Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: MAF readings discrepancies
Hybrid View
    Mar 2019
    France
    Hi all,
    I've been chasing my tail for a while with a very strange MAF discrepancy issue between bank1 and 2 on my car (Audi RS6 C5 2003), so I'm now looking for guidance from the bright minds.
    Symptoms are that - as seen on the advanced measuring values on my Hexnet- as long as the engine temp (coolant) stays below 80C, readings on both MAFs are perfectly aligned within a 5-7% margin, but above 80C, value of maf bank 1 starts to decrease little by little compared to bank 2. When the engine reaches a stable temperature (90-95C), the discrepancies between banks are as high as 70%, and like 40-50% when idle... Of course I get a fault code on the engine ECU (and that's the only one) saying I have implausible MAF discrepancy : '17416 - Mass Air Flow Sensor 1/2 : Implausible Signal - P1008 - 004 Intermittent'.
    To cut a long story short, I've already checked all hoses (including vaccum hoses) and seals, swapped the MAFs (same readings), checked the SAI valves/system, changed the EVAP solenoid (N80), along with the N112 and N249, without success. A quick air pressure leak test on the air inlets didn't show anything to worry about...
    Sooo after chasing a physical/mechanical problem (maybe it's still the case!), I start to wonder whether something could be wrong with the control /electrical system, like - off the top of my head - the engine ECU not receiving correctly the temperature sensor of one of the MAFs for gaz expansion compensation. Would that explain the strange and slow shift around 80C? Could a faulty ECU remap create such a phenomenon (my car is remapped but rewriting the stock map didn't change anything, except performance) ? Still scratching my head on this issue, so any help/suggestion is welcome!
    Best
    May 2016
    CLASSIC, okay most mostly a TDI guy but As I see it. Cold engine might be tighter then as warms tolerances fade. That is making assumption each bank has its own MAF, could be wrong.
    Would be looking at compression check. As have no scan DON'T
    know mileage wear factor here?
    Would suspect one bank not as efficient as the other, just an opinion.
    Also post an auto scan as you will be requested to do so as were only as brite as the info we have?
    Good hunting
    LARIMORE
    Mar 2019
    France
    Quote Originally Posted by Larry Manton View Post
    Good hunting
    LARIMORE
    Missed your post Larry, thank you. Yes I have 2 MAF, one per bank. Good point, but wouldn't that efficiency mismatch be seen somewhere down the line, I don't know like injectors duty cycles or lambda readings (the latter are perfectly matched by the way)?
    Regarding the full auto scan, I'll definetely comply to the rule (away from home for a week or so, but will be done on my return), but as the only engine fault code is this MAFs mismatch I though appropriate (probably wrongly) not to bother with the rest.
    So even with the MAFs swapped, the problem (lower readings at higher temperatures) remain on Bank 1?
    Have you considered the the possibility of some wiring problem or connection that has a resistance change with temperature? Perhaps a dodgy ground connection on one side?
  5. Likes Jack@European_Parts, Classik liked this post
    Who is the tuner?
    FOD!
    Remap most likely causing problem or not reporting the entire story in stack.
  7. Likes Classik liked this post
    Mar 2019
    France
    Thank you for replies and suggestions! I checked the wiring and admittedly with theses cars the MAF connectors are never in great shape due to the VERY small space behind the engine. So yes this may well be a reason. All main grounding points have been checked and cleaned no later than last Wednesday, so we should be covered.. except if the wiring doesn't follow of course.
    However I'm puzzled to hear an impedance dependancy to temp but you guys know better than me.
    Mapper is CTF Performance (in France-serious people), but as we speak I'm running the stock map (got an external device which allows to write map at will). Does that help?
    You mean switched or completely re flashed?
    Most of time if not complete reflash the nefarious tasks still exist in most tuners alleged but not actually a stock map.
  10. Likes Classik liked this post
  11. #8
    Mar 2019
    France
    I meant completely reflashed, the whole process takes like 10 minutes.
    The map is supposed to be an oem map, but how could I know for sure..
    Is there a way to check if the MAFs readings have been changed / tricked in any way?
    Many thanks!
  12. #9
    Not VCDS related.
    Install known stock parts, perform repairs as per RTFB using VCDS blocks, codes reported and with aid of mechanical and electronic testing equipment such as load light and DVOM.
  13. Likes Classik liked this post
  14. #10
    Mar 2019
    France
    I can only concur with the above, wise recommandations of course, particularly the electrical circuit check.
    Not VCDS related.
    Sorry but I don't fully understand. Mind expanding on that? Thank you!
