Results 1 to 7 of 7
Thread: MK6 jetta tdi
    Mar 2019
    MK6 jetta tdi
    Any changes to the steering of the car? I've tried turning on the Driver Steering Recommendation Electronic Differential Lock (XDS) Strength but it didn't seem to do anything. Does this car not have those features?
    Answering that question will be a whole lot easier if you post a full unedited VCDS Auto-Scan
  3. Likes Uwe liked this post
    Mar 2019
    Sorry... I'll post that up tonight after work. thank you.
    Dec 2016
    DE
    Steering characteristics should be handled by module 44. in this generation you should have an ZF steering rack which, depending on the software version, supports different characteristics curves [Kennlinien].
    Changing those will require another tool besides VCDS that allows you to update/flash firmwares. This is because the characteristics curves are tiny update files, which get uploaded to the ecu.
    Mar 2019
    This was my first scan on the car I believe. And I also posted up today's scan since I have made some changes.
    Thursday,02,August,2018,19:24:26:49714
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    VIN: 3VW3L7AJ6EM405804   License Plate:
    Mileage: 152010km-94454mi   Repair Order:
    Chassis Type: AJ-VW36 (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: 3VW3L7AJ6EM405804   Mileage: 152010km-94454miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 N    HW: 03L 907 309 AA
       Component: R4 2.0l TDI G000SG  9983
       Revision: 12H16---    Serial number:
       Coding: 0050072
       Shop #: WSC 04024 003 1048576
       VCID: 392F2EC56555B1EF76A-806C
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: A14B400C492200FF851302E4921D0042A1100012
       Shop #: WSC 49781 001 1048576
       VCID: 04518F315E173C0755C-8050
    02214 - Tire Pressure Warning
                        Reset counter: 245
                        Mileage: 148150 km
                        Date: 2041.14.26
                        Time: 09:18:02
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 49985
                        Count: 258
                        Count: 1280
                        Reset counter: 222
                        Mileage: 151955 km
                        Date: 2042.14.18
                        Time: 18:19:49
                        Count: 2
                        Count: 4096
                        Count: 8212
                        Count: 44800
                        Count: 65280
                        Count: 255
       Part No SW: 5C0 820 047 BN    HW: 5C0 820 047 BN
       Component: J301  Klimaanlage   0204
       Revision: 2001001S    Serial number: 00000001942985
       Shop #: WSC 13676 001 1048576
       VCID: 6D87CA95619DDD4FAA2-8038
       Part No SW: 5C0 937 087 L    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H34 0425
       Revision: B2034001    Serial number: 08013350130607
       Coding: 7B994BBA08A90B0008382000340894C40082502E60000000300050002000
       VCID: 363525F9584B5E979B8-8062
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Serial number: 14102585131210191329
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Serial number: 14102584131205112315
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.022  H10 0007
       Serial number:     WRH000AHHT0
       Coding: 180000
       Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0403351 FLE 20131115
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587131209135239
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586131125205138
       Coding: 800000
       Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
       Component: AirbagVW10    102 0912
       Serial number: 003MVD02LEP2
       Coding: 00004138
       Shop #: WSC 00066 790 00200
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 74B1DFF10E370C8765C-8020
       Serial number: 6940000Y1300010H220-
       Coding: 303036
       Serial number: 3572MSME6F413A40ZZZ-
       Serial number: 3582MSME6D67337EZZZA
       Serial number: 3516KSME282C3D29ZZZ/
       Serial number: 3526KSME685E1729ZZZ%
       Serial number: 3556LSME1851052AZZZQ
       Serial number: 3566LSME6971052AZZZZ
       Part No SW: 5C6 920 953 A    HW: 5C6 920 953 A
       Component: KOMBI         H04 0809
       Coding: 270801
       Shop #: WSC 00066 790 00203
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 2B03048D9389137FF46-807E
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H34 0425
       Revision: B2034001
       Coding: 102200
       VCID: 70B9D3E17AAF30A7814-8024
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H07 6813
       Revision: --------    Serial number: EAA098A0099033
