Results 1 to 8 of 8
Thread: Audi tt 8n Stops cheating
    Apr 2018
    Norway
    hey i got some trouble with my audi tt 8n
    At first it would not start when it got hot after short stops
    got up g28 sensor, bought new to replace it tomorrow. Then it began to cheat after 60 miles of driving and died when I switched, so after 30 minutes it stopped. When the car is about half an hour I get started. Then I got several error codes. But wondering if it can be just g28 that is wrong or if there is anything more?
    Saturday,13,April,2019,19:05:48:36574
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    Mileage: 246190km-152975mi   Repair Order:
    Chassis Type: 8N - Audi TT (1999 > 2007)
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
       Mileage: 246190km-152975miles
    Address 01: Engine        Labels: 06A-906-032-AJQ.clb
       Part No: 8N0 906 018 AB
       Component: 1.8L R4/5VT         0002
       Coding: 05500
       Shop #: WSC 00082
       VCID: 71BF281208B1F76F613-5160
    16706 - Engine Speed Sensor (G28)
                P0322 - 35-10 - No Signal - Intermittent
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 D
       Component: ESP     20    CAN  V006
       Coding: 23049
       Shop #: WSC 06435
       VCID: 3D27C4220469430FB5B-4B00
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043
       Component: TT-KLIMAVOLLAUTOMAT D02
       Coding: 00040
       Shop #: WSC 06435
       VCID: 678B464A367539DF3F7-2580
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 1008
       Coding: 10102
       Shop #: WSC 01236
       VCID: 77AB160A66D5A95FAF7-513C
    Address 17: Instruments        Labels: 8Nx-919-xxx-17.lbl
       Part No: 8N1 919 860 C
       Component: KOMBI+WEGFAHRS. M73 D30
       Coding: 00144
       Shop #: WSC 00530
       VCID: 3B23CA3A1A7D4D3F8BF-4B00
       Subsystem 1 - Part No: Ident
       Component: Nr. Wegfahrs.:AUZ5Z0F2106041
       Ident.-Nr. Wegfahrs.:AUZ5Z0F2106041
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N8 962 267
       Component: Zentralverrieg.     D04
       Coding: 04672
       Shop #: WSC 01236
       VCID: 7EA5032E49EF9817EC1-4EEA
    01559 - Drivers Door
                58-10 - Can't Lock - Intermittent
                60-10 - Won't Safe - Intermittent
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D003
       Coding: 00009
       Shop #: WSC 06435
       VCID: 65974C42CC792BCF0DB-5160
    End----------(Elapsed Time: 02:50, VBatt start/end: 12.5V/12.5V)-----------
    Saturday,20,April,2019,22:39:47:36574
    VIN:    License Plate: BP84092
    Control Module Part Number: 8N0 906 018 AB
      Component and/or Version: 1.8L R4/5VT         0002
               Software Coding: 05500
                Work Shop Code: WSC 00082
                P0322 - 35-00 - No Signal
    16717 - Knock Sensor 2 (G66)
                P0333 - 35-10 - Signal too High - Intermittent
    16712 - Knock Sensor 1 (G61)
                P0328 - 35-10 - Signal too High - Intermittent
    Check wiring diagrams to see of G28, G61, and G66 have anything in common.
    Improper G28 or installed incorrect, overfilled oil or contaminated oil, Bad harness, shield or bad ecu.
    Check that consumers not running hot with no DTC due to possible FOD!
    Please clear codes and immediately repost a fresh auto-scan.
    JPPSG
    Apr 2018
    Norway
    So there may also be errors in the ecu that do this?
    goes g66 and g28 together So that is, if the g28 sensor is defective then can I get error code on the G66 simultaneously?
    Quote Originally Posted by cleo View Post
    Unlikely. What I am suggesting is that you look for a common cause other than the sensors themselves; something like a common ground point, a common voltage supply, or anything of that nature.
  6. Likes Fredrick Awuor liked this post
    Apr 2018
    Norway
    Now I deleted all the errors.
    and drove a little round then stopped it right when I got home, and now is just the g28 coming up?
    Then I'll try and measure the voltages on the cables tomorrow.
    Apr 2018
    Norway
    Then I turned on the car a little today. Replaced this g28 sensor, erased error codes tested the car starts and goes well now without stopping. Must do clean wires now so what a lot of shit ravaged them. It just went up a bit to speed but calmed down a lot after driving the car. So then it may be the Earth again?
    So there may be cable breakage on the cable?
    Do not get multiple error codes on the car for now.
  9. #8
    Apr 2018
    Norway
    JPPSG
    What causes oil to contaminate you? Should oil change soon on the car, it may not be good anymore?
    Here's the new autoscan
    Sunday,21,April,2019,15:55:40:36574
    Mileage: 246930km-153435mi   Repair Order:
       Mileage: 246930km-153435miles
       Coding: 05500
       Shop #: WSC 00082
       Coding: 23049
       Shop #: WSC 06435
       Coding: 00040
       Shop #: WSC 06435
       VCID: 678B464A367539DF3F7-2586
                29-10 - Short to Ground - Intermittent
    01273 - Fresh Air Blower (V2)
                17-10 - Control Difference - Intermittent
       Coding: 10102
       Shop #: WSC 01236
       Coding: 00144
       Shop #: WSC 00530
       Coding: 04672
       Shop #: WSC 01236
       Coding: 00009
       Shop #: WSC 06435
    End----------(Elapsed Time: 02:49, VBatt start/end: 12.3V/12.5V)-----------
