Results 1 to 9 of 9
Thread: Oil level correction.
Hybrid View
    Verified VCDS User victor35ma's Avatar
    Nov 2014
    Los Angeles CA.
    hello, is it possible to make an oil level correction using VCDS?
    I got this car and we replaced engine oil 4.9L according to specs, but oil level is marking 1/4 bellow the MAX.
    [IMG]
    https://photos.app.goo.gl/BKn5kVt7EvB31V7f7
    [/IMG]
    Saturday,20,April,2019,15:04:58:23194
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
    VIN: WAUJF78K69N047743   License Plate: 6ZRP148
    Mileage: 180650km-112250mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72
              77
    VIN: WAUJF78K69N047743   Mileage: 180650km-112250miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Revision: E1H14---
       Coding: 0104010A02070160
       Shop #: WSC 22145 444 13987
       VCID: F9BA8A4A788348821A-80AC
    11 Faults Found:
    4527 - Coolant Fan Control Circuit 1
              P0480 00 [036] - Electrical Malfunction
                        Mileage: 180654 km
                        Coolant temperature: -40 °C
                        Intake air temperature: -40 °C
                        Ambient air pressure: 0 mbar
                        Voltage terminal 30: 12.368 V
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
              P0016 00 [237] - Incorrect Correlation
                        Fault Frequency: 51
                        Mileage: 178541 km
                        Date: 2019.02.26
                        Time: 17:35:19
                        Engine speed: 1115.00 /min
                        Normed load value: 6.7 %
                        Vehicle speed: 27 km/h
                        Coolant temperature: 77 °C
                        Intake air temperature: 47 °C
                        Voltage terminal 30: 13.782 V
    5671 - Boost Pressure Regulation
              P0299 00 [096] - Control Range Not Reached
                        Mileage: 180315 km
                        Date: 2019.03.13
                        Time: 18:14:34
                        Engine speed: 2327.50 /min
                        Normed load value: 82.4 %
                        Vehicle speed: 48 km/h
                        Coolant temperature: 96 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 14.324 V
                        Unlearning counter according OBD: 35
    4010 - Idle Control System
              P0506 00 [237] - RPM Lower than Expected
                        Mileage: 180646 km
                        Date: 2019.03.17
                        Time: 12:45:07
                        Engine speed: 643.00 /min
                        Normed load value: 20.4 %
                        Intake air temperature: 57 °C
    4054 - Cylinder 1
              P0301 00 [237] - Misfire Detected
                        Mileage: 180639 km
                        Date: 2019.03.17
                        Time: 08:08:18
                        Engine speed: 1343.00 /min
                        Normed load value: 31.8 %
                        Vehicle speed: 68 km/h
                        Coolant temperature: 82 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 13.923 V
    4060 - Cylinder 3
              P0303 00 [236] - Misfire Detected
                        Mileage: 180639 km
                        Date: 2019.03.17
                        Time: 08:08:18
    4063 - Cylinder 4
              P0304 00 [237] - Misfire Detected
                        Mileage: 180639 km
                        Date: 2019.03.17
                        Time: 08:08:18
    4057 - Cylinder 2
              P0302 00 [236] - Misfire Detected
                        Mileage: 180639 km
                        Date: 2019.03.17
                        Time: 08:08:18
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [237] - -
                        Mileage: 180639 km
                        Date: 2019.03.17
                        Time: 08:07:54
                        Engine speed: 1014.00 /min
                        Normed load value: 11.4 %
                        Vehicle speed: 16 km/h
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 13.593 V
    4106 - Bank 1; System too Rich at Idle
              P2188 00 [096] - -
    4201 - Fuel Level too Low
              P1250 00 [096] - -
       Part No SW: 8K0 927 155 AD    HW: 0AW 927 156 H
       Component: 0AW 20TFSIUSA H01 0004
       Revision: --H01---    Serial number: 0000000286
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMVL381 A02006
       ROD: EV_TCMVL381.rod
       VCID: F5A2867A549B2CE27E-80A0
    2225 - RPM Signal from ECU
              P0727 00 [108] - No Signal
                        Fault Frequency: 17
