04.19
                        Time: 18:43:38
                        Reset counter: 50
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
       Component: EPB  A4EC0230   H03 0230
       Revision: --H03---
       Coding: 0001031
       Coding: 0000018
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
                        Fault Status: 00101010
                        Reset counter: 40
                        Mileage: 286408 km
                        Date: 2019.04.18
                        Time: 16:42:17
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541 S
       Revision: 00000000    Serial number: 396BX077560682
       VCID: 313F14A18D28C11F213-8064
    Address 57: TV Tuner        Labels: None
       Part No SW: 4E0 910 148 E    HW: 4E0 919 148
       Component: R0078 TVhybridT     0470
       Revision: R0H06000    Serial number: 76300800288102
       Coding: 0000003
       VCID: 2517F0F1C9E09DBFCDB-8070
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0550
       Revision: 00000000    Serial number: 00000000002140
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  2702211611
       Coding: 344530393135313035412056413032373032323131363131
       Shop #: WSC 00000 128 00289
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
       Component: Türsteuer.HL BRM005 0180
       Coding: 0028462
                        Reset counter: 86
                        Mileage: 286400 km
                        Date: 2019.04.18
                        Time: 16:23:24
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
       Component: Reifendruck 3   H05
       Revision: 00050340    Serial number: 00000900049947
       Coding: 0252127
                        Fault Status: 01100010
                        Fault Frequency: 24
                        Reset counter: 0
                        Mileage: 286409 km
                        Date: 2019.04.18
                        Time: 16:22:49
                        (no units): 0.0
                        Temperature: 17.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000702160212
       Shop #: WSC 12336 024 394758
    Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
       Part No SW: 4E0 910 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J72107M
       Coding: 1020302
       VCID: 5CE19515BA2A1C77A25-8008
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
       Component: Türsteuer.HR BRM005 0180
       Coding: 0028462
                        Fault Frequency: 0
                        Reset counter: 45
                        Mileage: 286400 km
                        Date: 2019.04.18
                        Time: 16:23:02
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
       Component: Parkhilfe 8-Kan H12 0040
       Revision: 00H12000    Serial number: 08720704000217
       Coding: 0221008
    Address 77: Telephone        Labels: 4F1-910-336.lbl
       Part No SW: 4F1 910 336 D    HW: 4F1 862 335
       Component: BTA             H10 1120
       Revision: 00H10000    Serial number: 00000007563759
       Coding: 0070001
       Shop #: WSC 00272 210 64254
    End----------(Elapsed Time: 02:34, VBatt start/end: 14.0V/14.5V)-----------
    I've looked and come up empty-handed for these ECUs.
    There's some stuff for EGR and Throttle replacements, but nothing for the DPF.
    Apr 2019
    England
    thanks anyway Uwe
    Ive done the full super scan thingy..would that be any help?
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    You might need to trigger it through address 31, for a dual-ECU setup. That's a magic virtual address for speaking to both ECUs at once. Speaking of...
    Never seen address 31 in a GVL before. Ross-Tech, is that legit?
    Silence gives consent.
  5. Likes Jack@European_Parts liked this post
    OP you may want to try default re-coding the ECU's with VCDS and there is a firmware update, sometimes a re-flash update opens up a regen or even resets the ADP!
    I'm fairly confident it's legit.
    CAN cars with dual ECUs are pretty rare.
  8. Likes jyoung8607 liked this post
    Good point. It looks like there's a version 0020 available for these ECUs.
    But there's also the factor that this car has 178,000 miles on it, which make it entirely plausible that a DPF is past its useful service life.
  10. #8
    Jul 2014
    Tallinn, Estonia
    Speaking of DPF-s, the 4.2 TDI has not one, but two DPF-s. So "Bank 1" should mean the left one?
  11. #9
    Apr 2019
    England
    I was lead to believe bank 1 is lhs
    as an update I've took both dpf's off and jetwashed them thoroughly..tons of black soot etc came out and now its running clean water straight through..awaiting a spare ramp so I can pop them back on
    In the meantime I've looked at the readings for what I think is measured blocks on the dpf sensors (103 to 106 in engine ii) and there's no change running engine without the sections in at all (still sitting at 50 and 40) and the pressure is showing 0 and -14mbar where the other one is showing 0 and 0
    This suggests to me I might be needing an adaption of the sensors to reset the numbers once the dpf sections are back in
    does that sound right and any idea how I would do that?
    thanks
  12. Likes Uwe liked this post
  13. #10
    Quote Originally Posted by Grantus View Post
    Please elaborate under what conditions you're seeing what pressure. And please look in the other ECU as well.
