Results 1 to 10 of 12
Thread: Bentley Continental GT 34-level control module will not accept values for adaptation
    Apr 2019
    Canada
    Good morning, i've just received my HEX-NET VCDS hardware and am very excited to try my hand at this!
    My first "repair" is to set a 2006 Bentley Continental GT back to its factory (North American) ride height. The car is much lower than even the Euro setting at the moment, i suspect a past owner cheated by mis-entering the suspension level adaptation values. The car currently measures 378mm both front/rear, the factory ride height is 395/394mm front/rear as per http://wiki.ross-tech.com/wiki/index..._Level_Control
    However when I follow the adaptation instructions laid out in this detailed procedure https://forums.vwvortex.com/showthread.php?2055204 I cannot enter any value other than 395mm in the "new" field. Any other value will return "invalid" when I press test. The measured value is really 378mm, waaay off from where the car thinks it is.
    Then to make this even more confusing, i cant even change the soft coding value from 0005561 to anything else (ideally 0007761), i get an out of range error. its like this module wont take any changes at all.
    I have run an autoscan, and it shows no codes except for 34-level control (i caused this by terminating the adaptation before completion).
    Sunday,21,April,2019,14:04:29:30897
    VIN: SCBCR63W26C037857   License Plate:
    Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
              37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
    VIN: SCBCR63W26C037857   Mileage: 78610km-48845miles
    Address 01: Engine        Labels: 07C-906-018-BEB1.clb
       Part No SW: 07C 906 018 DF    HW:
       Component: BY-6.0L-TT      G  ª7948
       Revision: 10ÿTT       Serial number:  000-00004.02.
       Coding: 0000173
       VCID: 6C81C5D66A9C7C77525-513C
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 09E-927-156.lbl
       Part No SW: 09E 927 760 M    HW: GS1 904 1
       Component: AG6 09E 6.0L W12TT  1909
       Coding: 0000101
       Shop #: WSC 00083 000 00000
       VCID: 3A2D338E504812C7909-5160
    Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
       Part No: 3W0 614 517 D
       Component: ESP 5.7 4WD     H01 0021
       Coding: 0007878
       Shop #: WSC 03266 000 00000
       VCID: 363527BE6450F6A7741-51F2
       Part No SW: 3D0 909 137 C    HW: 5WK 484 97
       Component: 43 Kessy            6700
       Revision: 67005915    Serial number: VWZ3Z0F7449092
       Coding: 0405741
       VCID: 270BFAFAB3FA9F2FFF7-5160
    Address 06: Seat Mem. Pass        Labels: None
       Part No: 3W0 959 759 A
       Component:    CM Seat Pass.    0009
       Coding: 0000001
       Shop #: WSC 03241 104 65153
       VCID: 47CB5A7A13BA7F2F1F7-5160
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3W0 035 008 F
       Component:    ZAB COCKPIT      0253
       Coding: 0400325
       VCID: 303911A68634D8972ED-5160
    Address 08: Auto HVAC        Labels: 3W7-907-040.clb
       Part No: 3W0 907 040 E
       Component: Climatronic BY614   2010
       Coding: 0000102
       VCID: 33331EAA7722E38F53F-5160
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 H
       Component: STG.Bordnetz        5101
       Coding: 0000105
       Shop #: WSC 05016 104 175110
       VCID: 2F3B12DA9B0AC76F377-5160
    Address 11: Engine II        Labels: 07C-906-018-BEB2.clb
       Revision: 00ÿTT       Serial number:  000-00004.02.
