Good morning, i've just received my HEX-NET VCDS hardware and am very excited to try my hand at this!
My first "repair" is to set a 2006 Bentley Continental GT back to its factory (North American) ride height. The car is much lower than even the Euro setting at the moment, i suspect a past owner cheated by mis-entering the suspension level adaptation values. The car currently measures 378mm both front/rear, the factory ride height is 395/394mm front/rear as per http://wiki.ross-tech.com/wiki/index.php/Bentley_Non_UDS_Level_Control
However when I follow the adaptation instructions laid out in this detailed procedure https://forums.vwvortex.com/showthread.php?2055204 I cannot enter any value other than 395mm in the "new" field. Any other value will return "invalid" when I press test. The measured value is really 378mm, waaay off from where the car thinks it is.
Then to make this even more confusing, i cant even change the soft coding value from 0005561 to anything else (ideally 0007761), i get an out of range error. its like this module wont take any changes at all.
I have run an autoscan, and it shows no codes except for 34-level control (i caused this by terminating the adaptation before completion).
I hope i've missed a simple step, or overlooked something, any assistance would be amazing.
-Alexander
Sunday,21,April,2019,14:04:29:30897
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: SCBCR63W26C037857 License Plate:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCR63W26C037857 Mileage: 78610km-48845miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No SW: 07C 906 018 DF HW:
Component: BY-6.0L-TT G ª7948
Revision: 10ÿTT Serial number: 000-00004.02.
Coding: 0000173
VCID: 6C81C5D66A9C7C77525-513C
Readiness: 0110 1101
Part No SW: 09E 927 760 M HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1909
Coding: 0000101
Shop #: WSC 00083 000 00000
VCID: 3A2D338E504812C7909-5160
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 D
Component: ESP 5.7 4WD H01 0021
Coding: 0007878
Shop #: WSC 03266 000 00000
VCID: 363527BE6450F6A7741-51F2
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 C HW: 5WK 484 97
Component: 43 Kessy 6700
Revision: 67005915 Serial number: VWZ3Z0F7449092
Coding: 0405741
VCID: 270BFAFAB3FA9F2FFF7-5160
Component: ELV XXXX
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000001
Shop #: WSC 03241 104 65153
VCID: 47CB5A7A13BA7F2F1F7-5160
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 F
Component: ZAB COCKPIT 0253
Coding: 0400325
VCID: 303911A68634D8972ED-5160
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 E
Component: Climatronic BY614 2010
Coding: 0000102
VCID: 33331EAA7722E38F53F-5160
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000105
Shop #: WSC 05016 104 175110
VCID: 2F3B12DA9B0AC76F377-5160
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Revision: 00ÿTT Serial number: 000-00004.02.
Coding: 0000173
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 2517F0F2C9F68D3FCDB-5160
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
VCID: 2E050FDE9C00CE673C1-5160
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W8 920 840 C
Component: KOMBIINSTRUMENT RB8 0610
Coding: 0023203
VCID: 3C2135965A7C2CF7825-5160
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D1A646B498976ED-5160
Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W0 907 553 A
Component: LUFTFDR.-CDC- 3C3V0 7203
Coding: 0005561
Shop #: WSC 05017 104 175094
VCID: 382929866E4400D766D-5160
01437 - Control Position not Learned
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000001
Shop #: WSC 03259 103 80636
VCID: 3FDB429A4B6A37EFA77-5160
Address 37: Navigation Labels: None
Part No: 3W0 919 887 A
Component: NAVIGATION 0187
Coding: 0400000
VCID: 45D7507229B66D3FEDB-5160
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 E
Component: Dachmodul 0707
Coding: 0002493
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 D
Component: 12K-AUDIOVERST 4123
VCID: 353720B27956FDBF7DB-5160
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022401
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 303911A68334D8972ED-51F2
Address 65: Tire Pressure Labels: None
Part No: 3W7 907 273
Component: Reifendruckueberw. 0003
Coding: 0480311
VCID: 7DA7F89201E6E5FFF5B-5160
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 E
Component: Wische$
Shop #: WSC 00000 725 65552
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 2313EEEAC7C2730FA3F-5160
Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283 A
Component: 02 Einparkhilfe 0303
VCID: 3B23368A5F722BCF8BF-5160
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 J HW: 3W0 035 385 J
Component: rSAP ECU 0037
Coding: 0000272
End----(Elapsed Time: 08:13, VBatt start/end: 13.7V/13.7V. VIgn 0.0V)------
-Alexander
