Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: P1127 & P0172 - Too Rich codes
  1. #21
    Should be a code by second DCY or its FOD!
    JPPSG.........
    Please post OBD2 MODES 1,3,7 & 9 Thank you!
  2. #22
    May 2018
    JPPSG.........
    Ok thx. I’ll keep an eye out and see if it comes back on.
  3. #23
    May 2018
    Just saw your last part of that post about I’ll take that scan and send those over to you. Thank you very much have a great night
  5. #24
    May 2018
    Hi Jack.
    I ran the reports. You’ll have to excuse the novice here. I’ve never run OBD2. So I’m not exactly sure what you meant. I think is was the numbered modes you stated. But with mode 1, I wasn’t sure which numbers you wanted in the drop down menu. I did 3,7,9 since there was no #1 within mode 1. If I screwed up, let me know. Thanks. I’ll post what I did in a little bit. Thanks again.
  6. #25
    Mode 1-1 for readiness and MIL display.
  7. #26
    May 2018
    Ok, Thanks, I'll run that tomorrow.
  8. #27
    May 2018
    Morning Jack,
    Here are my scans. I did the following, mode 1-1, 3, 7, 9 and a mode 1 with LTFT in drop down box. I also ran regular VCDS scan just in case. I wasn't sure if it would make a difference, but I compared them with car running and off. They came out the same as you probably knew. I look forward to hearing from you. Thanks.
    Monday,29,April,2019,09:05:06:29843
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN:    License Plate: MODE 1
    VCDS Release 18.9.1 (x64):  Generic OBD2
    Mode 1:Read Data
    07:Long Term Trim - Bank 1     -14.1 %
    09:Long Term Trim - Bank 2     -11.7 %
    Monday,29,April,2019,09:06:16:29843 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4 Data version: 20190114 DS296.0 www.Ross-Tech.com VIN: License Plate: MODE 1-1 Mode 01 - PID 01 : Readiness -- Address 10 Number of DTCs stored: 0 -- MIL Status: MIL OFF Misfire monitoring: Passed Fuel System: Passed Comprehensive Components: Passed Catalyst monitoring: Passed Heated catalyst monitoring: Not installed. Evaporative system monitoring: Passed Secondary air system monitoring: Passed A/C system refrigerant monitoring: Not installed. Oxygen sensor monitoring: Passed Oxygen sensor heater monitoring: Passed Exhaust Gas Recirculation: Not installed.
    Monday,29,April,2019,09:09:06:29843
    VIN:    License Plate: MODE 3
    Mode 03: Emission related fault codes
    Address 10 (Engine): No fault code found.
    Address 1A (Auto Trans): No fault code found.
    Monday,29,April,2019,09:08:32:29843
    VIN:    License Plate: MODE 7
    Mode 07: Pending emission related fault codes
    Monday,29,April,2019,09:08:01:29843
    VIN:    License Plate: MODE 9
    Mode 9 : Calibration Identification
    Type 02 - VIN : WAUDT48H35K005891 (Address 10)
    Type 04 - Calibration ID : 8E1909559B  0030 (Address 10)
    Type 04 - Calibration ID : 8E0927156AB 0404 (Address 1A)
    Type 06 - Calibration Verification Number : 9372EBA5 (Address 10)
    Type 06 - Calibration Verification Number : 0000D183 (Address 1A)
    Sunday,28,April,2019,20:06:54:29843
    VIN: WAUDT48H35K005891   License Plate: REG SCAN 4-28
    Mileage: 46060km-28620mi   Repair Order:
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
              63 65 67 73 75 76 77
    VIN: WAUDT48H35K005891   Mileage: 46060km-28620miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E1 909 559 B    HW: 8E0 909 059 A
       Component: 3.0L V6/5V      G   0030
       Revision: 00000000    Serial number: AUZ6Z0D0285717
       Coding: 0013754
       Shop #: WSC 00672 785 00200
       VCID: 3537DC2D09563F9F7DB-5160
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 8E0 927 156 AB
       Component: AG5 01V 3.0l5VT USA 0404
       Coding: 0001002
       VCID: 6E8533412C804C477C1-5160
    Address 03: ABS Brakes        Labels: None
       VCID: 55F77CADAC161F9F9DB-51A8
    No Faults Found
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1424
       Coding: 00100
       Shop #: WSC 00672
       VCID: 63935275F242F12FE3F-513C
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       VCID: 3537DC2D0C563F9F7DB-4AE0
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 D
       Component: Airbag 8.4EC        0015
       Coding: 0010105
       VCID: 3B23CA152F72E9EF8BF-5160
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 02041
       Shop #: WSC 00672
       VCID: 3E25C3013960FCC7AC1-4AE0
       Part No: 8H0 920 950 H
       Component: KOMBI+WEGFAHRS. RB4 D22
       Coding: 01401
       Shop #: WSC 09401
       VCID: 313FE83DF83E13BF213-5160
       WAUDT48H35K005891     AUZ6Z0D0285717
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255
       Component:  VSG  B6 CABRIO     6386
       VCID: 73B3223547A261AF93F-5160
       Part No: 8H0 959 760
       Component: Sitzmemory EE H06   0010
       Coding: 00002
       Shop #: WSC 00065
       VCID: 74B12129479C66978A5-4B1E
       Part No: 8H0 959 433 E
       Component: Komfortgerát T7B    3320
       Coding: 11820
       Shop #: WSC 00672
       VCID: 3635DB2111503487741-4AE0
       Subsystem 1 - Part No: 8H1959801B
       Component: Tőrsteuer.FS BRM 3020
       Subsystem 2 - Part No: 8H1959802B
       Component: Tőrsteuer.BF BRM 3020
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
       Part No: 4Z7 907 357
       Coding: 00070
       Shop #: WSC 00672
       VCID: 045171E9173C5617BA5-4B1E
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H13   0010
       Coding: 00006
       Shop #: WSC 00065
       VCID: 3537DC2D0C663F9F7DB-4B1E
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H13   0010
       Coding: 00005
       Shop #: WSC 00065
    End----------(Elapsed Time: 05:33, VBatt start/end: 12.2V/12.2V)-----------
  9. #28
    May 2018
    Hello Jack and Uwe,
    I was wondering if either one of you had any other ideas or suggestions. Sorry to push. I’m kinda new with this Audi and am not looking forward to any love/hate thing I read about so often 😃. Maybe I’m overthinking it and just need wait to see if the CEL lights comes back. I appreciate any input you both may have. Thanks. Enjoy your evenings.
  10. #29
    Watch the fuel trims. That should give you a pretty good indication whether you've got the problem under control. Also do the MAF test again to see if it now produces values more in line with what's expected.
  11. Likes Jack@European_Parts liked this post
  12. #30
