Results 1 to 5 of 5
Thread: Touareg electric tail gate issues
    New User
    Apr 2019
    Romania
    Hell, im getting a problem with my vw touareg, the new electric tail gate installed with all retrofit cables not working full process, the rear door lock not opening and getting the answer from remote, inside switc or rear swich. My issue is that in adress 46 i do not have the bit 07 in byte 01 and in byte 12 the bit 0, when i purchase all retrofit kit, kufatec assure me my comfort module is supporting this update 4H0 907 064 AM and send me this part of codind in adress 46.
    The all sistem was revise 3 times and all components are working. The 2 lock is verified.
    Thank you
    New User
    Apr 2019
    Romania
    The car is from 2011 with vin number wvgzzz7pzbd014160.
    We'll need to see a full VCDS Auto-Scan to be able to advise on coding as it may be module hardware and software version related.
    If you don't have VCDS there may be someone local to you who can scan your car for you?
  4. Likes Uwe liked this post
    Since the OP doesn't seem to have any questions regarding a VCDS purchase, I'm moving this from Pre-Sales Support to the New User section.
    New User
    Apr 2019
    Romania
    Thank you, i will make a full scan today ..
