Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: P1127 & P0172 - Too Rich codes
    May 2018
    Hello All,
    Newbie here. I have a bout of throwing some rich codes. (posted below) and wanted to see if you experts could help out. FYI, I have the 3.0L engine with about 28,500 miles on it. The check engine came on about a 3 weeks ago. I looked at the codes, and checked on this site for possible issues. I started the diagnosis process on the air side. I cleaned the MAF and erased the codes. After about 200 of city/hwy miles, the CEL came back with same results. I wanted to add. I changed the fuel filter about 5000 miles ago. All plugs with correct gap and coil packs were changed about 2000 miles ago). Air filter was changed less than 5000 miles ago. I haven't checked anything yet on the fuel side, i.e. pressure, leaks, etc. (I also included a full scan result after the fuel trim report) Thanks everyone. I'm looking forward to hearing from you. Have a great day.
    *I cleaned the MAF
    *checked the power and ground connections from the car to the MAF plug, (all good)
    *ran logs on the fuel trims, each time CEL came on, the negative values were just about the same, (posted one below)
    *I ran 4 redline tests to check the numbers on the MAF. I didn't take logs, but in 2nd gear at about 6400rpm's, the MAF #'s were 98g/s and 102g/s the first day, 124g/s and 108g/s on second day. that is a far cry from the 80% of max HP (220 x .80=176).
    *did a smoke test to check for vacuum leaks, found a hose just past the MAF, that had leak from original crimp clamp. Replaced that and after retest, no leaks anywhere.
    Log:
    Address 01: Engine (8E1 909 559 B)
    13:53:34 Group 032: Lambda Control (Mixture Adaptation)
    1.5 % Adaptation (Idle) Bank 1 Sensor 1
    -17.2 % Adaptation (Partial) Bank 1 Sensor 1
    0.8 % Adaptation (Idle) Bank 2 Sensor 1
    -14.1 % Adaptation (Partial) Bank 2 Sensor 1
    13:53:34 Group 033: Lambda Control
    -2.3 % Lambda Control Bank 1 Sensor 1
    1.540 V Sensor Voltage Bank 1 Sensor 1
    -1.6 % Lambda Control Bank 2 Sensor 1
    1.540 V Sensor Voltage Bank 2 Sensor 1
    13:53:34 Group 002: General
    800 /min Engine Speed (G28)
    18.8 % Engine Load
    2.87 ms Injection Timing
    4.92 g/s Mass Air Flow (G70)
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E1 909 559 B    HW: 8E0 909 059 A
       Component: 3.0L V6/5V      G   0030
       Revision: 00000000    Serial number: AUZ6Z0D0285717
       Coding: 0013754
       Shop #: WSC 00672 785 00200
       VCID: 3537DC2D09563F9F7D3-5160
    17535 - Fuel Trim; Bank 1 (Mult)
                P1127 - 002 - System too Rich - Intermittent
    16556 - Fuel Trim; Bank 1
                P0172 - 002 - System Too Rich - Intermittent
       Part No: 8E0 927 156 AB
       Component: AG5 01V 3.0l5VT USA 0404
       Coding: 0001002
       VCID: 6E8533412C804C477C9-5160
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      4529
       Coding: 04497
       Shop #: WSC 00672
       VCID: 26150B61C1F04407C49-51A8
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1424
       Coding: 00100
       Shop #: WSC 00672
       VCID: 63935275F242F12FE37-513C
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 00672
       VCID: 3537DC2D0C563F9F7D3-4AE0
    02104 - Light Detection Sensor (G399)
                29-10 - Short to Ground - Intermittent
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 D
       Component: Airbag 8.4EC        0015
       Coding: 0010105
       VCID: 3B23CA152F72E9EF8B7-5160
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 02041
       Shop #: WSC 00672
       VCID: 3E25C3013960FCC7AC9-4AE0
       Part No: 8H0 920 950 H
       Component: KOMBI+WEGFAHRS. RB4 D22
       Coding: 01401
       Shop #: WSC 09401
       VCID: 313FE83DF83E13BF21B-5160
       WAUDT48H35K005891     AUZ6Z0D0285717
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255
       Component:  VSG  B6 CABRIO     6386
       VCID: 73B3223547A261AF937-5160
       Part No: 8H0 959 760
       Component: Sitzmemory EE H06   0010
       Coding: 00002
       Shop #: WSC 00065
       VCID: 74B12129479C66978AD-4B1E
       Part No: 8H0 959 433 E
       Component: Komfortgerát T7B    3320
       Coding: 11788
       Shop #: WSC 00672
       VCID: 3635DB2111503487749-4AE0
       Subsystem 1 - Part No: 8H1959801B
       Component: Tőrsteuer.FS BRM 3020
       Subsystem 2 - Part No: 8H1959802B
       Component: Tőrsteuer.BF BRM 3020
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
       Part No: 4Z7 907 357
       Coding: 00070
       Shop #: WSC 00672
       VCID: 045171E9173C5617BAD-4B1E
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H13   0010
       Coding: 00006
       Shop #: WSC 00065
       VCID: 3537DC2D0C663F9F7D3-4B1E
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H13   0010
       Coding: 00005
       Shop #: WSC 00065
    End----------(Elapsed Time: 05:30, VBatt start/end: 12.5V/12.6V)-----------
    Multiplicative trim issue mean its air or fuel issue after the MAF and since intermittent maybe an injector failing or sticking from age or being dirty.
    Take out injectors and tank, replace or try a fuel additive & a shot glass of marvel mystery oil to lubricate the fuel system.
  3. Likes Ashraf6119 liked this post
    Quote Originally Posted by dodaman View Post
    Yes it is.
    These values were with the pedal to the metal?
    Since this is a naturally aspirated engine, are you somewhere close to sea level?
    May 2018
    Take out and tank, replace or try a fuel additive & a hot glass of marvel mystery oil to lubricate the fuel system.
    Ok thanks. Yes, the nice older lady that owned it didn't put many miles on it. I bought it 16 months ago with only 18,500 on it, which in itself can be an issue. I was planning on doing a fuel pressure test and using some sort of Seafoam or Mystery oil. Appreciate the advice.
    Also check MAF filter box & pre-screen from ram air for blockage FOD! & not permitting enough air!
    It is apparent that this car has sit for a bit.
    May 2018
    Yes it is.
    Yes, I am I live 10 miles north of the white house in DC
  8. Likes Uwe liked this post
    May 2018
    I should have mentioned that. The screen and box are all fine. Everything up to the throttle body was clean as well as the throttle body itself.
  10. Likes Jack@European_Parts, Uwe liked this post
  11. #8
    May 2018
    Ok, I put some techron Cleaner in it and a bit of MMO. ���� It unclogs or does the trick. I’ll report back. Appreciate it.
  12. #9
    May 2018
    Yes it is.
    Yes, pedal down to the floor in 2nd gear.
  13. #10
    Well, your MAF readings should be higher.
    But the "Too Rich" codes are the opposite of what we usually see when a MAF under-reports actual airflow.
    Does this car feel like it has 220 hp?
