Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Steering Adaptation ?
    Sep 2016
    Quote Originally Posted by Robski View Post
    post a picture of it .............
    https://i.imgur.com/IGkkLuc.jpg
  2. #12
    Jul 2014
    Yorkshire
    Quote Originally Posted by chillout1983 View Post
    I'll let them off, they have adjusted the rear according to that report. The front is set on the outer limit & rear spot on (total toe) according to my info per PR code on the report, 0deg10' +/- 10' front & back.
    Hard to read the individual settings per side when zooming on picture.
    Did they use a steering wheel level & lock the steering wheel in the straight ahead position, if so I see no reason for it to pull apart from Uwe's suggestion ?
  3. #13
    Sep 2016
    I never witnessed them doing the alignment although it did not pull before the alignment, I will swap wheel tomorrow
  4. #14
    Sep 2016
    Would a simple battery disconnect allow the steering wheel warning to occur and rectify the steering wheel off center issue once driven ?
  5. Likes Uwe liked this post
  6. #15
    Can't hurt much to try.
  7. #16
    Sep 2016
    Tried but still the same however I watched a video on YouTube on the fact the steering angle sensor should be reset following Alignment.
    Well impressed with Hex Net it's rapid at scanning
