Results 1 to 10 of 10
Thread: Audi Q7 Battery Replacement?
    Sep 2018
    New Zealand
    Hi Everyone,
    I picked up an '07 Q7 a few months ago. Someone has done a poor job of installing face lift headlights and tail lights, so please disregard the light faults (this is on the list of things to resolve)
    A couple of days ago the central locking stopped working. After looking at the scan, I am thinking it is a faulty/failed battery that is causing the issues. Looking at module 061 and blocks 1, 4 and 10, the voltage of the battery with the engine off is only 11.65V. With the engine on I get a good 14.3V at the alternator and 46A, so it looks to me that the alternator is working ok, but the battery is not holding a full charge.
    The above indicates to me that a failed battery is causing systems to shut down and cause my central locking to stop working. Ergo, a new battery should fix the issue.
    However, the car is doing a couple of other weird things, which don't seem to me to line up with the idea that systems are shutting down. When you turn the ignition off and remove the key, the MMI stays on, the tail lights stay on (if auto-lights are on), the power windows continue to operate and the steering lock does not activate, almost as if the car has not recognised the removal of the key from the ignition. Over the last couple of days we have had to manually turn everything on/off to make sure the battery isn't further drained. I'm worried that the battery might be a symptom of some other fault, rather than the cause. Some sort of fault with the ignition switch causing systems to stay on, draining the battery etc.
    Any thoughts on whether I am wasting my money replacing the battery first? Do the symptoms described sound like issues related to a battery failing, or is the low battery voltage a symptom in and of itself? Any thoughts or insights would be greatly appreciated.
    Thanks.
    Saturday,20,April,2019,19:56:19:35988
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUZZZ4L78D018907   License Plate: HYQ360
    Mileage: 173950km-108087mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 1E 37 42 46 47 4F 52
              55 56 61 62 67 6C 6D 6F 72 76 77
    VIN: WAUZZZ4L78D018907   Mileage: 173950km-108087miles
       Part No SW: 4L0 910 401 R    HW: 4L0 907 401
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H04---    Serial number:
       Coding: 0011779
       Shop #: WSC 31414 790 00001
       VCID: 3169068CA8A5CEC262-8064
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No SW: 09D 927 750 FS    HW: 09D 927 750 FS
       Component: AL 750 6A           1000
       Revision: 00H64000    Serial number:
       Coding: 0000504
       VCID: 04079F5847978B6AF9-8050
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
       Component: ESP ALLRAD MK25E1   0010
       Revision: 00H30001
       Coding: 0099473
       VCID: 2959EEEC8075B602AA-807C
                        Reset counter: 204
                        Mileage: 173701 km
                        Date: 2019.04.14
                        Time: 09:55:57
                        Count: 64
                        Count: 8261
                        Count: 128
                        Count: 39680
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0230
       Revision: 09010701    Serial number: 10601500866926
       Coding: 0000147
       VCID: 63C5BCC4A2D92C52A0-8036
       Subsystem 1 - Part No: 4F0 910 131 A
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220
       Component: FBSAUDIC6 IDG   H01 0040
    00956 - Key 2
                        Fault Status: 00110010
                        Reset counter: 40
                        Mileage: 173011 km
                        Date: 2019.03.15
                        Time: 08:03:16
    01176 - Key
                        Fault Frequency: 8
                        Reset counter: 223
                        Mileage: 173943 km
                        Date: 2019.04.20
                        Time: 14:02:03
                        Reset counter: 200
                        Mileage: 173679 km
                        Date: 2019.04.13
                        Time: 08:14:56
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 731 L    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4220
       Revision: 00000000    Serial number: 387H2077556485
       Coding: 0002002
       Subsystem 1 - Part No: 4L0 910 609
       Component: E0380 BedienteilH01 0060
       Subsystem 2 - Serial number: 00000000838279
       Subsystem 3 - Serial number: 0116.08.070000000100010294˙
       Subsystem 4 - Serial number: 010294˙
       Part No SW: 4L0 910 043     HW: 4L0 820 043 E