       VCID: 2615F5B9886B2E172B8-8072
       Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
       Component: Radio Prem-8  H05 0008
       Revision: -----09S    Serial number: VWZ4Z7P3526008
       Coding: 01020040010006
       VCID: 2B03048D9309137FF46-807E
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0086
       Serial number: 000003554140509
       Coding: 02630102C2163A007F1606000000
       Shop #: WSC 01383 790 50316
       ROD: EV_OCULow_001.rod
       VCID: 53F37C6DEB796BBF9C6-8006
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 222
                        Mileage: 152019 km
                        Date: 2018.08.02
                        Time: 19:29:22
    End----------(Elapsed Time: 04:20, VBatt start/end: 12.7V/12.6V)-----------
    Address 56,1K0 035 188 F,recoded (Long Coding),from,01020040010006,to,01020040010000,(00066/790/00203),
    Address 56,1K0 035 188 F,recoded (Long Coding),from,01020040010000,to,01020040010006,(00066/790/00203),
    Address 03,1K0 907 379 BS,channel 9,adapted from,0,to,2,
    Address 09,5C0 937 087 L,recoded (Long Coding),from,7B994BBA08A90B0008382000340894C40082502E60000000300050002000,to,7B994BBF08A90B0008382000340894C40082502E60000000300050002000,(04024/003/104857),
    Wednesday,24,April,2019,20:44:24:49714
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    Mileage: 181640km-112865mi   Repair Order:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 44 47 56 75 77
    VIN: 3VW3L7AJ6EM405804   Mileage: 181640km-112865miles
    75-Telematics -- Status: Malfunction 1010
       Coding: 0050072
       VCID: 392F2EC56555B1EF993-806C
    Readiness: 0 0 0 X 0
       Revision: 00H46001
       VCID: 04518F315E173C07BA5-8050
                        Reset counter: 91
                        Mileage: 180032 km
                        Date: 2019.04.11
                        Time: 11:53:59
                        Count: 3
                        Count: 2
                        Count: 4096
                        Count: 8212
                        Count: 48384
                        Count: 255
       VCID: 6D87CA95619DDD4F45B-8038
       Coding: 7B994BBF08A90B00083820C03C0894C4D08250FE60240000300050002000
       VCID: 363525F9584B5E97741-8062
       Coding: 820000
       Coding: 820000
       Coding: 180000
       Coding: 020000
       Coding: 800000
       Coding: 800000
       Coding: 00004138
       VCID: 74B1DFF10E370C878A5-8020
       Coding: 303036
       Coding: 070801
       VCID: 2B03048D9389137F1BF-807E
       Revision: B2034001
       Coding: 102200
       VCID: 70B9D3E17AAF30A76ED-8024
    01302 - Control Module for Telematic (J499)
                        Reset counter: 154
                        Mileage: 180954 km
                        Date: 2019.04.18
                        Time: 12:07:17
       Component: IMMO          H04 0809
       VCID: 6A8DC1895CF3CA77209-803E
    Address 2E: Media Player 3
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 70     3501
       Revision: 00H22000
       VCID: 2615F5B9886B2E17C41-8072
       VCID: 2B03048D9309137F1BF-807E
                        Reset counter: 91
                        Mileage: 180032 km
                        Date: 2019.04.11
                        Time: 11:53:59
       VCID: 53F37C6DEB796BBF73F-8006
    12670464 - Databus
              [CAN TO brake]
                        Reset counter: 152
                        Mileage: 180882 km
                        Date: 2019.04.17
                        Time: 07:28:22
    0035 - Databus
              [CAN TO Airbag]
                        Fault Frequency: 7
                        Reset counter: 171
                        Mileage: 180767 km
                        Date: 2019.04.15
                        Time: 19:38:41
                        Fault Priority: 8
                        Reset counter: 132
                        Mileage: 181640 km
                        Date: 2019.04.24
                        Time: 20:47:04
       Component: TELEFON       H05 0315
       Revision: 1B001001    Serial number: 00007665533791
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 2E050D99A09B66573C1-807A
    End----------(Elapsed Time: 01:44, VBatt start/end: 12.3V/12.2V)-----------
  7. Likes Uwe liked this post
    Dec 2016
    DE
       Revision: 00H22000
    Looks like my wild guess was right. You got a 3rd generation ZF rack, currently equipped with characteristics curve 70.
    Mar 2019
    Im not sure what that means, am I able to make any changes to that or do I need the other tool. And if so which tool is that? Should I be concerned with any of the fault codes in the newest scan?
