the car stall sometimes and loss the power any sugestions thanks ...
Sunday,21,April,2019,11:42:32:20576
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4437.4
VIN: WAUDH74F07N085319 License Plate:
Mileage: 316610km-196732mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDH74F07N085319 Mileage: 316610km-196732miles
65-Tire Pressure -- Status: Not registered 0001
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 C HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0070
Revision: --H19--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 03055 444 100692
VCID: 2C14C3148F5B572A51-8078
000545 - Angle Sensor 2 for Throttle (G188)
P0221 - 008 - Implausible Signal - MIL ON
Fault Status: 10101000
Reset counter: 40
Mileage: 316611 km
Date: 2019.04.21
Time: 11:31:56
RPM: 1632 /min
Mass Air / Rev.: 136.3 mg/str
Temperature: 90.0°C
Part Throttle
Load: 20.8 %
Bin. Bits: 00000001
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Reset counter: 40
Mileage: 316611 km
Date: 2019.04.21
Time: 11:31:57
RPM: 2816 /min
Mass Air / Rev.: 60.0 mg/str
Temperature: 90.0°C
Overrun
Load: 11.4 %
005445 - Throttle Valve Controller
P1545 - 008 - Malfunction - Intermittent
Fault Status: 00001000
Reset counter: 40
Mileage: 316611 km
Date: 2019.04.21
Time: 11:31:58
Mass Air / Rev.: 0.0 mg/str
Temperature: 90.0°C
Engine Off
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 G HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H01--- Serial number: 4256232
Shop #: WSC 02325 785 00200
VCID: 291A3A0080A94202AA-807C
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Coding: 0020895
VCID: 6680713C5137AD7A47-8032
Fault Status: 00101101
Fault Frequency: 56
Reset counter: 59
Mileage: 316038 km
Date: 2019.04.06
Time: 17:12:06
Hex Value: 0x00C0
Hex Value: 0x6282
Hex Value: 0x0025
Hex Value: 0x0199
Hex Value: 0x00FF
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200590705
Coding: 0000007
Shop #: WSC 02116 444 53299
VCID: 24042B34E78B9F6A99-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
00955 - Key 1
Fault Status: 00110010
Fault Frequency: 21
Reset counter: 57
Mileage: 315956 km
Date: 2019.04.05
Time: 17:47:45
00190 - Driver's Door Handle Touch Sensor (G415)
Fault Status: 00110111
Reset counter: 248
Mileage: 315840 km
Date: 2019.04.01
Time: 08:09:04
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361KK067510314
Coding: 0000003
VCID: 3228DD6CAD7F01DA1B-8066
Subsystem 2 - Serial number: 00000000585166
Subsystem 3 - Serial number: 0116.11.060000000100010729ÿ
Subsystem 4 - Serial number: 010729ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030181369
Coding: 0524326
VCID: 1C7413D4DFFBA7AA21-8048
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H15 0240
Coding: 0113123
Shop #: WSC 02335 785 00200
VCID: 302CD764A37333CA6D-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBF3105514
VCID: 1A7815CCD5CFD99A33-804E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0015677
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0BEC4S
Coding: 0013878
VCID: 2A18C50C85AF491AA3-807E
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME143E12770
Subsystem 3 - Serial number: 6342CSME143E5A2CD
Subsystem 4 - Serial number: 6352QSME19311B339
Subsystem 5 - Serial number: 6362QSME18213D53E
Subsystem 6 - Serial number: 63734SME18762F79D
Subsystem 7 - Serial number: 63834SME19292C0B5
00591 - Seat Belt Switch; Driver (E24)
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Revision: 00H08000 Serial number: 90026063140254
Coding: 0012041
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 G
Component: KOMBIINSTR. M73 H18 0120
Revision: 00700000 Serial number: 5FG38W8C6
Coding: 2129252
Shop #: WSC 59023 001 104857
VCID: 23062828E2859852E0-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06B0780DD
Coding: F5D1DE77307A06
Shop #: WSC 02334 785 00200
VCID: 6C9403144FDB972A11-8038
Reset counter: 178
Mileage: 311900 km
Date: 2018.12.27
Time: 08:13:07
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 618A6220B819CA42B2-8034
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381K1067509958
VCID: 383CEF444B03EB8A25-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0051947
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01025070040000
Coding: 4618269
VCID: 2E10C91CB947253A7F-807A
02743 - Bulb for Brake/Turn Signal Light; Right
Fault Status: 00101001
Fault Frequency: 21
Reset counter: 48
Mileage: 314979 km
Date: 2019.03.14
Time: 07:22:03
02742 - Bulb for Brake/Turn Signal Light; Left
Reset counter: 31
Mileage: 316176 km
Date: 2019.04.12
Time: 08:05:31
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000003725
Coding: 0000026
Shop #: WSC 02324 785 00200
VCID: 25023630ECB166628E-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000057043
Coding: 0002014
VCID: 5EF059DC8967F5BA8F-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
VCID: 200C2724F393834AFD-8074
Fault Status: 01101101
Reset counter: 19
Mileage: 312920 km
Date: 2019.01.17
Time: 17:17:35
Voltage: 12.73 V
Count: 220
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Revision: 00000000 Serial number: 394KW067706034
VCID: 312AD260A8793AC262-8064
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000146175
Shop #: WSC 03317 444 84819
Component: von VA0 2611061915
Coding: 344630393135313035442056413032363131303631393135
Shop #: WSC 00000 512 00290
02272 - Quiescent Current Stage 1
Mileage: 312869 km
Date: 2019.01.15
Time: 12:01:28
Mileage: 312869 km
Date: 2019.01.15
Time: 12:04:54
02276 - Quiescent Current Stage 5
Mileage: 312869 km
Date: 2019.01.15
Time: 12:05:04
02274 - Quiescent Current Stage 3
Mileage: 312869 km
Date: 2019.01.15
Time: 12:05:14
Mileage: 312869 km
Date: 2019.01.15
Time: 12:05:24
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700035924
Coding: 0062221
VCID: 22082D2CFD9F915AEB-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000610230179
Shop #: WSC 12336 024 394758
VCID: 3424DB74576B0FEA09-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6920KP
Coding: 1000304
VCID: 5DF25ED08461EEA296-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Revision: 00H09000 Serial number: 06220631905765
Coding: 0021206
VCID: 271E3C3896BD7472BC-8072
Reset counter: 23
Mileage: 315866 km
Date: 2019.04.02
Time: 11:46:15
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005074018
Coding: 0010900
Shop #: WSC 02116 444 54056
VCID: 281C3F049BA37B0AB5-807C
End----------(Elapsed Time: 02:00, VBatt start/end: 12.1V/12.0V)-----------