       Component: KLIMABETAETIGUNGH05 0060
       Revision: 00---012    Serial number: 00000000127582
       Coding: 0001110
       VCID: 61C9B6CCB8C53E42B2-8034
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H18 0250
       Coding: 0003121
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H10 0100
       Coding: 00064792
       Shop #: WSC 31414
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00150059
       Shop #: WSC 31414
                        Fault Status: 01101011
                        Reset counter: 183
                        Mileage: 167276 km
                        Date: 2018.09.16
                        Time: 11:37:00
                        Reset counter: 183
                        Mileage: 167276 km
                        Date: 2018.09.16
                        Time: 11:37:00
    01494 - Bulb for Parking Lamps; Left (M1)
                        Reset counter: 183
                        Mileage: 173948 km
                        Date: 2019.04.20
                        Time: 18:47:00
    01498 - Bulb for Parking Lamps; Right (M3)
                        Reset counter: 183
                        Mileage: 173948 km
                        Date: 2019.04.20
                        Time: 19:06:00
                        Fault Status: 00100111
                        Fault Frequency: 39
                        Reset counter: 223
                        Mileage: 173588 km
                        Date: 2019.04.07
                        Time: 15:27:00
       Part No SW: 4L0 910 110 A    HW: 4L0 035 110
       Component: MP3-Changer     H45 0350
       Revision: 00045006    Serial number: AUZ5ZBG1226503
       VCID: 1D31CA3CC43D5AA2D6-8048
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 70 AIRBAG AUDI8RH42 0230
       Revision: 03H42000    Serial number: 00399D03DRUL
       Coding: 0014128
       VCID: 2E531DF0B99BD13A7F-807A
       Subsystem 1 - Serial number: 6332QSME360C400FF
       Subsystem 2 - Serial number: 6342QSME360D072DK
       Subsystem 3 - Serial number: 6352QSME3850294DL
       Subsystem 4 - Serial number: 6362QSME36070F1FP
       Subsystem 5 - Serial number: 63734SME386D7A3BJ
       Subsystem 6 - Serial number: 63834SME36521637Z
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0410
       Revision: 00H02000    Serial number: 90026072020007
       Coding: 0102142
       VCID: 275DE8D496618072BC-8072
       Component: E0221           H02 0030
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 930 T
       Component: KOMBIINSTR. M73 H21 0240
       Revision: 00700000    Serial number: 73Y52XV87
       Coding: 3649758
       Shop #: WSC 00070 067 57207
       VCID: 2345FCC4E2596C52E0-8076
       Part No SW: 4L0 910 105     HW: 4L0 815 071 D
       Component: Heizgeraet      H08 0080
       Revision: 0000000C    Serial number: 00000009014264
       Coding: 0000001
       VCID: 60CFB3C8B3CF374ABD-8034
    01412 - Glow-Plug with Flame Monitoring (Q8)
                008 - Implausible Signal
    02251 - Heater Unit Locked
                000 -  -
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B077268415
       Coding: F55BFE7770720200
       VCID: 2D511AFCB49DAA2246-8078
    Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
       Component: SG ext.Player H15 0700
       Revision: 00000000
       VCID: 275DE8D456618072BC-8072
       Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
       Component: MNS ECE         H50 1050
       Revision: 00000000    Serial number: 399H 077585023
       Shop #: WSC 00070 824 83289
       VCID: 306F0388A3AFC7CA6D-8064
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 C    HW: 4L0 959 793 C
       Component: TSG FA          H21 0150
       Coding: 0000539
       Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
       Component: Komfortgeraet   H07 0040
       Revision: 0040 ---    Serial number: 01060471200000
       Coding: 7602317
       Shop #: WSC 06111 109 68793
       VCID: 33650C8452B9FCD210-8066
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4L0 910 223 H    HW: 4L0 035 223 C
       Component: DSP-AU716-RD  H07 0250
       Revision: S0600000
       Coding: 030100
       VCID: 2959EEEC4075B602AA-807C
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                        Fault Status: 00101011
                        Fault Frequency: 12
                        Reset counter: 223
                        Mileage: 168317 km
                        Date: 2018.11.05
                        Time: 09:18:55
                        Voltage: 11.70 V
                        Temperature: 18.0°C
                        Bin. Bits: 00000011
                        Reset counter: 223
