P1127 & P0172 - Too Rich codes
   #41
dodaman
C?ID=332400
👍🏻 Thank you
   #42
dodaman
C?ID=332400
Hello All.
Sorry to revive the older threads, but I am having the same issues again and thought I'd keep it all within my original thread. The scan is below. FYI, I had the CEL come on again the other day. I reset it and had to go on a 400 mile round trip this weekend. It came back on with about 150 miles to go. I ran the scan when I got home as well as the measuring blocks. the Lambda readings were coming up rather negative again. -13 to -17 range. FYI. over the past 8 or 9 months since this thread, I have used MMO and fuel cleaner twice to help keep the system clean. Anyway, I did a fuel rail pressure test. All numbers came back good. I checked the plugs. They are all fine. The N80 was working fine. I ran a test on the EGR via Vagcom. IT seems to be fine. I decided to redo a smoke test. This came with interesting results. I took off MAF and hose and hooked up test to the hard plastic hose that connects to throttle body, ( don't know name of this) No smoke leaking at all. Then thought I'd try it with accordion hose on. After a couple minutes, there was a good amount of smoke coming from under the seal where the accordion hose go onto the hard plastic one, (out from under that spring clamp). see pic. I tried repositioning the clamp, but it kept coming out. I took off the hose and checked the hard plastic piece for any cracks, Nada. Then made a DIY pressure test for accordion hose. No light, water or air came out from anywhere. So I pulled the clamps hard to try and tighten them up a bit. and put them back on.
It was a good amount of smoke rolling out, so I'm thinking this my issue is again; unmetered air coming in after the MAF. and I wonder what thoughts you all have. Should I just buy a new or used hose set up. Is there a high temp tape anyone has used between the two pieces under the clamp to help keep air out. Try a different clamp. Thanks for everyone's advice. Have a good night.
here is the image. The smoke is coming from just under the green arrow.
https://imgur.com/NYLpS5W
Monday,04,May,2020,14:58:43:29843
VIN: WAUDT48H35K005891   License Plate: RICH REPORT 5-4-20
Mileage: 58960km-36636mi   Repair Order:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUDT48H35K005891   Mileage: 58960km-36636miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E1 909 559 B    HW: 8E0 909 059 A
   Component: 3.0L V6/5V      G   0030
   Revision: 00000000    Serial number: AUZ6Z0D0285717
   Coding: 0013754
   Shop #: WSC 00672 785 00200
   VCID: 3537DC2D09563F93B04-5160
17535 - Fuel Trim; Bank 1 (Mult)
            P1127 - 002 - System too Rich - Intermittent
16556 - Fuel Trim; Bank 1
            P0172 - 002 - System Too Rich - Intermittent - MIL ON
17537 - Fuel Trim; Bank 2 (Mult)
            P1129 - 002 - System too Rich - Intermittent
16559 - Fuel Trim; Bank 2
            P0175 - 002 - System Too Rich - Intermittent
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8E0 927 156 AB
   Component: AG5 01V 3.0l5VT USA 0404
   Coding: 0001002
   VCID: 6E8533412C804C4BB1E-5160
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      4529
   Coding: 04497
   Shop #: WSC 00672
   VCID: 26150B61C1F0440B09E-51A8
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1424
   Coding: 00100
   Shop #: WSC 00672
   VCID: 63935275F242F1232E0-513C
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   VCID: 3537DC2D0C563F93B04-4AE0
02104 - Light Detection Sensor (G399)
            29-10 - Short to Ground - Intermittent
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 D
   Component: Airbag 8.4EC        0015
   Coding: 0010105
   VCID: 3B23CA152F72E9E3460-5160
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 02041
   Shop #: WSC 00672
   VCID: 3E25C3013960FCCB61E-4AE0
   Part No: 8H0 920 950 H
   Component: KOMBI+WEGFAHRS. RB4 D22
   Coding: 01401
   Shop #: WSC 09401
   VCID: 313FE83DF83E13B3ECC-5160
   WAUDT48H35K005891     AUZ6Z0D0285717
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255
   Component:  VSG  B6 CABRIO     6386
   VCID: 73B3223547A261A35E0-5160
   Part No: 8H0 959 760
   Component: Sitzmemory EE H06   0010
   Coding: 00002
   Shop #: WSC 00065
   VCID: 74B12129479C669B47A-4B1E
   Part No: 8H0 959 433 E
   Component: Komfortgerát T7B    3320
   Coding: 11820
   Shop #: WSC 00672
   VCID: 3635DB211150348BB9E-4AE0
   Subsystem 1 - Part No: 8H1959801B
   Component: Tõrsteuer.FS BRM 3020
   Subsystem 2 - Part No: 8H1959802B
   Component: Tõrsteuer.BF BRM 3020
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
   Part No: 4Z7 907 357
   Coding: 00070
   Shop #: WSC 00672
   VCID: 045171E9173C561B77A-4B1E
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F M H13   0010
   Coding: 00006
   Shop #: WSC 00065
   VCID: 3537DC2D0C663F93B04-4B1E
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H13   0010
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 05:14, VBatt start/end: 12.2V/12.2V)-----------
Fahrvergnugen
Montrose, CO, USA
C?ID=363037
What was your result, Dodaman? I've got a '06 Quattro Cabrio 3.0 wA/T with similar codes, but only on one bank, not both.
