Results 1 to 6 of 6
Thread: 2011 Seat Ibiza ST, Can't change ABS code
    Verified VCDS User Dannozz's Avatar
    Apr 2017
    Hi guys,
    I just retrofitted rear brake disks on my 1.2TDI Ibiza and I wanted to change the ABS coding(Bosch ESP 8.2I). But I am keeping Error code 22. Can someone point me out what I am doing wrong here?
    Old with rear drum config: 110224DB817500B3882C24E681D200521700
    New with rear disk config: 110228DB817500B3882C24E681D200521700
    Saturday,20,April,2019,19:32:12:30519
    VCDS Version: 18.9.1.0 (x64)
    VIN: VSSZZZ6JZBR181741   License Plate: XX-XXX-X
    Mileage: 155820km-96822mi   Repair Order:
    Chassis Type: 6J-SE25 (6R0)
    Scan: 01 03 08 09 10 15 17 19 25 44 4B 56 61
    VIN: VSSZZZ6JZBR181741   Mileage: 155820km-96822miles
    4B-Multifunc. Module -- Status: Malfunction 0010
    Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 AA    HW: 03P 906 021 BC
       Component: R3 1.2l TDI   H06 9978
       Revision: 12005001    Serial number:
       Coding: 00114036032401080000
       Shop #: WSC 48890 002 104857
       ASAM Dataset: EV_ECM12TDI03103P906021AA 001018
       ROD: EV_ECM12TDI03103P906021AA.rod
       VCID: 67D755529E1AE3727C-8032
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
       Revision: --------
       Coding: 110224DB817500B3882C24E681D200521700
       Shop #: WSC 00046 123 12345
       VCID: 071775D2B25A03729C-8052
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6J0 820 043 C    HW: 6J0 820 043 C
       Component: Climatronic   H07 0606
       Revision: S0000000
       VCID: 244D025E27ACC86A99-8070
                        Fault Status: 00101101
                        Reset counter: 246
                        Mileage: 155742 km
                        Date: 2019.04.20
                        Time: 09:33:56
       Part No SW: 6R0 937 088 F    HW: 6R0 937 088
       Component: BCM PQ25 Re4  H46 0351
       Revision: BU046001    Serial number: 0379 109110736
       Coding: 3B980FF8C9A10F00013007F07E8B9EC9DF8063F97E8C6809300000000000
       Shop #: WSC 12302 002 104857
       VCID: 4183ABCAD8FEFD4292-8014
       Component: RLS 030511 05  54  0403
       Coding: 07242D
       Subsystem 2 - Part No SW: 6R0 959 801 N    HW: 6R0 959 801 N  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  003 3110
       Coding: 420000
       Subsystem 3 - Part No SW: 6R0 959 802 Q    HW: 6R0 959 802 Q  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  003 3110
       Coding: 420000
       Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3121
       Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3121
                        Fault Status: 00101010
                        Reset counter: 239
                        Mileage: 155624 km
                        Date: 2019.04.16
                        Time: 20:31:29
    Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
       Part No SW: 6J0 919 475 B    HW: 6J0 919 475 B
       Component: PARKHILFE 4K  H07 0008
       Revision: --------    Serial number: 80331110625011
       Coding: 100007
       Shop #: WSC 06402 785 00200
       ASAM Dataset: EV_SE250ParkiAssis2 S01006
       ROD: EV_SE250ParkiAssis2.rod
       VCID: 356BCF1A943641E23E-8060
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagA09 H09 0020
       Revision: --------    Serial number: 003GX00L2J2A
       Coding: 003039
       Shop #: WSC 06401 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A918CE6EDC83E1A43-801E
       Serial number: 3495RRB40530I4AGLPG-
       Serial number: 3505RRB40530I4AGNOKX
       Part No SW: 6J0 920 840 E    HW: 6J0 920 840 E
       Component: KOMBI         H01 0711
       Coding: 111A01
       Shop #: WSC 12345 123 12345
       VCID: 2C5DEA7E477C002A51-8078
    Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
       Part No SW: 6R0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H38 0025
       Revision:   H38       Serial number: 260311F2002607
       Coding: 2532C2
       VCID: 336FF10292425FD210-8066
       Component: IMMO          H01 0711
       Coding: 000002
       VCID: 6AD12C668D08DE1A63-803E
       Part No: 6R0 423 156 B
       Coding: 11251
       Shop #: WSC 06402
       VCID: 2F67FD72EA6A7B3274-807A
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441
       Component: MF-Modul       0007 0001
       Coding: 0000001
       Shop #: WSC 00046 000 00000
       VCID: 70E53E0E63D424CA2D-8024
    Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
       Part No SW: 6J1 035 153 G    HW: 6J1 035 153 G
       Component: Radio         H14 0204
       Revision: R0000000    Serial number: SEZAZ2L1884499
       Coding: 0104040001
       VCID: 2953136A408E1502AA-807C
    00856 - Radio Antenna
                        Fault Status: 00100111
                        Fault Frequency: 10
                        Reset counter: 239
                        Mileage: 155589 km
                        Date: 2019.04.15
                        Time: 17:56:31
                        Fault Status: 01101011
                        Fault Frequency: 13
                        Reset counter: 199
                        Mileage: 155624 km
                        Date: 2019.04.16
                        Time: 20:24:48
       Part No SW: 6R0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H38 0025
       Coding: 030F185A
       VCID: 74ED321ED7CC18EAC9-8020
       Subsystem 1 - Part No SW: 6R0 915 181 B    HW: 6R0 915 181
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370150042
    End-------------------------(Elapsed Time: 02:37)--------------------------
    General VW/Audi Repair is for things that don't involve VCDS at all.
    Moved to Retrofits.
  3. Likes Dannozz liked this post
    Remind me, Error 22 is "Conditions Not Correct"?
    Are you by chance trying to do this with the engine running?
  5. Likes Dannozz liked this post
    Apr 2017
    No, It was on ignition only.
    Apr 2017
    The problem is solved now. Apparently I had to change byte 10 also. Thanks Iichel and Luigid(from uk-polo) for pointing it out for me.
    The reference video for the future retrofitters: https://www.youtube.com/watch?time_c...&v=8KuUtIizboE (thanks again Luigid)
    Old drum coding:110224DB817500B3882C24E681D200521700
    the new correct 110228DB817500B3882C14E681D200521700
  8. Likes Uwe, iichel liked this post
  9. #6
    Aug 2016
    The Hague, NL
    I'm here as well
  10. Likes Uwe liked this post