                        Mileage: 172095 km
                        Date: 2019.02.10
                        Time: 10:03:02
                        Voltage: 11.90 V
                        Temperature: 32.0°C
                        Bin. Bits: 00000011
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000243224
       Coding: 0011001
       VCID: 5EB38D3089BB01BA8F-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 792 C    HW: 4L0 959 792 C
       Component: TSG BF          H21 0150
       Coding: 0000539
       VCID: 2F6D00F4BE91D83274-807A
       Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
       Coding: 0000021
       Subsystem 1 - Part No: NOSUBSYSTEM
       Component: AFS-Modul links
       Subsystem 2 - Part No: NOSUBSYSTEM
       Component: AFS-Modul rechts
    02071 - Local Databus
                        Fault Status: 11100100
                        Reset counter: 183
                        Mileage: 167272 km
                        Date: 2018.09.16
                        Time: 11:37:02
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 388H$077640682
       Coding: 0000001
    00532 - Supply Voltage B+
                        Reset counter: 223
                        Mileage: 165837 km
                        Date: 2018.08.21
                        Time: 17:52:37
                        Fault Frequency: 229
                        Reset counter: 223
                        Mileage: 165837 km
                        Date: 2018.08.21
                        Time: 17:20:29
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4L0 910 181 A    HW: 4L0 915 181
       Component: J0644 BEM       H12 0690
       Revision: --------    Serial number: 00000000019134
       VCID: 2541E2DCEC6D92628E-8070
       Component: von VA0  0708091116
       Coding: 344630393135313035442056413030373038303931313136
                000 -  -  - Intermittent
                        Mileage: 167353 km
                        Date: 2018.09.20
                        Time: 17:23:36
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 C    HW: 4L0 959 795 C
       Component: TSG HL          H21 0150
       VCID: 326B0980ADA3F5DA1B-8066
    02111 - Motor for Window Regulator
                        Fault Status: 01100101
                        Reset counter: 123
                        Mileage: 173369 km
                        Date: 2019.03.30
                        Time: 15:17:47
    Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H46 0630
       Revision: 00000000    Serial number: 00000707130329
       Shop #: WSC 12336 024 394758
       VCID: 3663359041CBE9FA37-8062
       Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J7740ZN
       Coding: 1021101
       VCID: 2447FFD8E7576B6A99-8070
       Part No SW: 4L0 910 945     HW: 4L0 827 851 C
       Component: ValeoHeckdeckel H24 0290
       Revision: --H24001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6CD7D7F84F07632A11-8038
       Subsystem 3 - Serial number: RD18.08.07--H24001001B0135˙
       Subsystem 4 - Serial number: 1B0135˙
       Component: ILM HINTEN 2    H05 0060
       Revision: AAH05061    Serial number: 003019119-----
       Coding: 0003591
       VCID: 2643E5D0916B997A87-8072
       Subsystem 1 - Part No: 4L0 910 591
       Component: J_245_EE16_SKB09H10 0200
       Subsystem 2 - Part No: 4L0 910 591
       Component: J_394_EE16_SKB09H10 0200
       Subsystem 3 - Part No: 4L0 910 591
       Component: J_392_EE16_SKB09H10 0200
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 C    HW: 4L0 959 794 C
       Component: TSG HR          H21 0150
                        Fault Status: 01101000
                        Fault Frequency: 99
                        Reset counter: 183
                        Mileage: 171223 km
                        Date: 2019.01.23
                        Time: 06:18:38
       Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
       Component: Parkhilfe 8-Kan H12 0080
       Revision: 00H12000    Serial number: 06320721501491
       Coding: 0221046
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 K    HW: 4E0 862 335
       Component: Handyvorb2      H18 0950
       Revision: 00000000    Serial number: 00000005006264
       Coding: 0010900
       VCID: 2A5B11E08573BD1AA3-807E
    End-------------------------(Elapsed Time: 03:07)--------------------------
    16.4905° S, 151.7375° W
    - You may not be wasting your money (or time), especially if the battery was already replaced once before and they did NOT adapt the replacement battery to the vehicle, now the system thinks there is a 12 year old battery in there. And if the battery is about 12 years old and is an AGM, it maybe time for a new one.
