Hi!
We (I and golfi_vend) have two 2015 passat B8s where we try to retrofit kessy.
As original Acc/Start Auth. (J518) - 3Q0 959 435 did not support kessy, we replaced it with 3Q0 959 435 A on both cars. Golfi_vend did upload correct dataset to 05 and re-learned keys etc.
One has all kessy door handles and antennas installed, other has only driver kessy door handle installed.
Everything seems to be right - with vcds, we can see that door sensors are touched (both, locking and unlocking), but doors won't lock/unlock when touching sensors.
We have compared module versions, codings and adaptions with some same year B8 passats, but don't see where the issue is.
Maybe someone has some ideas what to check next?
Here is autoscan of B8 where only driver door handle is replaced:
Also adaption of 05:
09:
Sunday,07,April,2019,09:39:41:49581
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4451.4
VIN: WVWZZZ3CZFEXXXXXX License Plate: KESSYNOTWORKING
Mileage: 99006km-61519mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 6C
6D A5 BB BC
VIN: WVWZZZ3CZFEXXXXXX Mileage: 99006km-61519miles
Address 01: Engine (J623-DDAA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 DR HW: 04L 907 309 M
Component: R4 2.0l TDI H22 1935
Revision: B4H22---
Coding: 011D001A036405083000
Shop #: WSC 40209 222 00000
ASAM Dataset: EV_ECM20TDI01104L906026DR 004005
ROD: EV_ECM20TDI01104L906026DR_004.rod
VCID: 7DA4F369FD7D743FF5B-8028
Part No SW: 0D9 300 041 B HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4803
Revision: 05853104 Serial number: TFK01502103595
Shop #: WSC 05311 115 00066
ROD: EV_TCMDQ250021.rod
VCID: 1768C1C1FF01BE6F4F7-8042
Part No SW: 3Q0 907 379 R HW: 3Q0 907 379 G
Component: ESC H42 0711
Revision: 00000000 Serial number: 60435000000918
Coding: 0FEC6A8F34260B6F077C060641CA49F0562CD0E0608292F11862F078C209
Shop #: WSC 00015 115 00001
VCID: 49CC57B9F935189F093-801C
Part No SW: 3Q0 959 435 A HW: 3Q0 959 435 A
Component: VWKESSYMQB 033 0522
Revision: 00033000 Serial number: 0330464091
Coding: 010E0E0703
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_KessyHellaMQBAB 004027
VCID: 382A227D92DF911766D-806C
Part No SW: 5G1 907 044 A HW: 5G1 907 044 A
Component: Climatronic H03 1001
Revision: 00001K10
Coding: 12020104204401012115504E00101802
VCID: 2616FC05486B17E7C41-8072
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 BD HW: 5Q0 937 086 BD
Component: BCM PQ37BOSCH 028 0146
Revision: -------- Serial number: 86580602152219
Coding: 00051E66C24102FF13844084B11C57281C80000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150201 042 0607
Serial number: 150205011446
Coding: 0E4DFD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y15M02D24H03M55S37
Coding: 00A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 19 01 2015 00000460
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150070787
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000061690635
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391504809758
Coding: 0071151811
Shop #: WSC 63672 002 1048576
ROD: EV_EPHVA18AU3700000_002_VW48.rod
VCID: 44D2468DDE17C5F7FA5-8010
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 A
Component: ACC BOSCH MQB H04 0195
Coding: 3200678251FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 35342B4985CD6C7F7DB-8060
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Reset counter: 128
Mileage: 99006 km
Date: 2019.04.07
Time: 09:21:01
Control Module temperature: 8 ∞C
Voltage terminal 15: 11.7 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
Part No SW: 3Q0 959 655 AE HW: 3Q0 959 655 AE
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R1P2C4Y7T
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 015C8F99818510DF913-8054
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G1857705E0042P00980
Coding: 80000A
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706E0055P00923
Coding: 80000A
Subsystem 3 - Part No SW: ----------- HW: 454 001 002 15
Serial number: 3576U0000005CB18B21G
Subsystem 4 - Part No SW: ----------- HW: 454 001 002 15
Serial number: 3586U000000E7028B21B
Subsystem 5 - Part No SW: ----------- HW: 454 800 402 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RCD6FD705000000R
Subsystem 6 - Part No SW: ----------- HW: 454 803 101 15
Component: SideSensor_Pr 111 0148
Serial number: 3526RE38ED605000000K
Subsystem 7 - Part No SW: ----------- HW: 454 801 202 15
Component: FrontSensor_D 114 0149
Serial number: 3556V122E9B050000008
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 AM HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0185
Revision: FF033033 Serial number: 20150202500527
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7BA0FD71E3697A0FCBF-802E
Part No SW: 3G0 920 751 HW: 3G0 920 751
Component: KOMBI 306 5310
Coding: 07A509186F84000800887E021000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009003
ROD: EV_DashBoardJCIMQBAB_009_VW48.rod
VCID: 629EA01564C3ABC7E89-8036
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: 9309
VCID: 36362C4598CB6767741-8062
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000237677
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 13021510801117
Coding: 030300044F017300FF00025E1C0F00010001070000000000000000000000
ROD: EV_GatewConti_011_VW48.rod
VCID: 72BED055B4233B47989-8026
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150000191910095056
Coding: 2FFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 1727155603
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 1102201500010015
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000017911013
Coding: 0800000000000000
Shop #: WSC 00015 115 08193
ROD: EV_ELVMarquMQBB.rod
VCID: 71BCDF59B125005F613-8024
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 100215BB815682
Coding: 003F1A208000028000001000
VCID: 42DE4095C403CBC7C89-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 203 2033
Revision: 00000000 Serial number: 0000138065
Coding: 01000011005001
Shop #: WSC 00015 115 00320
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3B203D71A3E9BA0F8BF-806E
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 140215BBD16033
Coding: 003F00208000028000001000
VCID: 41DC4F99C105D0DFD13-8014
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 039A00004F210200
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: 3FD84961B7F1A62FA77-806A
Subsystem 1 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 0001
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 0001
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 3Q0 035 864 HW: 3Q0 035 864
Component: MU-S-N-ER H10 0140
Serial number: VWZAZ2R8531779
Coding: 02840201FF00000011110001000808001F010084012001008C
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 6E86C425A01B1FA77C1-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H42 1017
Serial number: VWZ8Z9RD8010UL
Subsystem 2 - Part No SW: 5NA 919 866 R HW: -----------
Component: ECE AS 19/20 --- 1115
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 0184020162002017000040
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID: 77A8E141DF415E6FAF7-8022
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 E
Component: HDSG-Modul H12 0253
Revision: -------- Serial number: 29838352100000
Coding: 0200
ASAM Dataset: EV_DeckLidCONTIAU736 001012
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 12091712P22095
Coding: 000408020000040101261344814EA80094000E300040
Shop #: WSC 06314 790 00021
VCID: 3C223E6DA6E7BD37825-8068
Part No SW: 5Q0 959 595 D HW: 5Q0 959 595 B
Component: TSG HFS 020 0028
Serial number: 040215BB11508A
Coding: 000E00200100028000001000
Component: TSG HBFS 020 0028
Serial number: 040215BB114204
End(Elapsed Time: 16:52, VBatt start/end: 11.9V/11.9V. VIgn 11.9V, Deb=2)--
;SW:3Q0-959-435-A HW:3Q0-959-435-A --- Acc/Start Auth.
;Component:VWKESSYMQB 033 0522, Coding:010E0E0703
;EV_KessyHellaMQBAB,004027,EV_KessyHellaMQBAB_VW48.rod
;Sunday,07,April,2019,09:26:18:49581
;VCDS Version: Release 18.9.1 (x64) Data version: 20190114 DS296.0
;VCID: 382A227D92DF911766D-806C
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,1B ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,not activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,not activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,not activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,0.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,120.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,not activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,0 %,2
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,0.00 s,2
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,0.00 s,2
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,0 ,2
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,0 %,2
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,1300 ms,2
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,50.00 s,2
