Audi tt 8n Stops cheating
cleo
Norway
C?ID=330917
hey i got some trouble with my audi tt 8n
At first it would not start when it got hot after short stops
got up g28 sensor, bought new to replace it tomorrow. Then it began to cheat after 60 miles of driving and died when I switched, so after 30 minutes it stopped. When the car is about half an hour I get started. Then I got several error codes. But wondering if it can be just g28 that is wrong or if there is anything more?
Saturday,13,April,2019,19:05:48:36574
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
Mileage: 246190km-152975mi   Repair Order:
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
   Mileage: 246190km-152975miles
Address 01: Engine        Labels: 06A-906-032-AJQ.clb
   Part No: 8N0 906 018 AB
   Component: 1.8L R4/5VT         0002
   Coding: 05500
   Shop #: WSC 00082
   VCID: 71BF281208B1F76F613-5160
16706 - Engine Speed Sensor (G28)
            P0322 - 35-10 - No Signal - Intermittent
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
   Part No: 8N0 907 379 D
   Component: ESP     20    CAN  V006
   Coding: 23049
   Shop #: WSC 06435
   VCID: 3D27C4220469430FB5B-4B00
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043
   Component: TT-KLIMAVOLLAUTOMAT D02
   Coding: 00040
   Shop #: WSC 06435
   VCID: 678B464A367539DF3F7-2580
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Address 15: Airbags        Labels: 8N8-909-601.lbl
   Part No: 8N8 909 601
   Component: Airbag Front+Seite 1008
   Coding: 10102
   Shop #: WSC 01236
   VCID: 77AB160A66D5A95FAF7-513C
Address 17: Instruments        Labels: 8Nx-919-xxx-17.lbl
   Part No: 8N1 919 860 C
   Component: KOMBI+WEGFAHRS. M73 D30
   Coding: 00144
   Shop #: WSC 00530
   VCID: 3B23CA3A1A7D4D3F8BF-4B00
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:AUZ5Z0F2106041
   Ident.-Nr. Wegfahrs.:AUZ5Z0F2106041
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N8 962 267
   Component: Zentralverrieg.     D04
   Coding: 04672
   Shop #: WSC 01236
   VCID: 7EA5032E49EF9817EC1-4EEA
01559 - Drivers Door
            58-10 - Can't Lock - Intermittent
            60-10 - Won't Safe - Intermittent
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D003
   Coding: 00009
   Shop #: WSC 06435
   VCID: 65974C42CC792BCF0DB-5160
End----------(Elapsed Time: 02:50, VBatt start/end: 12.5V/12.5V)-----------
Saturday,20,April,2019,22:39:47:36574
VIN:    License Plate: BP84092
Control Module Part Number: 8N0 906 018 AB
  Component and/or Version: 1.8L R4/5VT         0002
           Software Coding: 05500
            Work Shop Code: WSC 00082
            P0322 - 35-00 - No Signal
16717 - Knock Sensor 2 (G66)
            P0333 - 35-10 - Signal too High - Intermittent
16712 - Knock Sensor 1 (G61)
            P0328 - 35-10 - Signal too High - Intermittent
Check wiring diagrams to see of G28, G61, and G66 have anything in common.
Improper G28 or installed incorrect, overfilled oil or contaminated oil, Bad harness, shield or bad ecu.
Check that consumers not running hot with no DTC due to possible FOD!
Please clear codes and immediately repost a fresh auto-scan.
JPPSG
cleo
Norway
C?ID=330917
So there may also be errors in the ecu that do this?
goes g66 and g28 together So that is, if the g28 sensor is defective then can I get error code on the G66 simultaneously?
Unlikely. What I am suggesting is that you look for a common cause other than the sensors themselves; something like a common ground point, a common voltage supply, or anything of that nature.
cleo
Norway
C?ID=330917
Now I deleted all the errors.
and drove a little round then stopped it right when I got home, and now is just the g28 coming up?
Then I'll try and measure the voltages on the cables tomorrow.
cleo
Norway
C?ID=330917
Then I turned on the car a little today. Replaced this g28 sensor, erased error codes tested the car starts and goes well now without stopping. Must do clean wires now so what a lot of shit ravaged them. It just went up a bit to speed but calmed down a lot after driving the car. So then it may be the Earth again?
So there may be cable breakage on the cable?
Do not get multiple error codes on the car for now.
cleo
Norway
C?ID=330917
JPPSG
What causes oil to contaminate you? Should oil change soon on the car, it may not be good anymore?
Here's the new autoscan
Sunday,21,April,2019,15:55:40:36574
Mileage: 246930km-153435mi   Repair Order:
   Mileage: 246930km-153435miles
   Coding: 05500
   Shop #: WSC 00082
   Coding: 23049
   Shop #: WSC 06435
   Coding: 00040
   Shop #: WSC 06435
   VCID: 678B464A367539DF3F7-2586
            29-10 - Short to Ground - Intermittent
01273 - Fresh Air Blower (V2)
            17-10 - Control Difference - Intermittent
   Coding: 10102
   Shop #: WSC 01236
   Coding: 00144
   Shop #: WSC 00530
   Coding: 04672
   Shop #: WSC 01236
   Coding: 00009
   Shop #: WSC 06435
End----------(Elapsed Time: 02:49, VBatt start/end: 12.3V/12.5V)-----------