    It is not necessary to use a Audi Battery, you can use an exact replacement size/ratings battery and when you adapt the new battery, just keep the values the same except change the battery serial number by a digit, that way the battery management system know there is a new battery which is of the same ratings.
    Battery Replacement
    Hope this helps,
    drpeter
  3. Likes Uwe, PetrolDave, Jack@European_Parts liked this post
    How quickly does the battery voltage drop after you shut down the ignition?
    If you've driven the car for a while, meaning the battery is presumably well-charged, and it drops below 12.0V quickly, either the battery is shot, or there's excessive resistance in the leads to it.
    Have you checked the condition of the battery terminals? Have you tried charging the battery using a separate charger and then monitoring its voltage afterward without applying any load to it?
  5. Likes DrPeter, Jack@European_Parts liked this post
    Sep 2018
    New Zealand
    Quote Originally Posted by DrPeter View Post
    Battery Replacement
    Hope this helps,
    drpeter
    Thanks for the quick response guys. Out of interest, how can you see the battery is 12 years old? That doesn't surprise me as it has a genuine battery in it and there is no way the guy I bought it off would have installed a genuine battery. When I l saw the battery was genuine it made me think it must be pretty old.
    Yes, have checked the terminals etc. and everything looks tight and clean. It basically drops below 12v straight away, although we don't really drive it that far. I will go for a drive now for a good half hour and check the voltage then. Your suggestion to charge the battery externally was on my list, but I don't own a battery charger, so was tossing up about buying a charger versus just going straight to the new battery.
    I'll check the voltage after a drive this morning and if it quickly drops below 12v I'll replace the battery. I'll post back with what I find.
    Cheers,
    Quote Originally Posted by TreeCrusher View Post
    We cannot. But based on what you posted there, it looks like the car thinks it's the original one.
    You could go to [Applications] -> [History Data], select module 61, and click [Start]. When VCDS finishes (not long), click [Save] and post the data here.
    Given how hard modern cars are on a battery, and how important the battery is, you should. Everyone should.
    Sep 2018
    New Zealand
    I went for a longer drive this morning and the voltage dropped pretty quickly after turning the car off so I replaced the battery. The new battery is definitely stronger, with the voltage holding above 12v for longer after shut down, but unfortunately the battery was not to source of the issues.
    Below lists some of the symptoms/observations:
    -When I insert/remove the key from the ignition there is no change in state of the vehicle. The steering lock doesn't engage/disengage the MMI stays on, lights stay on etc.
    -Central locking does not work from the remote
    -If you wait for the cabin light to turn off, pushing the unlock button on one of the keys causes the cabin light to turn back on (indicating the keys are actually communicating with the car)
    -If I undertake the tests in module 05, I can get the key ignition lock to click on and off, but I cannot get the steering lock to actuate.
    -With the new battery the battery voltage is 12.05v in module 061 (after working on it for a while with the engine off), but the supply voltage to the ignition in module 05 is only 11.6v. Could this be an issue with the ignition, or perhaps an earthing issue, or is this normal?
    -in the advanced block measuring in module 05 it states the locking voltage to the steering lock as being 0.28v, but then states the minimum locking voltage as being 7.2v.
    It seems to me that the car is not sensing the keys being inserted/removed, although I am lost as to the reason for this. Also, the fact I cannot get the steering lock to activate using the output test in module 05, seems to indicate some potential issue there.
