MK6 jetta tdi
theone2043
C?ID=343531
Any changes to the steering of the car? I've tried turning on the Driver Steering Recommendation Electronic Differential Lock (XDS) Strength but it didn't seem to do anything. Does this car not have those features?
Answering that question will be a whole lot easier if you post a full unedited VCDS Auto-Scan :thumbs:
theone2043
C?ID=343531
Sorry... I'll post that up tonight after work. thank you.
TBAx
C?ID=287144
Steering characteristics should be handled by module 44. in this generation you should have an ZF steering rack which, depending on the software version, supports different characteristics curves [Kennlinien].
Changing those will require another tool besides VCDS that allows you to update/flash firmwares. This is because the characteristics curves are tiny update files, which get uploaded to the ecu.
theone2043
C?ID=343531
This was my first scan on the car I believe. And I also posted up today's scan since I have made some changes.
Thursday,02,August,2018,19:24:26:49714
VIN: 3VW3L7AJ6EM405804   License Plate:
Mileage: 152010km-94454mi   Repair Order:
Chassis Type: AJ-VW36 (9M - VW Jetta IV (1998 > 2014))
          75 76
VIN: 3VW3L7AJ6EM405804   Mileage: 152010km-94454miles
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 N    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000SG  9983
   Revision: 12H16---    Serial number:
   Coding: 0050072
   Shop #: WSC 04024 003 1048576
   VCID: 392F2EC56555B1EF76A-806C
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492200FF851302E4921D0042A1100012
   Shop #: WSC 49781 001 1048576
   VCID: 04518F315E173C0755C-8050
02214 - Tire Pressure Warning
                    Reset counter: 245
                    Mileage: 148150 km
                    Date: 2041.14.26
                    Time: 09:18:02
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 49985
                    Count: 258
                    Count: 1280
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 222
                    Mileage: 151955 km
                    Date: 2042.14.18
                    Time: 18:19:49
                    Count: 2
                    Count: 4096
                    Count: 8212
                    Count: 44800
                    Count: 65280
                    Count: 255
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BN    HW: 5C0 820 047 BN
   Component: J301  Klimaanlage   0204
   Revision: 2001001S    Serial number: 00000001942985
   Shop #: WSC 13676 001 1048576
   VCID: 6D87CA95619DDD4FAA2-8038
   Part No SW: 5C0 937 087 L    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H34 0425
   Revision: B2034001    Serial number: 08013350130607
   Coding: 7B994BBA08A90B0008382000340894C40082502E60000000300050002000
   VCID: 363525F9584B5E979B8-8062
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585131210191329
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584131205112315
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH000AHHT0
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0403351 FLE 20131115
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587131209135239
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14102586131125205138
   Coding: 800000
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD02LEP2
   Coding: 00004138
   Shop #: WSC 00066 790 00200
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74B1DFF10E370C8765C-8020
   Serial number: 6940000Y1300010H220-
   Coding: 303036
   Serial number: 3572MSME6F413A40ZZZ-
   Serial number: 3582MSME6D67337EZZZA
   Serial number: 3516KSME282C3D29ZZZ/
   Serial number: 3526KSME685E1729ZZZ%
   Serial number: 3556LSME1851052AZZZQ
   Serial number: 3566LSME6971052AZZZZ
   Part No SW: 5C6 920 953 A    HW: 5C6 920 953 A
   Component: KOMBI         H04 0809
   Coding: 270801
   Shop #: WSC 00066 790 00203
   VCID: 2B03048D9389137FF46-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H34 0425
   Revision: B2034001
   Coding: 102200
   VCID: 70B9D3E17AAF30A7814-8024
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0099033
   VCID: 2615F5B9886B2E172B8-8072
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7P3526008
   Coding: 01020040010006
   VCID: 2B03048D9309137FF46-807E
   Component: OCULowUSA     014 0086
   Serial number: 000003554140509
   Coding: 02630102C2163A007F1606000000
   Shop #: WSC 01383 790 50316
   ROD: EV_OCULow_001.rod
   VCID: 53F37C6DEB796BBF9C6-8006
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 222
                    Mileage: 152019 km
                    Date: 2018.08.02
                    Time: 19:29:22
End----------(Elapsed Time: 04:20, VBatt start/end: 12.7V/12.6V)-----------
Address 56,1K0 035 188 F,recoded (Long Coding),from,01020040010006,to,01020040010000,(00066/790/00203),
Address 56,1K0 035 188 F,recoded (Long Coding),from,01020040010000,to,01020040010006,(00066/790/00203),
Address 03,1K0 907 379 BS,channel 9,adapted from,0,to,2,
Address 09,5C0 937 087 L,recoded (Long Coding),from,7B994BBA08A90B0008382000340894C40082502E60000000300050002000,to,7B994BBF08A90B0008382000340894C40082502E60000000300050002000,(04024/003/104857),
Wednesday,24,April,2019,20:44:24:49714
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
Mileage: 181640km-112865mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 47 56 75 77
VIN: 3VW3L7AJ6EM405804   Mileage: 181640km-112865miles
75-Telematics -- Status: Malfunction 1010
   Coding: 0050072
   VCID: 392F2EC56555B1EF993-806C
Readiness: 0 0 0 X 0
   Revision: 00H46001
   VCID: 04518F315E173C07BA5-8050
                    Reset counter: 91
                    Mileage: 180032 km
                    Date: 2019.04.11
                    Time: 11:53:59
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 8212
                    Count: 48384
                    Count: 255
   VCID: 6D87CA95619DDD4F45B-8038
   Coding: 7B994BBF08A90B00083820C03C0894C4D08250FE60240000300050002000
   VCID: 363525F9584B5E97741-8062
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00004138
   VCID: 74B1DFF10E370C878A5-8020
   Coding: 303036
   Coding: 070801
   VCID: 2B03048D9389137F1BF-807E
   Revision: B2034001
   Coding: 102200
   VCID: 70B9D3E17AAF30A76ED-8024
01302 - Control Module for Telematic (J499)
                    Reset counter: 154
                    Mileage: 180954 km
                    Date: 2019.04.18
                    Time: 12:07:17
   Component: IMMO          H04 0809
   VCID: 6A8DC1895CF3CA77209-803E
Address 2E: Media Player 3
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 2615F5B9886B2E17C41-8072
   VCID: 2B03048D9309137F1BF-807E
            000 -  -
                    Reset counter: 91
                    Mileage: 180032 km
                    Date: 2019.04.11
                    Time: 11:53:59
   VCID: 53F37C6DEB796BBF73F-8006
12670464 - Databus
          [CAN TO brake]
                    Reset counter: 152
                    Mileage: 180882 km
                    Date: 2019.04.17
                    Time: 07:28:22
0035 - Databus
          [CAN TO Airbag]
                    Fault Frequency: 7
                    Reset counter: 171
                    Mileage: 180767 km
                    Date: 2019.04.15
                    Time: 19:38:41
                    Fault Priority: 8
                    Reset counter: 132
                    Mileage: 181640 km
                    Date: 2019.04.24
                    Time: 20:47:04
   Revision: 1B001001    Serial number: 00007665533791
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E050D99A09B66573C1-807A
End----------(Elapsed Time: 01:44, VBatt start/end: 12.3V/12.2V)-----------
TBAx
C?ID=287144
   Revision: 00H22000
Looks like my wild guess was right. You got a 3rd generation ZF rack, currently equipped with characteristics curve 70.
theone2043
C?ID=343531
Im not sure what that means, am I able to make any changes to that or do I need the other tool. And if so which tool is that? Should I be concerned with any of the fault codes in the newest scan?
