Results 1 to 4 of 4
Thread: 2005 New Beetle - pre Purchase Scan
    Dec 2016
    East Sussex, UK
    I am looking to buy a 2005 New Beetle Cabriolet
    It's a 1.6 petrol. I ran a scan and this is how it came back
    Monday,22,April,2019,09:10:18:15721
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ1YZ5M356847   License Plate:
    Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
    Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
    VIN: WVWZZZ1YZ5M356847   Mileage: 151380km-94063miles
    Address 01: Engine        Labels: 06A-906-033-AVU.lbl
       Part No: 06A 906 033 DP
       Component: SIMOS33 1.6l 2V 00HS5793
       Coding: 00031
       Shop #: WSC 00066
       VCID: 70EBEADE309E7ACA2D-513C
       WVWZZZ1YZ5M356847     VWZ5Z0E0251177
    16555 - Fuel Trim; Bank 1
                P0171 - 35-00 - System Too Lean
                P0171 - 35-10 - System Too Lean - Intermittent
    17911 - Load Signal from Alternator Term. DF
                P1503 - 35-10 - Implausible Signal - Intermittent
    17925 - Power Supply Relay for ECU
                P1517 - 35-10 - Electrical Malfunction - Intermittent
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0011266
       VCID: 346326CE540606EA09-5120
    00495 - ESP-Sensor Unit (G419); Supply Voltage
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No: 6Q0 909 605 AL
       Component: 03 AIRBAG VW71      0711
       Coding: 0012339
       VCID: 010DBF1A5B346342D2-513C
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 1C0-920-x4x.lbl
       Part No: 1C0 920 940 C
       Component: KOMBI+WEGFAHRS. M73 V05
       Coding: 01412
       VCID: 1F49D9629D80B5B2C4-4B18
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V052
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EBEADE309E7ACA2D-4B00
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255 C
       Component:  VSG  NBC           3601
       VCID: 408B7A1E10BEAA4A9D-513C
    9 Faults Found:
       Part No: 1C0 959 799 F
       Component: DC Komfortgerát HLO 0004
       Coding: 00256
       Shop #: WSC 00028
       VCID: 3A7F08F62662F09AD3-4B00
       Subsystem 1 - Part No: 1Y2959802
       Component: 6Q Tőrsteuer.FS KLO 0005
       Subsystem 2 - Part No: 1Y2959801D
       Component: DC Tőrsteuer.BF KLO 0005
       Subsystem 3 - Part No: 1Y0959811
       Component: DC Tőrsteuer.HL KLO 0005
       Subsystem 4 - Part No: 1Y0959812
       Component: DC Tőrsteuer.HR KLO 0005
    16 Faults Found:
                53-10 - Supply Voltage Too Low - Intermittent
                80-10 - Single-Wire Operation - Intermittent
                37-10 - Faulty - Intermittent
    01134 - Alarm Horn (H12)
    01359 - Internal Central Locking Switch; Passenger Side (E198)
    01033 - Central Locking Key Switch; Passenger Side; Unlock
                29-10 - Short to Ground - Intermittent
                27-00 - Implausible Signal
                35-00 -  -
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1C0 035 196 S
       Component:  RADIO DE2         0003
       Coding: 06401
       Shop #: WSC 00066
       VCID: 2F6929A2ED20253274-51B2
    End-------------------------(Elapsed Time: 04:03)--------------------------
    All of the codes cleared apart from ones in the "Central Convenience" section - which left this:
       Coding: 00256
       Shop #: WSC 00028
    No Faults Found
       Coding: 06401
       Shop #: WSC 00066
       VCID: 2F6929A2ED20253274-51D0
    End-------------------------(Elapsed Time: 04:10)--------------------------
    Now, the voltage ones in the first scan I am not too worried about (as there was a known bad battery, that has been replaced) - but I don't know how to deal with the codes that have remained.
    In addition, the 1.6 engine seemed to idle slightly lumpy from a cold start, and also continued to rev when the pedal was released, and also with the throttle response there was quite a lag from pressing, before anything happaned, but no codes.
    The garage said they would resolve this, however I would like to know what is going on so I can guide them (if needed) and also know what the likely outcomes are to be
    Thank you for any thoughts
    Mark
    HQ
    Test drive the car, rack up a few miles, then go check your fuel trim values:
    Fuel trim issues in most cases are not too difficult to resolve... cracked vacuum pipe or bad CCV. But with some engines, it could be a failed rear main seal. No way know specifics of this car just yet.
    No Faults Found
    All the control modules, when asked about fault codes, did directly respond there are no fault codes. However, the ABS module, when asked, just stood there with a blank expression on its stupid face, drool running down his chin. So from VCDS's point of view, the ABS didn't say there were fault codes, but it really didn't say there were no fault codes. This is the very simplified version of what happened.
    So when you get that "No Faults Found or DTCs not supported by controller or a communication error occurred" message, go back and check again.
    Jef
    Dec 2016
    East Sussex, UK
    Great reply - thank you Jef
    The car is being looked at by the garage tomorrow - hopefully we will know more then.
    Will the fuel trim values have an effect on lumpy idle and also throttle delay/response?
    HQ
    It can... if there is a massive vacuum lean, running super lean, it will make an engine run like crap. See what the numbers show, and then (carefully) hose the engine bay down with brake cleaner as shown in the video.
    Jef