    Below is a couple of screen shots, an updated log after the battery replacement and the history data log. Again, I appreciate any thoughts or hints on what could be going on.
    Cheers.
    Tuesday,23,April,2019,21:06:25:35988
    Mileage: 174130km-108199mi   Repair Order:
    VIN: WAUZZZ4L78D018907   Mileage: 174130km-108199miles
       Coding: 0011779
       Coding: 0000504
       Revision: 00H30001
       Coding: 0099473
       Coding: 0000147
    01176 - Key
                        Fault Frequency: 6
                        Reset counter: 231
                        Mileage: 174058 km
                        Date: 2019.04.23
                        Time: 16:01:42
       Coding: 0002002
       Coding: 0001110
       Coding: 0003121
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                        Reset counter: 191
                        Mileage: 174056 km
                        Date: 2019.04.23
                        Time: 15:54:00
                        Reset counter: 191
                        Mileage: 174056 km
                        Date: 2019.04.23
                        Time: 15:54:00
                        Fault Frequency: 6
                        Reset counter: 191
                        Mileage: 174056 km
                        Date: 2019.04.23
                        Time: 15:56:00
                        Reset counter: 231
                        Mileage: 174060 km
                        Date: 2019.04.23
                        Time: 17:24:00
                        Reset counter: 191
                        Mileage: 174132 km
                        Date: 2019.04.23
                        Time: 20:50:00
       Coding: 0014128
       Coding: 0102142
       Coding: 3649758
       Coding: 0000001
                000 -  -
       Revision: 00000000
       Coding: 0000539
       Coding: 7602317
       Revision: S0600000
       Coding: 030100
       Coding: 0011001
       Coding: 0000539
       Coding: 0000021
                        Reset counter: 191
                        Mileage: 174056 km
                        Date: 2019.04.23
                        Time: 15:54:57
       Coding: 0000001
       Component: von VA0  0708091120
       Coding: 344630393135313035442056413030373038303931313230
       Coding: 1021101
       Coding: 0003591
                        Reset counter: 190
                        Mileage: 174060 km
                        Date: 2019.04.23
                        Time: 16:16:28
       Coding: 0221046
       Coding: 0010900
    End-------------------------(Elapsed Time: 03:04)--------------------------
    Control Module Part Number: 4L0 910 181 A
      Component and/or Version: J0644 BEM       H12 0690
               Software Coding:
                Work Shop Code: WSC 06111
                          VCID: 2541E2DCEC6D92628E-FFFE
               Additional Info: 4F0915105D  von VA0  0708091120
               Additional Info: Geraet 68793
    History Data
    Record 1/18: No-load voltage underranging
    2000-01-01,00:00:00*0000*000**
    2000-01-01,00:00:00*0000*000*00000***
    Record 2/18: No-load current overranging
    2000-01-01,00:00:00*0000*00.00*000**
    2000-01-01,00:00:00*0000*00.00*000*00000***
    Record 3/18: Energy-critical vehicle states
    00.00*00.00*+00.00*00*00*+0000*+00000*000000*2000-01-01,00:00:00*0-0-0-0-0-0*00.0*00.0*000.0*00*00*00*000**
    Record 4/18: Shut-off stage history
    1*2*-14.61*33*2019-04-21,09:54:54*0-0-0-0-0-0*00.0**
    2*0*-05.65*36*2018-09-20,17:30:03*0-0-0-0-0-0*00.0**
    1*0*-05.43*36*2018-09-20,17:23:36*0-0-0-0-0-0*00.0**
    2*5*-00.03*09*2018-09-08,10:28:39*0-0-0-0-0-0*00.0**
    1*5*-05.09*09*2018-09-08,09:26:50*0-0-0-0-0-0*00.0**