                        Mileage: 179883 km
                        Date: 2019.03.11
                        Time: 15:34:49
                        Engine speed: 100.00 /min
                        Transmission input speed: 1 /min
                        Transmission output speed: 1 /min
                        Engine torque: -40 Nm
                        Transmission fluid temperature: 20 °C
                        Accelerator position: 0.0 %
                        Clutch status: 13
       Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
       Component: ESP8 front    H04 0240
       Coding: 080500
       Shop #: WSC 02391 823 56573
       VCID: FCB4935E7FB17DAA01-80A8
       Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
       Component: BCM2 1.1      H80 0145
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: B3267862126F72D290-80E6
       Serial number: 0508000077145005
       Serial number: 0208000093481011
       Part No SW: 8T1 820 043 T    HW: 8T1 820 043 T
       Component: KLIMA 1 ZONE  H06 0150
       Revision: A0000000    Serial number: 01131120080598
       Coding: 64002000
       VCID: C2C82DA65DD5CB5A0B-8096
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 68
                        Mileage: 180654 km
                        Date: 2008.05.27
                        Time: 00:02:02
    00256 - A/C Pressure/Temperature Sensor (G395)
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 68
                        Mileage: 180654 km
                        Date: 2008.05.27
                        Time: 00:02:04
                        Temperature: 21.0°C
                        Temperature: 19.0°C
                        Load: 0.0 %
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 19.0°C
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Revision: 04022001    Serial number: 00000000268926
       Coding: 690000B1063C00010000080000007F5F0F14520800000021000000
       VCID: AF2E7412FE475632F4-80FA
       Component: WWS 211108  H06 0070
       Serial number: SWF08110216715
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 T    HW: 8K0 941 531 T
       Component: E1 - LDS  H07 0080
       Serial number: 00000000001111080968
       Subsystem 3 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
                        Fault Status: 00101100
                        Fault Frequency: 40
                        Reset counter: 104
                        Mileage: 177168 km
                        Date: 2019.01.31
                        Time: 13:15:00
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Serial number: 0039KD14KST+
       Shop #: WSC 02135 785 00200
       VCID: C0CC27AE5BD9D94A1D-8094
       Serial number: 5810000R0800002WSB
       Serial number: 6334MSME435226656
       Serial number: 6344MSME43522E52B
       Serial number: 6352QSME51120E066
       Serial number: 6362QSME74111030
       Serial number: 63732SME52132600I
       Serial number: 63832SME49050E28%
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HKI0008K
       Coding: 000034
       VCID: BD325E5A242BB4A276-80E8
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H17 0224
       Revision: 00000000    Serial number: 9DR28LNA8
       Coding: 8B1209000300D705020000
       VCID: AD126E1AF44B2422C6-80F8
       Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0095
       Revision: GB300043    Serial number: 4300G08B08830E
       Coding: 000303
       VCID: CBD600826A9F0A12F8-809E
       Component: J367-BDM  H04 0150
       Serial number: 18053E55051108
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Revision: 00000000
       Coding: 020302
       VCID: F8BC8F4E4B89518A65-80AC
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000008061733
       Coding: 011C03204000410001
       VCID: C1CA22AA58D3D04212-8094
       Revision: 00002001    Serial number: 0116040902
       Coding: 0106023A007A400400B001
       Component: GTO BF  H06 0040
       Serial number: 00000000000000102367
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 125
                        Mileage: 156261 km
                        Date: 2018.03.03
                        Time: 14:21:47
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 125
                        Mileage: 156261 km
                        Date: 2018.03.03
                        Time: 14:21:48
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S2100000
       Coding: 0203010102
       VCID: EE90A91639CD1F3ABF-80BA
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000008103707
       VCID: C0CC27AE53D9D94A1D-8094
                        Fault Frequency: 23
                        Reset counter: 108
                        Mileage: 177779 km