       Coding: 0000173
    Address 15: Airbags        Labels: 3D0-909-601.lbl
       Part No: 3D0 909 601 E
       Component: 0P Airbag 8.4E+ H10 0936
       Coding: 0012368
       VCID: 2517F0F2C9F68D3FCDB-5160
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 D
       Component: Lenksäulenmodul     3401
       Coding: 0000012
       VCID: 2E050FDE9C00CE673C1-5160
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No: 3W8 920 840 C
       Component: KOMBIINSTRUMENT RB8 0610
       Coding: 0023203
       VCID: 3C2135965A7C2CF7825-5160
       Part No: 6N0 909 901
       Component: Gateway K<>CAN      0101
       Coding: 0000006
       VCID: 70B9D1A646B498976ED-5160
    Address 34: Level Control        Labels: 3Wx-907-553-34.clb
       Part No: 3W0 907 553 A
       Component: LUFTFDR.-CDC- 3C3V0 7203
       Coding: 0005561
       Shop #: WSC 05017 104 175094
       VCID: 382929866E4400D766D-5160
    01437 - Control Position not Learned
       Part No: 3W0 959 760 A
       Component:    CM Seat Driver   0008
       Coding: 0000001
       Shop #: WSC 03259 103 80636
       VCID: 3FDB429A4B6A37EFA77-5160
    Address 37: Navigation        Labels: None
       Part No: 3W0 919 887 A
       Component:    NAVIGATION       0187
       Coding: 0400000
       VCID: 45D7507229B66D3FEDB-5160
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 E
       Component: Dachmodul           0707
       Coding: 0002493
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3W0 035 456 D
       Component: 12K-AUDIOVERST      4123
       VCID: 353720B27956FDBF7DB-5160
    Address 53: Parking Brake        Labels: 3W0-907-801.clb
       Part No SW: 3W0 907 801 B    HW: 3W0 907 801 B
       Component: EPB  BC6HX23    HC6 X230
       Coding: 0022401
    Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
       Part No: 1C0 959 733 H
       Component: Heckspoiler         0002
       VCID: 303911A68334D8972ED-51F2
    Address 65: Tire Pressure        Labels: None
       Part No: 3W7 907 273
       Component: Reifendruckueberw.  0003
       Coding: 0480311
       VCID: 7DA7F89201E6E5FFF5B-5160
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W1 955 023 E
       Component: Wische$
       Shop #: WSC 00000 725 65552
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 C
       Component: Batteriemanagement  2700
       VCID: 2313EEEAC7C2730FA3F-5160
    Address 76: Park Assist        Labels: Redir Fail!
       Part No: 3W0 919 283 A
       Component: 02 Einparkhilfe     0303
       VCID: 3B23368A5F722BCF8BF-5160
    Address 77: Telephone        Labels: None
       Part No SW: 3W0 035 385 J    HW: 3W0 035 385 J
       Component: rSAP ECU            0037
       Coding: 0000272
    End----(Elapsed Time: 08:13, VBatt start/end: 13.7V/13.7V. VIgn 0.0V)------
    I hope i've missed a simple step, or overlooked something, any assistance would be amazing.
    -Alexander
    16.4905° S, 151.7375° W
    Just wonder, how is the compressor? You should be able to reach and hold at least 6 bar of pressure (see Basic Settings Group [023])
    I would start with the Basic Settings to manually raise the ride height to approximately where it needs to be. Then see if the system will allow you to complete the adaptations. This will also insure the compressor can perform as expected. Use the Security Access code [08367] for the Basic Setting Enabling.
    You can access the Basic Settings raise and lower functions in the Pull-down menu, do this with the vehicle on a flat level surface and the engine running in a well ventilated area.
    If this does not seem to help, you could also try the Ride Adaptations with values that are 5mm (or more) greater than what you are currently reading. That way the controller thinks the ride right is closer to the target ride height than it actually is and may allow the adaptation function to complete.
    If that works, then perform the ride height again and see if it will accept the current readings, if not you will need to continue this 'stepped' approach to have the system eventually learn the correct or desired ride heights.
    Hope this helps,
    drpeter
  3. Likes Bruce, atdown, Jack@European_Parts liked this post
    Apr 2019
    Canada
    Quote Originally Posted by DrPeter View Post
    Hope this helps,
    drpeter
    Thanks for the suggestions Peter. The air pressure (i dont have a screenshot, from memory..) was about 10 bar. I'll give the basic settings a try. The car lowers/raises itself when i initialize the adaptation. So i know its functioning at least on some level.