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,96 ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,64 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,10 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,0 mV/m,5
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,not activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,not activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,4 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,7 B,1
ENG107595-MCTX settling phase,7 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,1000 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126938-Terminal_15_adaption_body_control_module,Default ,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
Elapsed Time: 00:51
09:
;SW:5Q0-937-086-BD HW:5Q0-937-086-BD --- Cent. Elect.
;Component:BCM PQ37BOSCH 028 0146, Coding:00051E66C24102FF13844084B11C57281C80000000000000000000000000
;EV_BodyContrModul1UDSBosc,014004,EV_BCMBOSCH_014.rod
;Sunday,07,April,2019,09:29:07:49581
;VCID: 7DA4F369FD7D743FF5B-8028
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2550 ms,12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1200 ms,12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1200 ms,12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
IDE01550-Service position,153.30 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.25 °,14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,14
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,20 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,10 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1A ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,09 ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,00 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,minimize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,minimize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,minimize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,minimize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,minimize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,minimize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,minimize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,minimize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,90 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,0 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,0 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,100 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,100 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,28 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,28 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,28 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,100 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,28 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,28 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,28 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,3A ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,39 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,36 ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,37 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,00 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,00 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,32 - allgemeine LED bis 12W ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,32 - allgemeine LED bis 12W ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,43 - allgemeine LED ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,34 - LED Bremsleuchten ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,37 - allgemeine LED bis 12W ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,not active ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,not active ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17,9 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,8 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,8 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,24 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,0 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,0 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,10 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,36 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,9 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,10 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,24 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,24 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,6 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,6 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,7 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,24 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,27 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,7 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,24 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,24 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,8 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,27 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,8 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,8 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,8 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,9 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,10 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,18 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,19 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 E2 28 49 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,23.00 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,53.00 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,53.00 °C,24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,active ,4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,24.89 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,present ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,0 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,0 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,0 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,0 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,0 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,0 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,8.30 °,2
IDE10299-Alternating park position 2,24.89 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.40 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,1 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,60 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,0 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,0 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,0 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,0 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,0 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,0 ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,60 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,60 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,60 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,60 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,60 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,60 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,60 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,60 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,60 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,60 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,2.0 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
MAS01490-Energy management,active ,1
MAS05055-lower turn position,26.30 °,2
MAS05056-upper turn position,171.30 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,3A ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,20 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake light ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,39 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,10 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake light ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Blinken links aktiv (beide Phasen) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Brake light ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Blinken rechts aktiv (beide Phasen) ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Brake light ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,90 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Brake light ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,37 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,09 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,34 - LED Bremsleuchten ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Brake light ,16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,28 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Nebellicht links ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,28 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Nebellicht rechts ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active ,8
Elapsed Time: 02:28