                        Date: 2019.02.17
                        Time: 11:16:32
       Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
       Component: EPB Audi B8   H06 0070
       Revision: 00000003    Serial number: 10000000131744
       VCID: B2287D66ED757BDA9B-80E6
       Part No SW: 8T1 035 186 K    HW: 8T1 035 186 K
       Component: Con3 Sirius   H01 0231
       Revision: 00000003    Serial number: AUZ5Z6H1147703
       Coding: 04020002010185004119070800
       VCID: BFCE24522E27A6B264-80EA
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
                000 -  -
                        Reset counter: 124
                        Mileage: 156259 km
                        Date: 2018.03.03
                        Time: 13:45:48
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000100499201
       Coding: 010C03204000210001
       VCID: C4C42BBE47C1C56A39-8090
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140782162359
       Coding: 0CD154
       VCID: B02C776EE37949CAED-80E4
       Revision:             Serial number: 0000100499198
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005027082
       Coding: 0010370
       Shop #: WSC 02256 785 00200
       VCID: BB365042FA3FBA9248-80EE
    End----(Elapsed Time: 01:48, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
                    Address 01: Engine  (8K2 907 115 AL)
    15:21:58
      IDE00025   Coolant temperature 94 °C
      IDE00151   Oil fill level 75.828 mm
      IDE00178   Camshaft adjustment intake bank 1: specified value 28.000 °
      IDE00179   Camshaft adjustment intake bank 1: actual value 27.953 °
      IDE00182   Camshaft adaptation intake bank 1: phase position -0.40 °
      IDE00347   Air mass: actual value: 2.97 g/s
      IDE00560-MAS04121   Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage 0.645 V
      IDE00560-MAS04122   Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation 99.2 %
      IDE00597   Long term adaptation of mixture formation bank 1 0.0 %
      IDE00604   Short term adaptation of mixture formation bank 1 0.0 %
      IDE03711   Mass flow through throttle valve 10.6 kg/h
    I am new to VCDS but... I will master it.
    Quote Originally Posted by victor35ma View Post
    No, you cannot change the oil level via the data port.
    I suppose you would like to change what it is displaying? And I guess this engine does not have a dip-stick?
    I don't have much faith in that display immediately after changing the oil. Drive car for a few days, see what it says then, and top it off.
    Oh, and better 3/4 full than over-filled!
    Nov 2014
    Los Angeles CA.
    I suppose you would like to change what it is displaying? -Uwe-
    yes and no. as you can notice in the log file it is full of oil 4.9L and also within 73 mm so it is a glitch...
    i just And I guess this engine does not have a dip-stick?
    you know it doesnt
    Ok... well, this car runs like that. it doesnt go eather low or ok . with 4.9L what is it? what is causing it?
    thanks again
    16.4905° S, 151.7375° W
    Hi there,
    Trust but verify!
    We used the T40178B - Oil Level gauge at the dealership.
    - You can find cheaper ones on the auction websites and other places. The Official Factory Repair manuals will have the charts for the proper level settings on the tool.
    Hope that helps,
    drpeter
    Jun 2014
    Newcastle, England
    Remember that the display is supposed to represent what you would see on the end of the dipstick. Typically it requires one litre to go from the bottom of that mark to the top. So in your case, about 300ml would see it at the top.
  6. Likes Eric, Jack@European_Parts, DrPeter, Uwe liked this post
    Nov 2014
    Los Angeles CA.
    look at the log file, it say IDE00151 Oil fill level 75.828 mm so it is ok. the display is wrong or not?
    I would not say the the display is wrong, it works for what it is, a consumer's way of checking the oil level and technically not to be used when servicing the vehicle, that is why the T40178B - Oil Level gauge.
    Maybe you can find a dipstick for this engine that will work?
    drpeter
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #8
    People have successfully installed directly through the drain plug center being drilled and running a hose to engine to keep sealed a telescope site glass too.
  11. Likes DrPeter liked this post
  12. #9
    https://www.ebay.com/itm/Audi-A4-A5-...YAAOSwOA1aF9ng
    https://www.ebay.com/itm/401447767853
    This seemed to be a reasonable price at like 20 bucks compared to the Snap-On one for $150
    Not endorsed but all I'm saying is look around!
  13. Likes Uwe liked this post