    Any insight on why i cant change the soft coding from XXX55XX?
    -Alexander
    Quote Originally Posted by atdown View Post
    IIRC, the "Stored Value" in these channels is always the height that the car should be at. It should not be construed as any kind of actual measurement.
    Try changing those channels 5mm at a time.
  6. Likes atdown liked this post
    Apr 2019
    Canada
    Try changing it 5mm at a time.
    Thanks Uwe.
    The only values adaptation will accept are 393-395. I have tried changing all corners to 1mm lower than the "stored value" (from 395 to 394mm), that doesnt throw up any objections in VCDS. However after that if i run another adaptation the "stored values" are back to 395 all round.
    -Alexander
    -edit-
    in hindsight, this behavior is probably normal. If the car wants to be at 395, the "stored value" wont change. I'll have to try 10 adaptations to see if i can move the level a measurable amount. If i was able to change the coding from xxx55xx to xxx77xx i would see the "stored value" change. (is that correct?)
    Since there are several different J197-Level Control controllers that are used in different vehicle types, the Coding Helper displays all of the know coding possibilities, however not all the coding possibilities that are listed in the Coding Helper will be not accepted by all controllers.
    In fact, after a little research, (searching through all the Bentley and other Auto-Scans) I have found the coding value of [0005561] is the only one that is used in the 34-Level Control for the 3W-Bentley. So at this time, it does not appear to be a coding issue.
    Just to make sure we are on the same page, could you post the ride height measurements for all four corners you see at the beginning of the 'Suspension Level Control Calibration' procedure? This is thee point where you are about to enter your first value.
    One last thing.... You are following this procedure too, right? Suspension Level Control Calibration We also have a Video that will help, just in case you have not seen it.
    drpeter
  9. Likes atdown, Jack@European_Parts liked this post
  10. #7
    Apr 2019
    Canada
    Thanks for digging deeper into this drpeter!
    That's good to know 0005561 is the only possible coding, im not going crazy!
    The measured ride height is:
    Front right 378
    Front left 379
    Rear right 380
    Rear left 378
    (all +/- a couple of millimeters depending on how aggressively i've bounced the suspension)
    Yes, i'm following your linked procedure to the letter. Is there any more diagnostic info i can screenshot that would be helpful?
    -A
  11. #8
    These "objections" are not from VCDS, they are from the module itself.
    I've seen a similar module in a 7L Touareg refuse to accept largish changes, which is why I recommended 5mm at a time, but I've never seen one only accept 1 or 2mm at a time, so that's bit puzzling.
    In hindsight, this behavior is probably normal. If the car wants to be at 395, the "stored value" wont change. I'll have to try 10 adaptations to see if i can move the level a measurable amount.
    Yes, I would expect 395 to be the stored value again each time.
    Although those codings were documented by the factory at one point, I do have recollection that some modules would not allow them to be changed.
  12. #9
    Apr 2019
    Canada
    Hope this helps,
    drpeter
    Drpeter, i attempted to use basic settings to manually raise/lower the ride height, however i didnt see any obvious raise/lower functions in the pull down menu.
    i tried (gingerly) the front axle filling selection and pressed ON/OFF/Next, but i didnt see any reaction from the suspension. Are you able to provide some more direction?
    Much appreciated
    -A
  13. #10
    I have found that marking the level sensors for a timing basic location saving settings & to a suspicion component while referencing a sensor reading in VCDS or DVOM at sensor to triangulate and then tweaking them to the desired value to obtain the height, is just easier sometimes.
    I also find this method easier for adaptions to be done versus running a pump to over heat it.
    Ever think of finding a coupling nut and two jam nuts fabricated make for easy settings fast or for modified calculations to be achieved?
    Reason I say this is maybe sensor locations are already altered with FOD!