    6*7*+04.42*00*2018-09-08,08:35:38*0-0-0-0-0-0*01.1**
    3*7*-07.19*00*2018-09-08,08:36:07*0-0-0-0-0-0*01.1**
    5*7*-10.96*00*2018-09-08,08:36:06*0-0-0-0-0-0*01.1**
    1*2*-06.91*34*2018-09-08,08:32:44*0-0-0-0-0-0*01.1**
    1*2*-06.97*37*2018-09-08,08:29:13*0-0-0-0-0-0*01.0**
    1*2*-08.48*37*2018-09-08,08:27:11*0-0-0-0-0-0*01.0**
    1*2*-73.57*39*2018-09-08,08:24:01*0-0-0-0-0-0*01.0**
    2*2*-04.95*40*2018-09-08,08:21:18*0-0-0-0-0-0*01.0**
    1*2*-08.79*40*2018-09-08,08:19:38*0-0-0-0-0-0*01.0**
    Record 5/18: Battery change history
    001*0708091116*2019-04-23,00:00:00*+00006*-9999**
    000*0708091116*2000-01-01,00:00:00*+00000*+0000**
    000*----------*2000-01-01,00:00:00*+00000*+0000**
    Record 6/18: Energy balances (last 5 trips)
    +000.3*000.0**
    +000.3*000.0**
    +000.3*000.0**
    +002.7*000.7**
    +004.0*000.9**
    Record 7/18: Energy balances (last 5 standing times)
    -002.4*001.4**
    -000.3*000.0**
    -000.2*000.0**
    -000.2*000.0**
    -000.3*000.0**
    Record 8/18: Battery manipulation (e.g. charging)
    +008.1*002**
    Record 9/18: Battery aging
    0000.0*0000.0
    Record 10/18: Dynamic energy management
    00.0*00.0
    Record 11/18: Recuperation
    0000.00*0000.00*0000.00*0000.00
    Record 12/18: Start-Stop
    00.00*00.00*00.00*00.00
    Record 13/18: Sporadic alternator faults
    0000.0*0000.0
    Record 14/18: Small battery for hybrid vehicle
    00.0*00.0
    Record 15/18: Local activ.
    00*99*03*00*00
    Record 16/18: Vehicle energy balance
    00*00*01*00*00
    Record 18/18: Date reprogramming in instrument cluster
    15**
    2011-12-14,09:00:00*2000-01-01,12:00:00**
    2008-12-17,17:00:00*2008-12-17,20:00:00**
    2007-11-05,14:00:00*2007-12-06,14:00:00**
    2007-07-21,05:00:00*2007-10-08,12:00:00**
    2000-01-01,12:00:00*2007-05-16,12:00:00**
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #7
    Sep 2015
    I had these exact symptoms in my A3 8V. Reason was, ignition lock was somehow physically stuck in such a way that it did not register key being taken out. Car thinks the key is still inserted and leaves MMI on and won't let you lock the doors with remote.
    I had the entire ignition lock replaced (under warranty, luckily) and no problems after that. Maybe you are experiencing the same issue? Try to wiggle the key while pulling it out to see if that helps? In my case, it did. Also, when I took out the key and MMI stayed on, I could often turn it off by hitting ignition lock firmly with my fist.
    EDIT: If there is a measuring value for this key in/out detection, maybe that would tell something. But I do not know if such thing exists in your car or not.
  11. #8
    Wouldn't hurt to install a solar charger to maintain the thing when it sits either.
    Change the battery anyway.........
  12. #9
    Sep 2018
    New Zealand
    Quote Originally Posted by Mika_M View Post
    Mike, you nailed it, thank you. If I get really aggressive with the key I can make it sense the key removal and then all works normally. There is obviously something mechanical in the ignition switch that is faulty. I’ll replace and report back.
  13. #10
    Sep 2018
    New Zealand
    Hi again everyone,
    I purchased a replacement ignition and installed it and it problems are fixed.
    A few points for anyone undertaking this repair:
    -The ignition is a simple plug and play replacement
    -No coding required
    -The ignition is not specific to the key, so can just replace and not worry about keys etc.
    -An ignition from a C6 A6 also works (That's where I got my replacement from)
    Below is a picture of my ignition module with the part number shown.
    Thanks to everyone for their time and help.
